Fitting a briefcase to a rack
Samsbike
PostPosted: 10:02 - 20 Jun 2016    Post subject: Fitting a briefcase to a rack Reply with quote
I have a couple of old plastic briefcases. They are waterproof, lockable, slim and relatively lightweight.
I am intending on getting a rack to carry lunch, laptop to work (I can leave my helmet in the changing rooms).
Given that the briefcase is just smaller and I have small cc bike, cant I just drill a few holes and use it as a sort of top box?
Any reason why I shouldnt?
tom_e
PostPosted: 10:06 - 20 Jun 2016    Post subject: Reply with quote
Can't see why not, I'd probably cut a sheet of metal or mdf or something to put in the bottom so you can bolt through that to spread the force of the bolts but apart from that I can't see you having any issues.
Samsbike
PostPosted: 10:21 - 20 Jun 2016    Post subject: Reply with quote
Cheers good point on the metal bit, although I am trying to keep it as light as possible.
PostPosted: 10:35 - 20 Jun 2016    Post subject: Reply with quote
You can take a fat lass on the back: a briefcase versus a decent sized top box is hardly an issue.
No reason not to use it if it's big enough though. If you don't need to remove it and aren't going to be carrying much in it, you can just cable tie it on. Washers will probably suffice to spread the load.
Matt B
PostPosted: 10:40 - 20 Jun 2016    Post subject: Reply with quote
+1
Would just bolt it on with some big fat "Penny" washers Thumbs Up
c_dug
A top box might be a bit more waterproof along it's hinges etc, no other reason not to use the briefcase.
I'd steer clear of MDF though, it'll swell and eventually come apart in the rain.
Doink
PostPosted: 23:11 - 20 Jun 2016    Post subject: Reply with quote
If you're gonna fit something you might as well just fit a small top box, you can pick them up cheap.
As well as almost certainly leaking a briefcase bolted on to a motorbike will undoubtedly attract many shouts of "briefcase wanker" as you ride down the road.
Andy_Pagin
PostPosted: 09:02 - 21 Jun 2016    Post subject: Reply with quote
Any make/model of bike in particular?
I'm toying with the same idea for my Fazer. The grab handle bolts straight into the frame with two relatively massive bolts, so in theory I could weld up some tubing to slot into the bolt holes in place of the handle. Damn sight cheaper than a proper top box frame, and probably less hideous if it wasn't for the crappiness of my welding skills
JoeDaStudd
PostPosted: 10:12 - 21 Jun 2016    Post subject: Reply with quote
Wouldn't like to say how waterproof they will be doing 30mph+ in the rain.
Grab a pressure washer and see how well they really hold up before you do anything.
Last thing you want is to spend cash and time fitting them only to find your lunch and laptop soaked during the first downpoor.
Samsbike
PostPosted: 11:12 - 21 Jun 2016    Post subject: Reply with quote
Cheers I still need to get a rack. My issue is that although I have a givi monolock box it's huge and I just wanted something smaller. The box is heavy and I think the rack max weight limit is around 8lbs which is not a lot.
Also the bikes a 125 so I don't want it even slower than it already is.
c_dug
PostPosted: 11:27 - 21 Jun 2016    Post subject: Reply with quote
Givi (and possibly other manufacturers) make single helmet sized top boxes, which are pretty small.
I'd be inclined to try and get my hands on a peli case instead of a briefcase, if you're really worried about size.
The last post was made 10 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 68.55 Kb
