Has anyone managed to diagnose this?
Yogi81
PostPosted: 10:40 - 21 Jun 2016    Post subject: Has anyone managed to diagnose this? Reply with quote
Hi folks. Been tinkering with a 2000 sv650, it has a tapping noise on the front cylinder. The cam chain tensioners have been checked and is fine and the valve clearances are well within spec. I've done a compression test and it reads 150psi in the front cylinder and 175 on the rear. any ideas what to expect? Could it be piston rings or valves? The pressure doesn't drop down it stays at 150psi
mudcow007
PostPosted: 10:52 - 21 Jun 2016    Post subject: Reply with quote
Exhaust/ headers loose?
Ive known of them to make ticking noises when leaking
weasley
PostPosted: 12:37 - 21 Jun 2016    Post subject: Reply with quote
This, this and thrice this.
I chased a "valve" ticking all over an old engine I had, checking, rechecking and checking again the valve clearances, shims, chain and tensioner. It turned out to be a leaking exhaust header gasket. Embarassed
The last post was made 10 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 35.24 Kb
