Has anyone managed to diagnose this?
Yogi81
PostPosted: 10:58 - 21 Jun 2016    Post subject: Has anyone managed to diagnose this? Reply with quote
Hi folks. Been tinkering with a 2000 sv650, it has a tapping noise on the front cylinder. The cam chain tensioners have been checked and is fine and the valve clearances are well within spec. I've done a compression test and it reads 150psi in the front cylinder and 175 on the rear. any ideas what to expect? Could it be piston rings or valves? The pressure doesn't drop down it stays at 150psi
PostPosted: 11:00 - 21 Jun 2016    Post subject: Re: Has anyone managed to diagnose this? Reply with quote
150psi sounds pretty good... Have you checked the valve clearances? What is the state of the exhaust and exhaust gasket on the front cylinder?
Yogi81
PostPosted: 11:08 - 21 Jun 2016    Post subject: Reply with quote
I thought the compression should be around 213psi with a variation of 28psi between the two. 150psi seemed low. The valve clearances are spot on all well within spec. I just can't pinpoint where or what's causing the the tapping noise??
Monkeywrenche...
PostPosted: 11:19 - 21 Jun 2016    Post subject: Reply with quote
when you did the compression test did you hold the throttle wide open? is it carbs?, in which case you'll need to hold open the slides.
Also It's the exhaust header gasket
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
The last post was made 10 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 39.37 Kb
