Silicone grease/rubber bits
ferrisio
PostPosted: 11:37 - 22 Jun 2016    Post subject: Silicone grease/rubber bits Reply with quote
Hi, I have horrible intake leaks on my R1100RS so it idles high/backfires and gets worse as it gets hotter. It looks like both inlet manifolds/rubbers/whatever you want to call them are knackered as when I spray GT85 around them the bike bogs down, plus they look a bit cracked/twisted.
My plan is to get some replacements but I also read you should use silicone grease on rubber parts like this? Will this help them seal, or make them last longer? What does it actually do? Just working out whether to order a tube - quite pricey stuff.
BMW R1100R
charlie74
PostPosted: 11:46 - 22 Jun 2016    Post subject: Re: Silicone grease/rubber bits Reply with quote
taken from wiki
Silicone grease is commonly used for lubricating and preserving rubber parts, such as O-rings. Additionally, silicone grease does not swell or soften the rubber, which can be a problem with hydrocarbon based greases
so to answer your question, it does both. its also handy for car door rubbers etc as it doesn't react with it, we used to use it for stopping doors/windows freezing totally shut
PostPosted: 11:53 - 22 Jun 2016    Post subject: Reply with quote
Expensive? no. It's cheap as chips. I use spray.
Halfords £3.99
https://www.halfords.com/motoring/engine-oils-fluids/grease/halfords-silicone-lubricant-400ml
Screwfix £2,79
BES
HT silicone grease (high tack) is for use where severe conditions of temperature and pressure require durability without the grease being too stiff to handle. For use on ‘O’ rings, valves and taps; ideal as plumbers’ grease. Complies with UK water fittings bylaws.
Part No. Description Unit Price Qty
15792 30 ml HT silicone grease £1.61
15793 60 ml HT silicone grease £2.64
ferrisio
PostPosted: 12:08 - 22 Jun 2016    Post subject: Reply with quote
Hadn't seen the spray, cheers!
BMW R1100R
PostPosted: 15:17 - 22 Jun 2016    Post subject: Reply with quote
Wintergreen oil may well help in the short term.
Be careful using it.
iooi
PostPosted: 17:56 - 22 Jun 2016    Post subject: Reply with quote
Also search out "Red Rubber Grease"
The last post was made 10 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 48.41 Kb
