| NutsyUk |
 NutsyUk Nearly there...
 Posted: 19:47 - 22 Jun 2016 Post subject: Lexmoto XTRs 125 / My Doer Upper Blog |
Hi this is my first post so bare with me...
I'm having my midlife crisis... I got a Bike!
I just got a XTRs for a really great couldn't be ignored deal. I think the bike in its current state is worth a lot more than I paid I know there are plenty of Chinese bike haters out there, but I'v been reading a lot about them and I think its fair to say Lexmoto have been a little better than most? With good parts support...
6000Kms on the clock...
Anyway The bike needs a little work;
Back brake isn't triggering the brake light.
Horns not working.
Downpipes a bit rusty but savable for now, I think I could give it a gentle sand/clean then give it some anti rust high temp paint. I know I can buy a new stainless downpipe for 50 quid but im now broke so everything as cheap as i can go :p
Rev dial is fairly slow to catch up with actual rev.
Accelerator grip has too much play before the cable pulls...
Needs new tires, back would normally take 100s but been reading 110s fit fine too...
And some of the wiring could do with being redone and sealed.
Aesthetically the bike look to be in amazing nick. No real rust issues on the frame. Just a couple of spots in screw holes and one weld bubble... Easy to clean up and fix. One thing that MUST change is the break light. Its a clear plastic one with a red coated bulb. The red light looks like it was dipped in cheap ink, the inks cracked and the light comes out bright pink...
Now I admit I'm no bike expert and I havnt even taken my CBT yet. My motor mechanic days where when I was in school Im 33 now :p So its going to be a learning experience for me.
The acceleration seems a little slow according to my brother who has an aprilla 125, but as far as I can tell everythings stock lexmoto (apart from indicator lights). I assume it just needs a cleaning and oil change at this stage. Maybe new spark plugs?
Anyway now the questions
Just so I dont miss anything, anyone got a good comprehensive check list for servicing these bikes? I plan to do it myself...
If its allowed, does anyone know where I can get a downloadable copy of the haynes manual? I think I need the generic Chinese motobike manual 4871?
As for the acceleration, I'm not a racer and tbh the bikes only to get me from A to B but I wouldnt mind a little more acceleration response but still remain learner legal, does anyone have any tips for that?
Its a 8.5Kw engine according to google thats 11 horsepower I think learner legal limit is 14? Is there anyway to squeeze out a little more power form this bike? A new carb? Sprocket calibration change? New CDI?
I realised when getting this bike there are limitations. Its not going to be as powerful than a Honda CBR but any tips would be really appreciated.
Also what is a little strange is when I did the checks on the bike the HPI checks report claimed that its only had 1 owner. But i'm certain its had more. As the guy I got it off got it from a second hand dealer who got it from some where whoever.... And the guy I got it off didnt do any work on the bike as he only got it to work on as a project but didnt get to do any work on it. Hence the after market indicators gives it away that he wasn't the first owner.
Everything legally checks out, had the v5 paperwork MOT logbook (which was empty because its never been MOTed too new)
Just something strange I noticed.
So yeah, thats me Hi
| Evil Hans |
 Evil Hans World Chat Champion
| Alan1986 |
 Alan1986 Spanner Monkey
| charlie74 |
 charlie74 Trackday Trickster
| NutsyUk |
| Evil Hans |
| NutsyUk |
| Rogerborg |
 Rogerborg nimbA
 Posted: 07:18 - 23 Jun 2016 Post subject: |
I wouldn't spend one penny more on it than you absolutely have to, as you'll never see it back. Bear in mind that if you see an advert asking £500, it's because nobody has paid that for it yet.
The XTR uses a low compression pushrod engine that's a copy of the 1970s vintage CG125 lump. You're not going to get any more speed out of it. Just keep it running right with regular servicing - it'll take any 10W40 oil, the cheaper the better (OK, maybe not Poundland ).
https://hondacg125.awardspace.com/ is a decent resource for the engine, much of the other processes will apply as well, and YouTube should provide the rest.
The rear brake will most likely be actuated by a pull-switch. Have a look at the pedal, find a wire attached to it running upwards and follow it until you find something like this:
https://images.wemoto.com/full/ELECTRICAL_STOP/10025051.jpg
It'll either need adjusted (move it upwards using the nut on it) so that it trips when the pedal is pressed, and/or removed and cleaned.
Any universal 12V horn should work, although if yours has a screw in the middle of it, try adjusting that to see if it springs back into life.
I'd ignore the rev counter until everything else is done.
The accelerator cable should have some sort of adjustment mechanism on it - it'll be no more complicated than adjusting pushbike brakes.
The wiring is likely to be fragile. If you don't have a multimeter, I'd strongly suggest dropping £5 on one.
Why does it need new tyres after just 3700 miles?  ____________________ Biking is 1/20th as dangerous as horse riding.
| NutsyUk |
| Evil Hans |
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:08 - 23 Jun 2016 Post subject: |
| NutsyUk wrote: | The break switch seems dead |
It's a simple mechanical switch, there's not much to go wrong. I've recovered one by cleaning it up internally, although they're only a couple of £££ if it's corroded too badly.
Fair enough on the tyres.
| NutsyUk wrote: | ill prolly need to tweak the carb. |
[Dramatic music.]
| NutsyUk wrote: | considering a bigger (still legal) carb. |
[Dramatic music intensifies]
It's not limited by the carb, it's not limited by the exhaust, it's limited by being a low compression 125cc engine that'll start bouncing its valves if you rev it hard enough.
Any gains you get from that engine will be illusory. Believe me, I tried. It's intended to be robust, reliable and fairly low maintenance: the bike's performance will never match its looks. Sorry. ____________________ Biking is 1/20th as dangerous as horse riding.
| NutsyUk |
 Posted: 16:42 - 23 Jun 2016 Post subject: |
Hehe dont be sorry its my first bike It was really only a hypothetical, can it be tweaked up kinda thing. Tbh im just really happy i got it so cheap. Just wish the insurance was too. (struggling as i have some history, best to not go into detail. My fault tried to do the right thing after)
But what I meant by tweak the carb was just change the air mixture as it seems to be burning too rich if the sooted up spark plug is anything to go by.
The geek in me wants to install digital speedos and rev counters :p But it seems pointless really on this bike. When I get a big boys bike maybe
And yeah the pad on the swing arm... It might be too slack. Will see what I can do there. But my dad says its happened on his and my brothers crossers and its not too much to worry about.
Funny thing, i realise the chinese bikes arent loved much... When I went to pick up the bike, we had to go bout 40 miles for it. On the way back we stopped at a mcdonalds that seemed to have a motorbike meet up going on... Im not telepathic but I could almost hear what people were thinking... SHITE BIKE! :p
But Im happy with it so far. Its cheap, cheap to run (for me not cheap to insure But nothing will be) Going to be a very simple job to get fully up and running. And the main reason for it is to get from A to B without having to rely on dad at age of 33 After moving back home into the country.
You see I lived in London and pushed biked everywhere. In the country everything is so far away... :p
Oh one Minor Fail... I managed to scratch the fairing around one side of the fuel tank , with the fuel tank when removing it to get to the electrics under it... Hopefully some t cut and maybe a spot of black paint would clean that up. |
| NutsyUk |
 Posted: 19:51 - 23 Jun 2016 Post subject: |
Yay more fun... Do the chinese have any kind of standards in wiring?
Ive taken the side back fairing off to see if theres any obvious reason for the night running light isnt turning on...
Again my electronics is a little rusty...
But since when was Green Live (+)
and Red was Neutral (-) ?
Also the said green is not just any colour of green but earth wire green. But without a yellow line.
Also it seems while Red is neutral off the battery but Yellow is neutral in other areas... as is brown and blue and some other colours. Though while multiple neutrals are useful if your running a switch off the neutral side of a light.
One other oddity I found with the wiring for the back lights. One indicator shared the positive line with the numberplate light, while the other indicator has its own line.
I would have thought the night time running light would be powered off the same line as the numberplate light.
Anyway Im struggling to find where the fault lies... Cant be in the light control switches? I mean they work...
Anyway yeah... Its looking like im going to have to buy that haynes manual Bleh more money going out of a already depleted current account... I hope it has the wiring loom circuit diagram in it... |
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:17 - 23 Jun 2016 Post subject: |
That's unusual. You're certain that there's a big red line coming off the -ve terminal and running to the frame / engine earth point?
The Haynes manual is a generic one for these bikes, it's unlikely to have a specific wiring diagram for the XTR. ____________________ Biking is 1/20th as dangerous as horse riding.
| Meatybeaty |
 Meatybeaty World Chat Champion
| NutsyUk |
 Posted: 21:26 - 23 Jun 2016 Post subject: |
Tis odd, about to go back in and fit the break switch back on managed to get it working...
Ill take a look at the map of the london underground when i get back
Thanks while i realise the look might be a different design than the one you posted might still give me some clues... |
| NutsyUk |
 Posted: 07:04 - 24 Jun 2016 Post subject: |
Fixed the peddle break light. The switch worked...
Still trying to figure out why the rear running light isnt working when the headlights are turned on...
I need to check but a friend mentioned that the break light might have 2 filaments in it. One for running light one for break... one could have burned out...
Will check a little later... Trying to comprehend how fekked we are now, after voting to leave eu  |
| Rogerborg |
 Rogerborg nimbA
| Meatybeaty |
| Rogerborg |
 Rogerborg nimbA
| NutsyUk |
 Posted: 09:07 - 24 Jun 2016 Post subject: |
Ohh that diagram is good I guess there might be slight revisions between the none s and s model... but still that helps.
Out of curiosity is there a way with this setup to install a gear selected indicator? |
| WD Forte |
 WD Forte World Chat Champion
| NutsyUk |
| WD Forte |
| NutsyUk |
 Posted: 14:35 - 24 Jun 2016 Post subject: |
God a meter and making good use of it :p Though even though i just replaced the battery on the meter its still showing the wrong volt level Anyway still working to show me a feed...
Anyway today is cleaning the chain and sprockets day. |
The last post was made 9 years, 234 days ago. Instead of replying here, would creating a new thread be more useful? |
