Clutch sticking
B0ndy
PostPosted: 22:21 - 23 Jun 2016    Post subject: Clutch sticking Reply with quote
Weird one, ever since replacing my clutch plates + springs my clutch sticks after a period of time. If I start the bike in the morning or after X amount of hours, pull in the clutch and drop down to first it starts moving with the clutch held in.
Because of this my starting routine now involves putting the bike on the side stand, putting it in first and giving it a few blips of the throttle until the back wheel stops moving - that way I don't get dragged down the road Laughing
The internetz says change oil and see whether that helps but I changed it when I did the clutch job - I used the same grade just a different brand.
I don't want to replace the oil to find the problem still exists.
Any ideas? Thumbs Up
Bike is a CB400SF NC31 F2N
CBF 125 -> CB400SF -> GSX600F -> ZX6R (G1) -> GSXR1000 K4 -> ZX6R (B1H Stunt bike) -> VFR800 -> R1 5PW -> Sprint 1050 -> Fireblade 929 -> ZX10R C2H -> GSXR1000 K3
jaffa90
PostPosted: 23:30 - 23 Jun 2016    Post subject: Reply with quote
What exactly was the oil you put in?
Also what`s the tick over / idle speed ?
Did you soak / coat the plates with oil before fitting?
B0ndy
PostPosted: 17:25 - 24 Jun 2016    Post subject: Reply with quote
Motul 5000 Semi-Synthetic 10W/40, I usually use Silkolene Super 4 10w40 Semi Synthetic
1 - 1.5k RPM
I left them in fresh oil overnight
jaffa90
PostPosted: 17:59 - 24 Jun 2016    Post subject: Reply with quote
Sounds ok, also is the oil level not to high ?
Is the clutch biting with the lever half way out or where?
The last post was made 10 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 40.58 Kb
