SUZUKI FZ50
gespejel
PostPosted: 22:58 - 27 Jun 2016    Post subject: SUZUKI FZ50 Reply with quote
hi! I recently bought a Suzuki Fz50 but the previous owner took out the blinkers, does anyone can direct me to where I can buy them and instructions on how to install them?
Also, I can't see where you turn on the blinkers, everything was removed from my bike. Could someone share a picture?
Thanks!!!
-Grace Espejel
RhynoCZ
PostPosted: 23:46 - 27 Jun 2016    Post subject: Reply with quote
Here: https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=SUZUKI+FZ50&_sacat=0
The switch should be on the left handlebar. ( https://www.ebay.co.uk/itm/1980-suzuki-fz50-left-switch-lights-turn-horn-/252428009569?hash=item3ac5e1c061:g:6I4AAOSwstxU9Tdc )
Here (not sure, but the Google says Suzuki FZ 50):
https://4.bp.blogspot.com/-MyQ2cSK2RBQ/UEupIylQJ0I/AAAAAAAABBM/OM78cIMCynM/s1600/Suzuki+FZ+50+wiring+diagram+England.jpg
https://2.bp.blogspot.com/-Q-NSKkeRnYU/UEupJ_6EtdI/AAAAAAAABBU/pKZpOO5pXkQ/s1600/Suzuki+FZ+50+wiring+diagram+other.jpg
https://2.bp.blogspot.com/-JUrlA-9QJuE/UEupF0KABbI/AAAAAAAABA8/FE2Wh17sc0E/s1600/Suzuki+FZ+50+wiring+diagram+Australia+and+general+market.jpg
https://4.bp.blogspot.com/-cPgqj0p4_Hg/UEupHA5XGbI/AAAAAAAABBE/khs1vaed5yU/s1600/Suzuki+FZ+50+wiring+diagram+Denmark.jpg
ninja_butler
PostPosted: 07:44 - 03 Jul 2016    Post subject: Reply with quote
I've got a Suzuki FZ50 myself, I'll upload some photos of the wiring later. The rear indicators are a doddle, just make sure they are well earthed to the frame. The wires for the front indicators go inside the handlebars and into the headlight shell so they'll be a bit fiddly; you might want to feed a piece of wire through from the other end and pull the indicator wires through.
The main job - as Rhyno pointed out already - will be to fit the lefthand switch unit. If you look at the correct Suzuki FZ50 lefthand switch assembly, it has wires for:
1. Indicators.
2. Brake light.
3. Headlight hi/lo
4. Horn.
edit*
While you are doing the indicators, have a good look at the state of the wiring and electrics on your FZ, rusty things will cause earthing and voltage problems (it's only a 6 volt battery) but the electrical system components for an FZ are all cheap and easy to replace.
https://i1213.photobucket.com/albums/cc469/Ninja_Butler/Suzuki%20FZ50%201980%20Suzy%20wires/headlight%20shell.jpg
https://i1213.photobucket.com/albums/cc469/Ninja_Butler/Suzuki%20FZ50%201980%20Suzy%20wires/left%20side.jpg
https://i1213.photobucket.com/albums/cc469/Ninja_Butler/Suzuki%20FZ50%201980%20Suzy%20wires/right%20side.jpg
There is a gap of 253 days between these two posts...
theoilman
PostPosted: 22:02 - 13 Mar 2017    Post subject: 1982 FZ50 CDI Reply with quote
I am in the US and just purchased a 1982 Suzuki FZ50 that I can not get spark from. When I purchased it, it was about 80% together with the rest of it in a box.
The previous owner said the ignition coil on the magneto was bad, but the odd thing is, I can not find a CDI unit or voltage regulator on the bike or in the box, Suzuki seems to have taken these items off the parts schematic too. My stator/magneto only has 4 wires and everything I see in schematics shows it having 5 wires, the red/white is the one missing.
Does anyone have a 1982 FZ50 that could tell me where I would find or even send me pictures of the CDI box (the pictures above don't show a cdi either) or where it mounts. I cant even find open connectors in the wire harness...
This is a real head scratcher.
Thank you for any help!
Paul
hmmmnz
PostPosted: 00:18 - 14 Mar 2017    Post subject: Reply with quote
https://www.cmsnl.com/suzuki-fz50-1982-z-e01-e02-e09-e16-e24-e26_model13337/partslist/FIG17.html#results
number 6.
https://images.cmsnl.com/img/partslists/battery_bigsue0324fig17_5116.gif
i saw your post on moped army
and it looks like your cdi has been unplugged
https://i.ebayimg.com/images/g/4hwAAOSwDk5UK5Gj/s-l1600.jpg
[url=heres a cdi on ebay]https://www.ebay.com/itm/Suzuki-FZ50-FZ-50-Rascal-moped-scooter-CDI-box-electrical-relay-unit-/251663913835?hash=item3a9856936b:g:4hwAAOSwDk5UK5Gj&vxp=mtr[/url]
the humans are dead
I kick arse for the lord
The last post was made 9 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.89 - MySQL Queries: 13 - Page Size: 47.79 Kb
