| DRZ4Hunned |
 DRZ4Hunned World Chat Champion
 Posted: 11:37 - 04 Jul 2016 Post subject: Wiring a shed |
So I've bought a shed to use as a workshop, it's 16' x 10' and is located at the bottom of my garden (about 25m).
I've done some research into wiring it up and I think I now have a basic understanding of what to do but I'd like to check with someone more knowledgeable before I potentially kill myself or burn my shed down. (I've never done any sort of electrical installation before - I have wired a plug though if that helps?)
Budget is a constraint so I'd ideally like to avoid getting a sparky in and getting it signed off, but I still want to do it properly and safely.
I have two external sockets on the house which I'm guessing would be a spur from the ring in the kitchen. To avoid the need for a inspection certificate, I was planning on essentially creating a large extension lead by using some 2.5mm Arctic Flex cable and putting a 13A plug on the end and plugging this into the external socket of the house to provide the power to the shed.
I would then run this flex cable into a mini consumer unit with a 16A (sockets) and a 6A (lights) MCB. The plan was to then run two circuits in the shed, a lighting circuit consisting of two 5' LED T8 Fixtures, connected by 1.5mm T&E via a switch. And 5 double sockets connected by 2.5mm T&E.
Does this setup sound sensible? I know I should ideally run SWA in a buried trench connected to the consumer unit of the house, but this would involve getting a sparky in to sign it off which I want to avoid if possible.
Also do I run the sockets and lights on a radial circuit or a ring main circuit?
Appreciate any feedback on this  ____________________ DRZ400-SM
FZS600 |
| zark |
 zark Trackday Trickster
| Meatybeaty |
 Meatybeaty World Chat Champion
 Posted: 12:10 - 04 Jul 2016 Post subject: |
Just wondering if anything went wrong with the wiring, would it negate a claim from your house insurance, as regards equipment in the shed, dont know myself but worth finding out about  |
| faffergotgunz |
 faffergotgunz Nova Slayer
| charlie74 |
 charlie74 Trackday Trickster
| UncleFester |
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| Suntan Sid |
 Posted: 15:37 - 04 Jul 2016 Post subject: |
I can't find it but i'm sure this was discussed sometime within the last 6 months.
I built a shed, (16' x 8')in my garden, 40m fom the house.
In the shed there was, lighting, a wood turning lathe, a band saw, pillar drill bench grinder and all the usual hand held eletric tools.
I used a shop bought 50m extension lead, which I plugged into the house and ran up the gaden to the shed.
Never had a problem in all the years I used it.
Never blew a fuse or tripped a circuit breaker!
As someone has said how many items do you think you'll be using at any one time?
The most I ever used was three, lathe, sander and lights!
As for wiring in the shed, all I did was run four gang extension leads to the work benches and plugged them in when I needed them. ____________________ "Everybody needs money, that's why they call it money!"  |
| DRZ4Hunned |
| DRZ4Hunned |
 Posted: 17:07 - 04 Jul 2016 Post subject: |
| Suntan Sid wrote: | I can't find it but i'm sure this was discussed sometime within the last 6 months.
As for wiring in the shed, all I did was run four gang extension leads to the work benches and plugged them in when I needed them. |
Interesting to know that you can run all that without any issues, I'm not sure exactly what I'll be using at the same time, probably a radio, lights and possibly a power tool such as a drill or a grinder but I'd like the options of more if needed. I've heard electric heaters are a big no no. ____________________ DRZ400-SM
FZS600 |
| angryjonny |
 angryjonny World Chat Champion
| 331X2 |
 331X2 Crazy Courier
| sensi5446 |
 sensi5446 Trackday Trickster
| DRZ4Hunned |
| drzsta |
 drzsta World Chat Champion
| MCN |
 MCN Super Spammer
| doggone |
 doggone World Chat Champion
| DRZ4Hunned |
| stevo as b4 |
 Posted: 20:34 - 05 Jul 2016 Post subject: |
In my shed I've run normal three core in plastic conduit about 25m from a 13A spur on the garage ring main I had professionally fitted.
In the shed I've kept it simple. One fluorescent strip light and fused switch, and a double socket, that I'll just plug an extension lead into for any extra stuff I want to run.
Be realistic, as in a shed your probably never going to run more than the lights and one power tool at any one time?
The most I'll ever run when I'm not in there is a battery charger and maybe a de-humidifyer in winter. I might run a heater in there in winter when working on bikes, but a 1kW oil filled radiator seems to be OK, and I'd just unplug it to use a drill or saw etc. |
| DRZ4Hunned |
| stevo as b4 |
| Baffler186 |
 Baffler186 World Chat Champion
 Posted: 10:54 - 06 Jul 2016 Post subject: |
What I did:
Drill out from your fusebox to the outside of the house.
Get some armoured cable, even if you're not burying it.
Buy a consumer unit (£30 ish from toolstation)
Find a sparky who does private work (friend's son, uncle's ex-cousin, sum1 must no sum1?)
You can try connecting it all up yourself, but I wouldn't. A sparky will make a much neater job, and you'll know it's done proper.
FWIW I paid £120 cash, that included consumer units, junctions/fittings and labour. That was taking a wire direct from fuse box, running it (neatly) alongside the house, buried under the garden/driveway (which we did afterwards to save labour) then wiring in 2 x sockets and 2 x strip lights.
I might add I got the armoured cable free, so maybe look up costs for that. ____________________ Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic |
| faffergotgunz |
| MCN |
 MCN Super Spammer
 Posted: 17:59 - 06 Jul 2016 Post subject: |
| syl |
 syl World Chat Champion
 Posted: 04:04 - 25 Jul 2016 Post subject: |
Sorry, bit late but just got back from holidays. If you're going to do it with a 13A plug, I'd forget the consumer unit. Just connect the sockets up directly and use a 5A fused spur for the lights
If you do it properly, yourself, look into voltage drop and earthing regulations. I had to use 3 core 10mm armoured cable, which costs £££, to connect up a couple of outbuildings. I did the majority of the work myself and got an electrician in to connect it up to the main and submain fuseboxes. The garden eventually recovered from the mess. Since I went to the expense I used conduit and put in water and a spare too.
https://www.amigo.co.uk/obsy/37.JPG ____________________ Current bike: Kawasaki Z750S |
The last post was made 9 years, 353 days ago. Instead of replying here, would creating a new thread be more useful? |
