Strange thing happened today.
Bozzy
PostPosted: 18:15 - 06 Jul 2016    Post subject: Strange thing happened today. Reply with quote
Went out on the bike earlier today for circa 2.5 hours. Nearing the end of my ride after a long motorway run, my bike started running on 1 cylinder. I managed to limp it home after a few cut outs on the way. After leaving it a few mins at home, I started it again and it was still only running on 1 cylinder. I then decided to grab some lunch and have a look at trying to find the issue afterwards. After lunch I restarted the bike and everything was back to normal. I'm assuming I might have a loose ht lead or dodgy plug? Just wondering if anyone has suffered similar???
Bike is a 2004 SV650. It was bone dry outside, so not a soppy plug.
doggone
PostPosted: 18:49 - 06 Jul 2016    Post subject: Reply with quote
I'd expect it has two ignition coils and one of them is on the way out.
They can often behave pretty strangely before giving out completely.
RhynoCZ
PostPosted: 18:51 - 06 Jul 2016    Post subject: Reply with quote
What doggone says, faulty coil/s got hot and stopped working. If it really ran alright when cold, then it's time to change the coil/s. Thumbs Up
Just a thought, does the charging system give you enough voltage?
Bozzy
PostPosted: 19:12 - 06 Jul 2016    Post subject: Reply with quote
Thumbs Up Thanks for confirming that guys.
PostPosted: 21:04 - 06 Jul 2016    Post subject: Reply with quote
Check the front plug recess isn't full of crud, water and corrosion.
nitrosurf
PostPosted: 21:45 - 06 Jul 2016    Post subject: Reply with quote
Trawling the internet a lot reading about motorcycles leads to some things sticking around in my head; what Stinkwheel has said I've heard (or more appropriately read) from SV owners on quite a few occasions. Apparently it's a foible of the bike, but I imagine any bike with a similar engine layout and nothing to stop spray/road crud accumulating could suffer with the same thing.
Holdawayt
PostPosted: 08:58 - 07 Jul 2016    Post subject: Reply with quote
Just checking... you have fuel right?
It sounds almost like how a bike feels when it's starting to run out.
331X2
PostPosted: 10:24 - 07 Jul 2016    Post subject: Reply with quote
If you know what cylinder was dropping out, swap the coils over and see if the issue moves with it.
RhynoCZ
PostPosted: 10:27 - 07 Jul 2016    Post subject: Reply with quote
Issues that seem like fuel starvation: Faulty coil/s, faulty charging system, faulty battery, faulty fuel pump (if fitted), dirt/water in fuel clogging up the system, ... Razz
Bozzy
PostPosted: 22:06 - 07 Jul 2016    Post subject: Reply with quote
Thanks for the comments guys.
I don't think it will be a wet plug on the front cylinder as I have a fender extender and I rarely ride in the rain. That said, I'm going to check the drain hole to make sure it isn't blocked up and have a general look around the plug. I'll change the plugs if this is the case and may put new coils on irregardless as they aren't expensive or difficult to fit.
(Although I managed to turn fitting a hugger into a 3 hour job so anything could happen!)
Edit to add definitely not fuel. Got plenty of that left.
Bozzy
PostPosted: 18:11 - 08 Jul 2016    Post subject: Reply with quote
Just something I noticed reading my Haynes.
They recommend an NGK CR8E spark plug or, for "extended high speed riding" they recommend an NGK CR9E. I had been riding at high speed for well over an hour, just wondering if the issues I encountered were due to using the CR8E which is the hotter of the two plugs?
Bozzy
PostPosted: 21:46 - 13 Jul 2016    Post subject: Reply with quote
Bit of an update. New plugs arrived today along with a feeler guage I'd bought to check the gaps. I promptly whipped the old plugs out and discovered they were carbon fouled and one of the plugs has had water ingress judging by the corrosion on it. Anyway, new plugs in and everything is running tickety-boo. Looks like it's running rich so I'll need to check the air filter isn't blocked or in need of renewal. It wouldn't surprise me if it needs renewing..the bike was supposed to have a full service before delivery to me and I'm not so sure it has looking at the condition of the plugs (I've only done 700 miles since I bought the bike)
Image of the old plugs attached.
P.s thanks for your help guys Thumbs Up much appreciated
PostPosted: 23:29 - 13 Jul 2016    Post subject: Reply with quote
Dance! Dance!
Bozzy
PostPosted: 18:50 - 14 Jul 2016    Post subject: Reply with quote
stinkwheel wrote:
Dance! Dance!
Thumbs Up I thank you kind sir Karma
The last post was made 10 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 79.51 Kb
