Triumph starter failure (with pics)
BillyJ
PostPosted: 20:26 - 13 Jul 2016    Post subject: Triumph starter failure (with pics) Reply with quote
My triumph starter shat itself...
Apparently it is a common issue.
The starter gear is pretty mashed but the idler gear is missing 3 teeth.
There is some nice metal shaving as well.
What do we think the solution is... new gear and new starter... or get the upgrade kit at this eye watering price...
https://www.ebay.co.uk/itm/TRIUMPH-SPRAG-CLUTCH-STARTER-UPGRADE-1050-SPEED-TRIPLE-TIGER-DAYTONA-955i-/262492255755?hash=item3d1dc1f60b:g:8RIAAOxyc2pTbfnW
https://s31.postimg.org/6vvlef9a3/IMG_20160713_192025.jpg
https://s31.postimg.org/gx0fnqmd7/IMG_20160713_192058.jpg
https://s31.postimg.org/l8p1cqta3/IMG_20160713_195150.jpg
https://s31.postimg.org/5buutrq9n/IMG_20160713_195411.jpg
Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser"
McJamweasel
BCF Junkie
PostPosted: 20:38 - 13 Jul 2016    Post subject: Reply with quote
I think Triumphant are taking the piss there.
There is a kit available from Triumph for about £460. Send me your engine number and I'll check tomorrow for you and tell you exactly what's in the kit.
BillyJ
PostPosted: 20:42 - 13 Jul 2016    Post subject: Reply with quote
PM'd Thumbs Up
Robby
Dirty Old Man
PostPosted: 09:26 - 14 Jul 2016    Post subject: Reply with quote
The original lasted 50k+ miles. A standard replacement should last the same. You won't be keeping the bike long enough for a standard replacement to get worn out again.
BillyJ
PostPosted: 09:35 - 14 Jul 2016    Post subject: Reply with quote
New gear and starter will cost about 200 to 300.
I have a feeling the sprag may be dead too though, what symptoms would that show?
Before I took the gear out, my bike span the starter a few times before engaging and I imagine that is the sprag as on the idler gear there are no 2 teeth missing next to each other and I imagine the starter engages 2 teeth.
BillyJ
PostPosted: 10:42 - 14 Jul 2016    Post subject: Reply with quote
Managed to get on a microscope at work and if anyone cares here are 2 of the failed teeth
One seems to be a brittle fracture from overload and the second seems the same although it seems the tooth cracked and was still half attached and the next tooth on the motor pulled it off completely as can be seen form the smoother section which would be plastic deformation of the tooth bring pulled off by the motor.
Either way, they both seem to not be from wear...
https://s31.postimg.org/6fbha95p7/SNAP_102430_0107.jpg
https://s31.postimg.org/oo40g0n1n/SNAP_102523_0108.jpg
Robby
Dirty Old Man
PostPosted: 17:11 - 14 Jul 2016    Post subject: Reply with quote
Any chance your battery was a bit tired?
BillyJ
PostPosted: 17:31 - 14 Jul 2016    Post subject: Reply with quote
Yes, I had a problem starting it once which I suspected was the battery, I have a new one ready to fit
The last post was made 10 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 56.86 Kb
