Lipo charger wet cell battery?
mudcow007
PostPosted: 10:46 - 21 Jul 2016    Post subject: Lipo charger wet cell battery? Reply with quote
I have a Turnigy Accucell 6 charger for charging my lipo's - which works as it should.
I need to charge a 12v battery from a UPS, its a sealed lead wet cell battery etc..
On the charger it has got a charge program for leaded batteries?
but then i'm stumped on the charge rate...
Goes from 0.1A -> 6.0A
then 2.0v(1P) -> 20.0v(10p)
I havent looked at the battery yet - I suppose it may have its charge rate on the case?
**edit** found the battery
Ritar RT1272 [12v 7.2AH/ 20HR]
constant voltage charge
Cycle use 14.6 - 14.8v
Standby use 13.7 - 13.9
initial currant less than 2.1A
Im guessing the 2nd value is just what voltage the battery is, just didnt know what the "p" value was?
The Artist
PostPosted: 11:36 - 21 Jul 2016    Post subject: Reply with quote
Just whack it on 6A @ 14.6V
Keep an eye on it in case it starts to bubble or get hot.
1P = 1 cell = ~2.1V for lead acid.
bladerunner
PostPosted: 00:23 - 22 Jul 2016    Post subject: Reply with quote
stick it on PB and itll only draw what it wants...at less than 1c....like said before keep an eye on it and drop it to say 1/10th c if overnight charging..your charger will turn off or switch to trickle charge anyhow once the battery is charged......lipo charger on SLA battery is a lot more high tech than most SLA batterys are used to dealing with Smile
mudcow007
PostPosted: 09:29 - 22 Jul 2016    Post subject: Reply with quote
Cheers guys Thumbs Up
PostPosted: 18:19 - 27 Jul 2016    Post subject: Reply with quote
As above - if you've got the time, I'd stick it on 1/10th C for a lead acid, especially one like that. (Though 7.2AH is pretty tiny for a UPS.)
So I'd be tempted to go for more like .7A.
mudcow007
PostPosted: 11:14 - 29 Jul 2016    Post subject: Reply with quote
Cheers G, the battery in question is only from a APC 700 - the battery is doubled making it 24v
The last post was made 10 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 47.52 Kb
