Slightly retarded question - my bike smells of petrol...
trevoriv
PostPosted: 18:10 - 08 Jan 2006    Post subject: Slightly retarded question - my bike smells of petrol... Reply with quote
Right, my bike and the area around my bike smells of petrol and everyone is saying thats not right theres something wrong with it. Well every bike ive used has had that typical bike/petrol smell so im assuming its nothing out of the ordinary as theres no leaks or puddles under the bike so why does the bike smell of petrol? Smile
*told you it was retarded*
-Savage-
PostPosted: 18:32 - 08 Jan 2006    Post subject: Reply with quote
could just be excess unbunt fuel in the exhaust gases. does the smell increase when you run the bike?
trevoriv
PostPosted: 18:39 - 08 Jan 2006    Post subject: Reply with quote
nope just always smells a bit petroly Smile never really changes, it is a 10 yr old bike mind, not really worried about it just want to give ppl the reason why it smells hehe
Mik_RX125
PostPosted: 20:30 - 08 Jan 2006    Post subject: Reply with quote
Well first thing I'd do is put a "No Smoking" sign on it, for whenever you go out on it. Then go around it checking for slight leaks, mainly around the petrol tank and carbs. If you can't find anything then stick pine tree car smellies around your friends necks to shut them up.
Mik
Yamaha FZ6 Fazer S2 owner
See all my Bikes
Groove
PostPosted: 22:26 - 08 Jan 2006    Post subject: Reply with quote
My ZXR used to smell of petrol when sitting there after a journey.
Turned out to be the vacum for the fuel tap didnt work or somthing so it was always letter petrol though Shocked
Got it fixed though
BlackSheep
PostPosted: 22:34 - 08 Jan 2006    Post subject: Reply with quote
It's probably just fumes from your vented fuel cap .
GSXR 1100 StreetFighter
trevoriv
PostPosted: 22:45 - 08 Jan 2006    Post subject: Reply with quote
we'll go with that i think Smile it smells a bit worse when the tank is full so i think its something to do with venting, there is def no leaks so im not worried just curious.
dotti
PostPosted: 23:34 - 08 Jan 2006    Post subject: Reply with quote
Do you leave the fuel tap on when the bike is sitting around? It's possible that the float valve could be allowing some petrol to escape from the carb overflow pipe.
Dangerous traffic offences spotted on 50-minute trip: Lost count after 100. Number of traffic cops spotted: One, sitting by a speed-trap camera
extreme3d
PostPosted: 00:04 - 09 Jan 2006    Post subject: Reply with quote
Just a quick word of caution that yes it may well be the tank vent as air needs to be let in to allow the fuel to flow out.... but petrol vapour is heavier than air so it goes down, not up. Whilst it may smell a bit around the vent it's not usually enough to be intrusive.
A quick and easy way to see vapour is to place your bike in the garage. Put a light coloured board or sheet in the background and shine a light towards the bike. Now watch the shadow closely as vapour is immediately obvious. Watch 'under' the bike to see it falling. You might need to do the bike on both sides. If you don't see any vapour then the amounts leaking are nothing to worry about.
Try the trick with some petrol in a jug first (if you don't believe me Laughing ). Tip the jug over just enough so that the petrol can't flow out. In the shadow though the vapour will be 'pouring' from the lip Thumbs Up
dodsi
Dirty Carny
PostPosted: 00:09 - 09 Jan 2006    Post subject: Reply with quote
When was the last time you filled up?
Could you have over filled?
I have done that and the garage reeked of fuel.
PostPosted: 01:58 - 09 Jan 2006    Post subject: Reply with quote
My garage always smells of petrol. There are normally 3 bikes in there mind.
I would imagine it's my RXS Very Happy .
trevoriv
PostPosted: 19:34 - 09 Jan 2006    Post subject: Reply with quote
All seems well, just a smelly old bike that likes to vent Thumbs Up
Golf_gti
PostPosted: 18:29 - 20 Jan 2006    Post subject: Reply with quote
maybe its some leeked down onto the frame from when youve refilled in a petrol station???
i duno its just a wild guess!!!
i didnt mean for it sound stupid:DVery Happy thats just my theory!!
RazzRazzVery HappyVery Happy
Wink-Dan-Razz
Early 2006 MY TZR 50 2004... was ready and i was free!!....well until my tank ran out lol!!
mchaggis
PostPosted: 20:41 - 20 Jan 2006    Post subject: Reply with quote
Your garage smells of petrol? You're lucky, mine stinks of god knows how many solvents, greases, degreasers, paints, lacquers, varnishes, oil and also petrol. It's enough to make you feel odd sometimes. Confused
The last time I got a really bad petrol smell it was because I was moving a tank and somehow managed to turn the tap while I was putting it down on the bench. Shocked
There's always a bit left in the hose at the pump to annoy you too. Rolling Eyes
I must not be a troll...
Mmmm, Guinness
TOM M
PostPosted: 01:19 - 21 Jan 2006    Post subject: Reply with quote
Bit off track but when i over fill the tank on my car (and its about 12 years old) it stinks of petrol. Only happens if i fill it to the brim
Now owner of a 1200 Bandit
loply
PostPosted: 18:40 - 21 Jan 2006    Post subject: Reply with quote
My bike used to smell a lot of petrol, but not so much these days. No idea why.
I assume your bike is carbed? If so, and if no liquid petrol is leaking out, I wouldn't worry about it too much.
Yamaha SZR660 Caution to the wind, the throttle pinned!
Golf_gti
PostPosted: 23:00 - 21 Jan 2006    Post subject: Reply with quote
i thought my bike was leeking petrol because there was a really strong smell in the garage, i found out it was a open jerry can with diesel inside it lol!!
RazzVery HappyRazz
Wink-Dan-Razz
Teaman
PostPosted: 18:27 - 22 Jan 2006    Post subject: Reply with quote
waft a light match around the parts of the bike that might be a cause, eventually you will not only find the problem but cure it at the same time,
my bike pongs from the air ducts, after a buzz
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
BFG
PostPosted: 18:55 - 23 Jan 2006    Post subject: Reply with quote
Agree. Turning the petrol off is standard practice. Many modern bikes have a vacuum system that does this for you now. If you have one of these, it could be faulty.
Which bike is it?
owdamer
PostPosted: 21:41 - 24 Jan 2006    Post subject: Reply with quote
My yzf started smelling of petrol, turned out to be the fuel pump seal had failed and petrol was leaking out.
My girlfriends tzr had an odd petrol tank. It used to sigh every couple of minutes..
There is a gap of 10 years, 188 days between these two posts...
radotrenco This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
MCN
PostPosted: 12:17 - 29 Jul 2016    Post subject: Re: Smell of petrol gone Reply with quote
radotrenco wrote:
Guys if you are still experiencing gas (fuel) smell I found the solution to it on my Yamaha XT660Z Tenere 2009. It got very bad about 3 weeks ago so I removed all bolts from fuel cap and found 4 small springs under the rubber seal. Make sure you put rag over the fuel tank neck so you don't drop anything inside before you start removing anything. I extended those 4 springs by about 5mm by pressing flat head screw driver in between the spirals of the springs. Put them back in and it solved it all. No more gas smell. Those springs get weaker with age and there is not enough pressure for the rubber seal to seal the fuel tank entry. Good luck with this and don't inhale fuel vapour if you don't have to. Smile Stay safe.
Thanks for that (and resu-rectuming a thread from Tutankhamun's Forum.)
V2
PostPosted: 06:35 - 30 Jul 2016    Post subject: Reply with quote
Does the op's bike still smell of petrol though?
The last post was made 10 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 120.99 Kb
