| Mart_er6 |
 Mart_er6 Nitrous Nuisance
 Posted: 22:10 - 11 Aug 2016 Post subject: Clutch permanently engaged? |
'Evening..
Yesterday my clutch cable snapped accelerating up a motorway slip road as I changed gear.. slight brown pants moment. I thought it would be an open and shut case of a frayed cable (done 30k miles).
However doubt set in quite early as before I called the recovery van I tried just pulling on the remains of the wire to change gear. Doing this, when I selected first, the gear would not disengage and the bike stalled.. Recovery van called and picked me and bike up
Back home tonight, repeated the test and manually moving the clutch housing leaver (that the cable pulled) makes no difference to the sound of the engine in neutral (it used to change with clutch engaged/not engaged) and again in first pulling the clutch housing leaver didn't disengage the gear, bike stalls (should have put it on center stand!)..
So is it possible the clutch is stuck/fused in the engaged position? If so, any idea what to do with it (other than send it to the Triumph dealer)? Strip and replace/clean? Any other thoughts/ideas?
I have a new cable coming shortly, but I strongly suspect that it won't fix the problem.. One other thing, after a dealer service a month ago, it came back with a different biting point quite near the end of the lever outwards travel..
Bike is a Sprint ST1050..
Martin ____________________ Honda Varadero XL125 "Vara" > Kawasaki ER6F "Smerf" > Triumph Sprint ST 1050 |
| Artens |
 Artens Borekit Bruiser
| G |
 G The Voice of Reason
 Posted: 23:25 - 11 Aug 2016 Post subject: Re: Clutch permanently engaged? |
How were you trying to 'pull' the cable? The lever gives a significant, well, leverage .
I wouldn't expect you'd be able to pull it by hand.
Best way to do I'd say is to knock it into neutral before stopping if possible, or stall it.
To start off, ideally stop on a downhill - but if on flat, start in neutral, push it for a bit until there's a little speed, then drop it into gear.
Read up on clutchless changes if you're not used to it. |
| Mart_er6 |
| G |
| sickpup |
 sickpup Old Timer
| Robby |
 Robby Dirty Old Man
| Mart_er6 |
| jaffa90 |
 jaffa90 World Chat Champion
| G |
| sickpup |
 sickpup Old Timer
| Mart_er6 |
 Posted: 12:29 - 12 Aug 2016 Post subject: |
Yes, will fit the new clutch cable first before removing clutch cover etc. 95% sure I'm pushing the actuator correctly when testing it but you lot have me doubting everything  ____________________ Honda Varadero XL125 "Vara" > Kawasaki ER6F "Smerf" > Triumph Sprint ST 1050 |
| smallfrowne |
 smallfrowne Scooby Slapper
| Mart_er6 |
| Mart_er6 |
| bikenut |
 bikenut World Chat Champion
| Mart_er6 |
| iooi |
 iooi Super Spammer
| Mart_er6 |
| nitrosurf |
 nitrosurf Trackday Trickster
| Dave70 |
 Dave70 World Chat Champion
| yen_powell |
 yen_powell World Chat Champion
The last post was made 10 years, 53 days ago. Instead of replying here, would creating a new thread be more useful? |
