| sebwin |
 sebwin L Plate Warrior
 Posted: 18:56 - 10 Aug 2016 Post subject: SOLVED - CBF500 - Battery issue - Draining 0.16A |
Hi,
I have a 2006 Honda CBF 500 ABS bike.
I use it about once every 2 weeks.
After 4 weeks of no use, battery was unusually dead (dashboard lights didn't even come on).
Battery removed = 7V !!!
Replaced with new, charged, battery. Bike started fine first time, but I did not ride it.
1 week later went for a ride and starter motor wouldn't fire (dashboard lights did come on).
Battery removed = 8V
I've trickle charged the new battery = stable at 12.9V and re-fitted.
I've removed the positive lead and using a multimeter read a draw of 0.16Amp = too high.
I've sequentially removed all the 10A fuses from the main fuse box (indicators etc), with no effect on the draw.
I've removed the two 10A ABS related fuses near the starter solenoid with no effect on the draw.
I've removed the 30A fuse on the starter solenoid, which causes the draw to drop to 0 Amp.
I'm a little unsure where to go next... would you be able to kindly help, I'm beyond the edge of my knowledge with this!!!
Thanks a lot for your help
| fast wooly |
 fast wooly Two Stroke Sniffer
| sebwin |
| sebwin |
| davebike |
 davebike World Chat Champion
 Posted: 06:44 - 16 Aug 2016 Post subject: |
That is why most pro's like me check the battery and stator to sort charging issues not the rec/reg the test is just not reliable
A current draw test with bike of can as you have proved be useful ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| fast wooly |
| jjdugen |
 jjdugen World Chat Champion
The last post was made 9 years, 186 days ago. Instead of replying here, would creating a new thread be more useful? |
