Rough running at low revs, No.2 exhaust downpipe not as hot.
Kozak
PostPosted: 13:15 - 16 Aug 2016    Post subject: Rough running at low revs, No.2 exhaust downpipe not as hot. Reply with quote
As in the title been rough running at start up and low revs as if only running on 3, but once revs up higher beyond 5,000 seems to improve, plenty of power and cruises no problem 70+. I was convinced the valve clearances would be way out on No 2 but no, all still in spec. Pulled the cap off and with a spare spark plug fitted there are plenty of sparks getting through. The No2. sparkplug looks similar tan coloured like the rest.
What to check next? - I just stripped and cleaned the carbs this last winter and don't want to do that again. Should I check if carbs are out of balance? Would that explain having one cylinder No2 not getting enough fuel/air getting through. Or should I check the fuel level in each carb? Suggestions welcomed.
1987 Kawa GPz550 91,400 miles. Regularly serviced.
MCN
PostPosted: 13:54 - 16 Aug 2016    Post subject: Reply with quote
If electrics ar eall good then carb balance is next thing. If out as much as you say then the gauges will show what's what.
jaffa90
PostPosted: 00:24 - 17 Aug 2016    Post subject: Reply with quote
Sounds like No2 pilot jet is blocked.
temeluchus
PostPosted: 02:39 - 17 Aug 2016    Post subject: Reply with quote
blocked pilot jet, stuck float, float needle stuck, carbs wildly out of sync, idle mixture screw not set correctly.
mentalboy
PostPosted: 03:56 - 17 Aug 2016    Post subject: Reply with quote
MCN wrote:
... carb balance is next thing. If out as much as you say then the gauges will show what's what.
It's a GPZ, almost certainly balance out. Carbed Kwaks have weak springs holding the adjuster screws and seem to throw out the balance on a regular basis. I used to check (and adjust) the Zed at least twice a year!
Make mine a Corona.
andym
PostPosted: 07:54 - 17 Aug 2016    Post subject: Reply with quote
I had the same problem on the CBR, when I connected up the (homemade) manometer and started the bike all the 2 stroke oil was instantly sucked up by by the no. 4 carb.
If the GPZ 500 is anything like the 750, it should be a simple enough job to balance them.
Kozak
PostPosted: 16:20 - 20 Aug 2016    Post subject: Reply with quote
Just removed the carbs - taken out the battery overflow tube that sits between the battery and rear of airbox, removed the 2 bolts each side holding the air box in the frame which allows the box to move back a little and came off without too much trouble - found that the rubber flange connecting carbs to the engine was loose on No 2 - ? don't know if that was causing the problem (except an air/vacume leak I thought should make the mixture lean and run hot not cold?) - also remembered that I have some spare carbs and found 3 lots that look clean so will swap with one of these after a quick check and clean this one at my leisure.
Kozak
PostPosted: 21:51 - 21 Aug 2016    Post subject: Reply with quote
Sorted (for now) Thumbs Up
Combination of problems - the carb flange between engine and carbs was loose on No 2. Stripped and cleaned No 2 carb - the pilot jet was clean. Checked fuel level ans No 2 was too low, 11mm instead of 7mm like the rest so adjusted the float, and when all back on balanced the carbs and No 2 was way off, took almost a whole turn of the screw to balance. Short test run and runing smoother than ever, and No 2 pipe as hot as the rest.
The last post was made 10 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.71 - MySQL Queries: 13 - Page Size: 55.63 Kb
