Kawasaki KC100 Fuelling
eunos20b
PostPosted: 19:15 - 15 Aug 2016    Post subject: Kawasaki KC100 Fuelling Reply with quote
Hi all,
Got this bike about a month ago and have managed to recommission it as my first bike after being sat for 25 years. All has gone easy so far, happy days.
Haven't been out on it too much, took it twice down to MOT station which is 6 mile round trip. Anyway everytime I turned the fuel on, the bike would start first or second crank but would literally pour fuel out of the overflow hole underneath the engine. So I ripped the carb out and checked it all over. Carb was very clean inside and everything seems good. Whilst having it open I bent the tab on the float that touches the pin, in order to try and restrict the fuel flow just a tad. Have put it all back together and now the leak is totally gone - fuel goes through to carb but doesn't leak. But engine won't start at all now. Fuel on, fuel off, choke on, choke off, bit of throttle, nothing. Won't start. Any ideas? Bike definitely has ignition as lights come on and haven't messed with ignition at all.
Thanks
davebike
PostPosted: 07:46 - 16 Aug 2016    Post subject: Reply with quote
You need to set the float hight correctly the tab you bent adjust the fuel hight in the float chamber
No I don't know what it should be on that bike
Dave
NC750Xdct + others at work !
[email protected]
eunos20b
PostPosted: 09:31 - 17 Aug 2016    Post subject: Reply with quote
Cheers.
I took it apart again, bent the tab back just a little and found a sweet spot. Runs like a dream. Now to sort the knackered clutch...
The last post was made 10 years, 74 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 35.44 Kb
