Honda CG125 1982 6v to 12v conversion
Thoney
PostPosted: 12:06 - 17 Aug 2016    Post subject: Honda CG125 1982 6v to 12v conversion Reply with quote
HI all,
I have recently bought a 1982 Honda CG125 which has a 6V Battery, I want to do the conversion to 12V and It will be my first battery conversion, I was wondering if anyone could help me on this or put me in the right direction to someone who could?
thanks!!
Teflon-Mike
tl;dr
PostPosted: 14:48 - 17 Aug 2016    Post subject: Reply with quote
Search engine is your freind, this ghas been covered on a few occassions.
First question WHY do you wish to convert from 6v to 12v?
The electrics on little bikes tend to be pretty 'weak' regardless, and having more volts wont give you more 'power' to run such equipment as a higher wattage head-lamp or the charger for a GPS or smart-phone or anything.
Main advantages of converting an old bike to 12v is for 'compatability' 12v bulbs and stuff tend to be easier to come by and are often cheaper.... Though that's possibly something of a 'non-problem' with e-bay and so much now only a couple of clicks and a 2-day DHL jiffy-bag away... especially as you have so little electrical shit on an old bike to need many parts, and if it's in half decent shape to start with, shouldn't need much very often.....
Though living through the 6v electric and AC direct lighting era, I would reccomend buying a couple of headlamp bulbs and 1/4 dozen tails to keep in the tail, as they do seem to like to pop pretty readily.... more so if you try fitting higher wattage ones than the book says.
Other advantage is 'reliability'.. which most often translates as being able to neglect the maintenance....
12v electrics have twice the electrical 'pressure' between the battery terminals, so when you have a cruddy corroded up old switch or bullet connector or earth point, electric has more 'force' to push through the high resistance it offers.
BUT, 12v isn't the 'solution' to that problem... the solution is to clean the contacts in the switches or in the bullet connectors or earth points, to get rid of the corrosion making them high resistance, and to make sure the rubber insulation around them letting moisture in, is 'good' and giving them all a good dosing of WD40 used for its intended purpose as a 'water-dispersant', to keep it at bay, and let the electric get through under the pressure it has at 6v as it should.
If you try and ignore that 'root-cause', then even if you convert to 12v, the problem will still be there, and switches and contacts will remain a 'bit iffy' and unreliable.
Most oft suggested reason for wanting to go 12v though is for better lights..... which a 12v conversion on its own will NOT offer.
Brightness of a headlamp bulb is dependant on the power rating, the wattage. so if you want to fit a brighter, higher wattage headlamp bulb, you need more POWER to make it light, not just more volts.
Generator only chucks out so much electric 'power', so if you want to use more for the headlamp, then you need a generator that will deliver it..... find it else where.... sharing out what you got less equally to give the lamp the lion share.
Little bikes like the CG, though don't have very much electrical equipment, and certainly noting that's likely to be drawing many amps at the same time as the head-lamp all that often, you can steal watts from..... say fitting lower wattage indicator bulbs or even lower LED indicator bulbs to free up some amps for the head-lamp.
Other issue with the 6v CG and even most of the 12v ones, is that they have AC-direct head-lamps; they are powered directly of unrectified, unregulated electric straight from the generator... they are only notionally rated at 6v, the generator delivering a varying voltage 'wave' with peak's of anything from 6 to maybe 16v depending on the engine revs.
It's actually a very 'efficient' little system... it's just not very powerful!
And trying to convert to 12v regulated DC current taken from the generator through a regulator/rectifier to a battery to stabilise it at a constant 12v, can actually see you get less from it, depending how its done.
Standard 6v system, where it takes electric from the generator to charge your 6v battery, to charge the battery, actually uses a very crude 'half wave' rectifier called a zenner diode. This lets +volts through but blocks -Volts, so it only takes the positive hump of the wave supplied by the generator, about half the 'power' the generator may be making....
Using a more sophisticated 'full-wave' rectifier that uses four diodes in a bridge circuit, so that the out-put pins get positive volts, regardless of which way the input is pointing, will get you more of the power the generator is making, less an efficiency loss AC direct to the head-lamps just doesn't have....
Is possible though to use a now, reasonably 'cheap' four or five 'pin' 12v rectifier to charge a 12v battery off a notionally 6v generator..... remember, that AC generator will deliver anything from perhaps 3-4v at a lumpty tick-over up to perhaps 14-16v when revved....
BUT you will never get more power OUT than the genny can put IN, so you will still have a limited number of watts to point at a head-lamp, and if you want to run anything more than the stock 35W or so bulb, you will probably still be struggling.
I have done it to an old, small, points ignition Yamaha engine, using a £10 four-pin Pit-Bike regulator, using the 'standard' 6v generator.... BUT still didn't have the 'power' to light up anything more than the standard 35w head-lamp bulb.....
& it was FAR from a cheap or easy conversion, after buying all new 12v equipment, from the battery through to the horn and all the little bulbs behind the speedo, as well as indicators and indicator flasher etc etc.
I also 'robbed' a lot of watts from that equipment using a chrystal times transistorised 'electronic' indicator flasher to be able to use LED indicator bulbs without loosing the benefit of thier low wattage, using 'ballast resistors' to load them back up the same as a conventional bulb to make them flash at the right rate.....
And the initiative for 12v conversion wasn't to get better lights, as to be able to run a GPS (as opposed to Sat-Nav) for Green-Lane orienteering on the thing.
With 12v on the bike, though did allow me to tackle the head-lamp issue with a more efficient HID head-lamp, that's about 10x as bright as a tungsten bulb for about half the watts, and only draws 35, the same as stock 6v....
BUT, whilst that is about as good as you can get, and conveniently with limited electrical power.... it's another convoluted conversion; and to use an HID you need to have a head-lamp which will take an available HID bulb fitment.... 6v bayonet bulbs tend not to be compatible, begging a more modern 'H' type fitment for 12v halogen bulbs. Depending on the HID arrangement, you may also need to use a 'corrected' HID bulb to get it to dip properly, and or an HID compatible lens/reflector in the head-lamp.... all of which to do the job properly, as in it actually works, and works as it should and better still doesn't annoy the MOT man, tends to preclude the cheaper 'systems' found on e-bay... of which the cheapest are only HID on 'full-beam' and have a tungsten element for dip, which used most, means they afren't actually all that much of a bonus very often!
HOWEVER... cutting through all of them permutations in the 'plan'.....
Back to basics.... and old rule of proddy racing, before looking for MORE than 'standard' make sure you have all you should AS standard......
IF you tackle a 6v system at source; and do all the basic grunt niggly neglected maintenance, and spend time cleaning contacts and corrosion, replacing wires that have gone black and horrible and the insulation started to go hard and crumbly, and get the full 6v flowing round the system as it ought to... replacing previouse owners 'ideas' that a 45w bulb MUST be brighter than a standard 25W one, and making sure that the tail lamp is actually a 6v one, and rated at wattages in the book, and not a 12v car tail lamp bulb bought at a petrol station and chucked in as a get-me home fix at some point, and never changed, cos it never blew again.....
Tackling the issues at source... you are likely to get as much or more from the 6v system than you would trying to bastardise it with a 'modernisation'...
Like I said, these days availability of even relatively uncommon components is so good it is far from the issue it was in years past; whilst making the wires good and getting all the volts you got through them will eradicate more intermittent and or annoying electrical issues than upping the volts...
AND that head-lamp.. with the correct bulb in it, getting all teh volts it shouls, will deliver a lot more light.....
And if THAT isn't enough.... look at the lens and the reflector!
Usually on older bikes tarnished in the reflector that has probably lost a lot of its silvering so is probably not chucking half the light the bulb makes at the lens, which old yellowed and etched with however many years of grime, probably doesn't let half of it through anyway!
Up-rate the electrics and lamps as much as you like.... but with cruddy old lamp unit, only letting 1/4 of it out, you'll need 4x as powerful a bulb, JUST to get as much as you should have!
Exhaustive effing about with bike lamps over the years, has proved to me, that if the lamp's 'weak' to look at the lamp, not the bulb, and clean or replace the damn thing, depending on how dire it is.
And new, good quality, not after-market patern get me through an MOT bit of shit (of which I have more than I would like cluttering up the shed!!!) will give you far more of what you really want, and far more easily than trying to get clever with an 'upgrade' or mod. likely to make more problems than it solves!
KISS IT.. Keep It Simple - keep it STADARD.... its a good moto...
If you have to go away from standard, make sure the reasons are sound, and the plan to do it 'reasonable' and with a better than good chance of actually delivering what you hope it will.
CG, is enticing in later models, and Chinese derivatives having 12v electrical systems, and suggestion that pillaging parts from an MOT failed chink 'might' offer cheap and easy convcersion...
It does... but reality is that there are enough differences in the systems to make it a mine field, where you ARE likely to make more problems than you solve.
Which brings me back to the top... and WHY do you want to convert to 12v?
An un-molested 6v CG retains the virtues of simplicity; trying to bastardise that, and fit some sort of hybridises electrical system on it, that isn't anything like the Paynes Manual depicts, could be chucking the baby out with the bath-water.....
you could get more of what you actually hope for simply overhauling the 6v system and making sure you have all you should as standard.
And avoiding the 'problem' of not being able to charge your smart 'phone on it, by not being a slave to it every time it bongs with a twitter tweet or whatever, and using a far more reliable way of navigating than its Sat-Nav-Ap... called paper MAPS, and street-signs and such! Worked for a century before Smart-Phones came along!
smallfrowne
PostPosted: 15:02 - 17 Aug 2016    Post subject: Reply with quote
I fitted a CDI stator to mine, along with a matching cdi and ignition coil. The genny cover no longer fits as it won't go over the new pick up for the cdi, so got a CDI genny cover for it too. 12v rectifier in place of the resistor that lives on the lower fork yoke. You'll need a 4 wire rectifier if I remember rightly. The old diode that lives next to the battery is no longer connected to anything. 12v battery obviously, bulbs, switch gear is fine, left the 6v horn as it is used so rarely and is now insanely loud and annoying.
Can't remember too many specifics as it was done a while ago and sort of bodged together over a period of months, some of which was spent running at 9v using the new stator with 6v gear. Lights were fantastic for a couple of months at least.
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
Pjay
PostPosted: 15:39 - 17 Aug 2016    Post subject: Reply with quote
Come now Tef, you do spout some tosh sometimes, but that is among the most tosh you've ever spouted [spout.gif].
A sat nav on a bike vs paper maps on a bike is a no-brainer, stop being ridiculous. The reason sat navs took off so well, is because they are far superior to paper maps. Not only because you dont even need to look at them. I bluetooth my phone to my earpiece and listen to the commands.
Stopping and checking maps is a royal pain in the anus in the sunshine, let alone when its wet and windy.
MCN
PostPosted: 16:09 - 17 Aug 2016    Post subject: Reply with quote
Small problem. Big Post.
Very Happy
Teflon-Mike
tl;dr
PostPosted: 17:17 - 18 Aug 2016    Post subject: Reply with quote
If I wanted an annoying woman to tell me what to do, I wouldn't have spent so much fucking money on a divorce!!!
Amazingly people managed to get places they hadn't been before, before the advent of Sat-Nav or smart-phones, and did so quite happily without getting tangled in wires, or driving into rivers and the like, 'cos the widget told them to!
I am not and will not be a slave to a Sat-Nav let alone a second rate smart-phone Sat-Nav 'ap', and be at the mercy of its questionable data-bases and even more questionable rout-planning!
I have proved how unreliable Smart-Phone aps and propriety Sat-Nav units are time over time over time, even 'good' and I mean far superior Global-Positioning from a 12 or 16 channel marine/aviation Receiver is far from 'infallible' in real world ground conditions, where they can loose line of sight signal between hills or buildings, or suffer interference from signal 'scatter' particularly in the city.
Linked to high resolution, high data mapping, and only providing cross-hair location, not trying to offer routing guidance, even e-mapping is much more reliable, still able to see the 'map' and calculate position by land-marks and dead reckoning if needs be.... AND you can choose where to go, and often down routes that simply are NOT IN proprietry sat nave or sat-nav ap data-bases, or blocked because of 'idiot liability' issues.... at least as long as the batteries last and the wires don't get tangled....
Which a trusty Ordinance survey map, if you know how to work one properly... and its not exactly brain surgery to learn how to fold one and use the 'key'! Then does the same job, without the electrickery.
But hey... if you don't want the expense of marriage to have a nagging woman tell you where to go, and prefer being tied up in electrical wires and audio cables than emotional strings... Yeah... fantastic invention, and compared to the cost of divorce fantastic fucking value for money!
STILL not exactly essential, and still no more than moderately useful for finding places you may want to go though.....
Pjay
PostPosted: 17:45 - 18 Aug 2016    Post subject: Reply with quote
Teflon-Mike wrote:
Stuff
You do realise that for every moron that gets guided into a river, there are millions of people using satnavs to escape traffic jams and get to their destination with minimal effort or planning?
Progress Tef, Progress.
By your logic, we should never have evolved from fish. We all done fine then, no worries about driving into rivers, or even wondering where we were going, let alone what time it would be when we arrived.
Teflon-Mike
tl;dr
PostPosted: 20:16 - 18 Aug 2016    Post subject: Reply with quote
Yup, well, that was what they called it when they invented the factory, and the rail-way, the telegraph the machine gun and the 'production line'
Charlie Chaplin parodied the fordist/industrialist ideas of 'Progress' in a film called 'Modern times' in 1936, almost a full century ago, in which he demonstrated with ironic slap-stick how 'Progress' made men slaves to the machine, rather than the other way around.....
I wonder what he'd make of the Sat-Nav?
'Progress' making us slaves to the machine to make ever more incredible machines to be slaves to...... Dumbing down to the lowest common denominator; you don't have to think for yourself just do as the machine tells you.... It may be 'progress' as we have come, in the industrial era, to know it..... Doesn't mean we need to blindly do as we are told, not thinking for ourselves and buy into the consumerist bullshit we 'have' to use it, its the 'ONLY' way to do things....
Especially on an antique motorbike, built before they were even imagined, that has got folk places quite happily without one all this time; and less, doing just a little thinking for ourselves and applying a little common sense; we certainly don't need to buy problems to try and adopt this 'progress' trying to make one work on an old motorbike to which it is not particularly compatible....
While if one is so 'unconventional' that they wish to shun the common car, rebelling against the 'system' choosing to ride a motorbike; more shun pre-packaged consumerist imperatives to buy the newest latest bestest motorbike with all the 'must have' wistles and bells fitted as standard in the Modern-Times manufactury, buying an old charming 'classic' one...
WHY would you suddenly have a qualm of conscience about being a conformist and HAVE to use a fucking smart-phone sat-nav ap to be told where to fucking go on it!?!?!?
Any-one can be a rebel these days so long as they wear the right uniform to display which brand of non-conformity they conform to, it seems..... But sod the sociology... as an engineer... DOES IT WORK?
My experience of smart-Phone sat-nav aps is pretty dire... and NO! they do not.
Year or so back up on the Derby moors, a place progress seems to have utterly escaped since Putting match to powder keg that started the industrial revolution quarter millenia ago, with the first mills in Derwent Valley, and discovering that the Pub with a 'Good Pub Grub' sign and menu outside actually DIDN'T serve dinner; I allowed my daughter to direct us via I-phone to the nearest McDonalds... or chippy, or heaven forbid, KFC! an hour later, after passing the same derelict Chinese resturant the Pub Land-Lord had directed us to for the third time... and she moaned in frustration to "Just be patient! I'm waiting for signal!"; I dumped her at the road-side with our Snowie to wait for it, whilst I went to find a petrol station and some Celophane sarnies, with no navigational aids beyond the setting sun... to return 40 minutes later, and ask if she had signal yet to the reply... "Yeah... sort of... just before the battery went!"
J-U-P
Another occasion has seen me watch Snowie throwing a frustrated tantrum out-side some-ones front garden, jumping up and down on the spot, shaking her smart-phone yelling "But IT says that its HERE! It MUST be here, somewhere!".. when she wanted a cash point.... that she had visited a hundred times, and was actually 100 yards away on the next parallel street!
Meanwhile an auntie who knows this county like the back of her hand, and until ten years ago, would suddenly cut off the main road and dart down obscure back-lanes, 'to avoid the school' (or whatever) when she's seen the clock... called me to check I was 'in' and tell me she'd be popping over shortly.... she lives fifteen miles away, it should have taken her no more than half an hour.... FOUR HOURS later, she arrived, after half a dozen 'phone calls to tell me she was still on her way... asking how she got here she grimaced.... "The WOMAN! she shreeeked... she kept telling me to get back on the motorway!!!!" she had apparently been given a new company car and introduced to this progress of 'Sat-Nav' and all of a suddeen utterly lost all her prior geographic knowledge, common sense and freedom of choice.. and HAD to do what the woman told her!!!
Meanwhile, I have had sat-nav running on-route on countless occasions; its always been quite entertaining comparing its orders to my own local knowledge.
And for the most part 90% of its instructions are uttery unnecessary. I do NOT need it to tell me, turn by turn how to get to the middle of town, less to tell me to go to the middle of town to get on the main-road to go to the by-pass to get to the motorway, when I can cut round the houses......
I don't need or want it telling me 'Of Rawt' in mid-atlantic drawl every time I pull into a petrol services along the way, or follow a marked road-works diversion.
The ONLY time it is of any actual 'use' is the last mile or so of any 'new' journey, from the main road that's got me close to destination, round the houses to the actual address....
And the number of times; after following Sat-Nav instructions for those last few hundred round the houses yards, some-one elses local knowledge or a look on a map has revealed a 'simpler' route, is remarkably often.
YEAH... people use it.. many quite contentedly and hapily and without apparent problem, and they probably believe its a great 'thing'.....
That does not make it unequivocally so., and it STILL does not make it an essential device you MUST have on a fucking motorbike!
This is not simple Luddite bigotry, this is practical, think for yourself fucking common sense!
They are NOT essential, they are no where near as 'useful' as they appear, and reliance on the damn things to the exclusion of all else, is where being ridiculous lies, as they are simply NOT that reliable.
Darwinian analogies of evolutionary improvement of the species, via beneficial mutation, really, REALLY don't apply....
Pjay
PostPosted: 20:21 - 18 Aug 2016    Post subject: Reply with quote
You're just shit at Sat Navs.
Besides, the poor guy just wants to buy readily available bulbs fs.
MCN
PostPosted: 17:26 - 19 Aug 2016    Post subject: Reply with quote
Your shit at not baiting The Tef. Smile
Pjay
PostPosted: 23:19 - 19 Aug 2016    Post subject: Reply with quote
It's what he lives for.
PostPosted: 23:33 - 19 Aug 2016    Post subject: Reply with quote
I've got OS maps on my phone. Wink
Yes there are times when a big OS Landranger map or such like is useful but for everything else, Google Maps navigation is excellent.
Of course, if you've got a potato GPS on a potato phone then your experience will be bad.
RhynoCZ
PostPosted: 23:48 - 19 Aug 2016    Post subject: Reply with quote
Getting lost is a part of the fun. Thumbs Up Razz
EDIT: Getting lost with nearly empty tank is not fun at all, though. Thinking
MCN
PostPosted: 16:43 - 20 Aug 2016    Post subject: Reply with quote
My satnav tells me when I'm low on fuel. Thumbs Up
Tells me where the nearest petrol stn. is. Thumbs Up
I just need to navigate to it. Shocked
The last post was made 10 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 107.24 Kb
