Battery voltage query
Groove
PostPosted: 15:30 - 17 Aug 2016    Post subject: Battery voltage query Reply with quote
Gsxr 600 k1. Wasn't charging it's battery. Stator was at fault (not getting any real ac voltage from it.
New stator now working fine.
Voltages in the battery reading 13.8 at about 6k revs. Raising from about 13.3 at idle.
This doesn't sound enough to me and feel I should get a new reg/rec (google says around 14.6 under load).
So is it enough or too low?
MCN
PostPosted: 15:42 - 17 Aug 2016    Post subject: Reply with quote
If you put the main beam the heated rear window and press the brake what does it show?
It may only pump the juice in if there is load.
It would be handy to connect an ammeter in line to see how much amps the system is drawing. Loaded and no load.
Editeded :
https://www.w8ji.com/battery_and_charging_system.htm
PostPosted: 18:52 - 17 Aug 2016    Post subject: Reply with quote
As above and note that reg/recs can sometimes work and sometimes don't.
I thought it not possible but have ridden with a plug in voltage meter and after a while it would stop working until the bike had been switched off/on again then it'd work for a while then crap out again.
Wasn't a mosfet one which I understand have an improved switching system.
Groove
PostPosted: 20:33 - 17 Aug 2016    Post subject: Reply with quote
Well it's the track bike so only light is the rear light and clocks.
I will check out if there's a drain on the electrics though.
MCN
PostPosted: 14:49 - 18 Aug 2016    Post subject: Reply with quote
Possibly regulator Smile
Cosmik de Bris
PostPosted: 04:45 - 19 Aug 2016    Post subject: Re: Battery voltage query Reply with quote
Yeah, does sound low to me. 13.6 is about the lowest it should be I think but more like 14 - 14.5 I would think.
The last post was made 10 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 50.77 Kb
