YZF600R Thundercat Service - All at once or maybe in stages.
T1Cybernetic
PostPosted: 20:54 - 17 Aug 2016    Post subject: YZF600R Thundercat Service - All at once or maybe in stages. Reply with quote
I always do my own service on my cars Wink Easy enough most times (Excluding a stuck bolt or two)
Anyway I plan to do my own service on the bike but what's it like? Easy or hard on a Thundercat? I would imagine it's not too different on any bike really.
On a separate note - My water is horrible looking brown /almost rusty looking. Is it something to worry about? I'll hopefully change it tomorrow Very Happy and give it a clean through with the hose if that's ok?
And last but not least, What should I put on my shopping list? Coolant first Wink but what do you lot use? or recommend?
Signature removed by popular demand...
Hong Kong Phooey
PostPosted: 00:29 - 18 Aug 2016    Post subject: Reply with quote
Getting fairings off and on can be a pain in the arse, so you might want to just do it all in one go. Be prepared to order new fasteners from ebay etc.
Once you start you'll probably find other jobs need tending to.
If it's your first time then use a Haynes manual, otherwise there's probably a Yamaha manual knocking about for download.
Rusty water means it's probably been neglected. Change it, preferably flush through. Check coolant spec for your bike, I used Prestone ready mixed in my CBR - apparently it's compatible.
strikeforce
PostPosted: 00:36 - 18 Aug 2016    Post subject: Reply with quote
Do it all in a 1er
Did my r6 the other day, sparkies, oil + filter, air filter, coolant flush and new fluid.
Even cleaned up the header pipes whilst all the fairings were off. Not hard to do really and i enjoy knowing its been done.
Yzf-r6 5sl
Msx-f
J.M.
PostPosted: 01:51 - 18 Aug 2016    Post subject: Reply with quote
The biggest pain about servicing the Thundercat is if you need to remove the carbs to do the valve clearances; the screws are really awkward to access, and you need a long allen key really.
On mine, a fair few of the fairing bolts had seized to their fasteners. That's a 1-time annoyance to deal with if you replace the offending bolts, but hopefully one that won't really affect anything.
Overall it's not too bad.
2004 R1 & 2018 XSR900
T1Cybernetic
PostPosted: 07:21 - 18 Aug 2016    Post subject: Reply with quote
Yeah I figured it had been neglected too Sad The book says I need 50/50 distilled water and 50% corrosion inhibited ethylene glycol anti-freeze.
I normally use euro car parts (red/Pink) stuff in the car Triple QX Red.
From a quick google should be fine but I thought I would ask first Very Happy I don't want to break anything.
iwaldo
PostPosted: 08:03 - 18 Aug 2016    Post subject: Reply with quote
I just used premixed Halfords own coolant on mine, works fine Smile
MT-09 / YZF600R Thundercat '02
yen_powell
PostPosted: 08:34 - 18 Aug 2016    Post subject: Re: YZF600R Thundercat Service - All at once or maybe in sta Reply with quote
I had this, turned out to be a kidney stone.
(If you are going to do servicing bit by bit, match up the stuff that you will access each time even if it isn't due. For instance if you are doing the valves, do the plugs and air filter at the same time as you'll have all the bodywork off anyway.)
XT1200Z and a DR350 in bits
pompousporcup...
PostPosted: 08:44 - 18 Aug 2016    Post subject: Reply with quote
as already posted, do it all at once. the fairing is alright to get off imo (bar a couple of mullered allen heads) but an absolute bitch to get everything to line up again..new fastener kit can be had off ebay
https://www.ebay.co.uk/itm/YAMAHA-YZF600R-THUNDERCAT-1998-YZF-600-R-STAINLESS-STEEL-FAIRING-BOLTS-/161582271889?hash=item259f0dcd91:g:GE4AAOSwm8VUzfNH
OR below as you may need to metal clips.. i couldnt be arsed to source it cheaper
https://www.ebay.co.uk/itm/Yamaha-Thundercat-YZF600R-Full-Stainless-Steel-Fairing-Screen-Bolt-Clips-Bolts-/131050000301?hash=item1e83304fad:g:Z2YAAOSwdrRXG6YO
Wemoto for oil and filter, air filter and plugs works out pretty good value.
I use the blue triple QX premixed coolant from eurocarparts.. £6 for 5L you can't really go wrong Thumbs Up there are two 10mm bolts on the front of the block for draining.. use a smaller bucket or a bit of card to direct the flow of coolant coming out as its difficult to get a bucket where it needs to be... the pipes are in the way and the coolant flies out, hits the pipe and goes everywhere.
whilst you're at it, get the sprocket cover off and clean the inner side of that off. you'd be surprised how much crud collects there
T1Cybernetic
PostPosted: 11:18 - 18 Aug 2016    Post subject: Reply with quote
Nice one cheers Wink And those fixings will definitely come in handy!
To be fair I only want to do the water first as like above it looks like an after thought and seems neglected so it really does need doing. The old owner said it's not due a service until after November and as it runs perfectly fine we didn't go into specifics.
The oil and brake fluid and pads all look good Wink I haven't checked filters or plugs but I will mull it over today! We have space to tear the bike down and it gives me an excuse to tinker Very Happy So doing it all at once is preferred even by myself, But I do love to tinker Razz
Do any of you know where to get bike parts near south kirkby WF9 area Very Happy
weasley
PostPosted: 12:27 - 18 Aug 2016    Post subject: Reply with quote
This - plus you can check that the sprocket nut is tight, as they have been known to unwind themselves if not installed properly.
On mine the worst fairing bolt is the one right at the back, underneath, that holds the two sides together in front of the rear wheel. Last time I worked on it I couldn't undo it, but still managed to get the fairing spread apart enough to drop it out of the way.
Classic areas of service/upgrade are:
- fork oil; some use heavier oil (7.5W or 10W)
- fork springs - the standard ones can be a bit soft
- brakes - they work very well if you stay on top of keeping them cleaned and freed-up
- downpipes; everyone will tell you the OEM ones rot away. I put stainless on mine but the OEM ones were surprisingly sound
- carb balancing
- rear shock rebuild/replacement
Mine has been bulletproof for 14 years, with only one small issue in that time.
el_oso
PostPosted: 15:49 - 18 Aug 2016    Post subject: Reply with quote
depends on what you want doing.
I recently sold mine and had done over 70k miles on it.
Getting the carbs off is a pain in the backside. The allen keys are really awkward.
blue spot callipers seized frequently and really are not easy to re-bleed if you take the pistons out to clean.
Suspension is really soft, both front and rear.
Duke 390
Car: Jeep Wrangler 4.0L
The last post was made 10 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 73.2 Kb
