Valve guides
scotto75
PostPosted: 10:15 - 18 Aug 2016    Post subject: Valve guides Reply with quote
Hi everyone,
I've got oil getting in my cylinder barrel of my CG125 causing lots of blue smoke on start up, so I have assumed it is coming from above. The compression is in the high 190's, just slightly over 200psi with a bit of oil in, so I feel the piston rings are okay.
I've replaced the exhaust valve stem seal, but it's still burning oil. It stops after the bike has been ridden for a period, but leave the bike overnight, and it's smokey again on startup.
I understand that replacing valve guides involves removing the cylinder head and getting an engine shop to do a pro job.
My questions are....
1 - is it worth getting the valve seats done and replacing the valves and seats, piston rings, etc at the same time?
2 - if so, is it not quicker and cheaper just to buy a replacement cylinder head and piston kit?
Any advice will be greatly received!
PostPosted: 11:04 - 18 Aug 2016    Post subject: Reply with quote
I'd be costing a complete copy-engine from a Chinese bike.
Try searching for 156FMI or 157FMI, although you will need to check that it's a CG copy as that code can also apply to Suzuki copy-engines.
PostPosted: 11:56 - 18 Aug 2016    Post subject: Reply with quote
I wonder if that's it.
I normally associate leaking valve stems with smoke on the overrun (so when you wind off the throttle after a period of being on the power). Probably getting worse with use rather than better as the oil thins.
Is it actually using oil?
An oil control ring can be cracked with no significat loss in compression.
scotto75
PostPosted: 13:20 - 18 Aug 2016    Post subject: Reply with quote
It's hard to say exactly, without getting someone to follow me watching when it happens, but its's usually worse when I change gear, so releasing the throttle, and pulling away from idle. The second half of my morning journey is on a dual carriageway, an it does feel like it eases a little after this.
I filled it up a week ago and had to put almost 300ml in this morning, so it's using a fair amount as the CG only holds a litre anyway.
PostPosted: 14:11 - 18 Aug 2016    Post subject: Reply with quote
Well. If you take the head off, I'd have a good look at the rings too.
I'd imagine a new set of valve guides would be pretty cheap.
Valves themselves are upwards of £20 each.
Valve guides are £17 each.
You can fit and remove them at home by heating the head in the oven and drifting the old ones out. The new ones can be fitted by freezing the guides and heating the head then drifting them in. You need to make a drift out of something soft (aluminium, hardwood) that's slightly smaller than the overall OD of the guide with a hole u the middle that the body of the guide can fit into.
Many people would take it to a machine shop and get them to press it in.
All the above said. You can get a pattern head on ebay for as little as £40 delivered. You'd need to swap your valve gear across and lap in the valves.
scotto75
PostPosted: 22:34 - 18 Aug 2016    Post subject: Reply with quote
Thanks stink wheel. As you say, a pair of valves and guides will be £40, but for £60 I can get a new head off eBay with the valves and springs already fitted. A set of rings will be another £20, but for £40 I can get a new cylinder and piston kit.
Don't really want to spend £100 on parts and then have the bike out of action for a few days, but I'm guessing it would cost more to have a mechanic do the work.
It needs to get done as I'm not happy cruising about in a cloud of blue smoke or running with only two thirds oil.
scotto75
PostPosted: 23:02 - 18 Aug 2016    Post subject: Reply with quote
I guess I could give fitting a set of guides a go myself, but always thought it safer to let an experienced professional do any head work. Do you think it's an easy enough job to be able to diy at home or just easier to pay the extra £20 for a head with valves already fitted?
PostPosted: 00:14 - 19 Aug 2016    Post subject: Reply with quote
I would personally fit the valve guides on the basis that they are honda parts.
I'm a bit contrary that way though and there's definately more than £20 of work in the job.
Teflon-Mike
tl;dr
PostPosted: 00:35 - 19 Aug 2016    Post subject: Reply with quote
NO. its not an easy job to fit valve guides they usually have to be accurately mileld out, and new ones shrink fitted in.
Usually cheaper to replace the head than have new guides shrunk in on a small jap; and on a CG with so many chinky copy bits, so cheap, I doubt you'll find any-one to salvage the original for less.
(I'm surprised Honda even list them as a service replaceable part, usually they don't, they expect the whole head to be swapped.)
While motor is in bits, again, usually cheaper to use a cheap Chinky copy cylinder & piston kit than get the original rebored & buy over-size piston to suit.
For the time/cost/hassle of pulling the motor to bits to do one, you may as well do both and be done.....
However... my mind is still quizzed at the notion you suggest you have managed to replace the valve stem seals or at least one of them, WITHOUT having the head off and the valves out to do it....
Which offers ponder point that actually you haven't, or haven't replaced it properly.. and as the more common port of entry for blue smoke... good chance that trying to fix a stem seal without removing and stripping the head, you have as like as not caused the smoke-screen, and may not need either new cylinder head, valve guides, piston rings or cylinder.. just to pull the head off and do stem seals proppa, after popping teh valves to do'em...
As to notions of DIY vs paid mechanic; CG motor is fairly 'freindly'; if you have all the parts and gaskets and tools ready to hand, no reason why you shouldn't pull the head and swap out anything and everything from the base gasket up, in a week-end, following the Haynes book of Laughs diligently and methodically; but if you aren't so spanner savvy, and dont have a particularly extensive tool kit, and dont have such specialist tools as a low range torque wrench, or valve spring compressor, it could be a piece of string job, waiting on tools of e-bay or tracking down loaners.
One thing on these or any other small honda with screw and lock-nut tappets that need pretty frequent adjustment, i would say is an invaluable investment is the official Honda tappet adjusting tool and lock-nut spanner; available from Dave silver's spares for about £20, they save a hell of a lot of swearing with diddy ring spanner and 'something' usually an over size monkey-wrench on the 'square' head of the tappet, chewing it up....
Paid Mechanic? at £30 an hour; with all the bits and the tools; you are probably looking at maybe five or six hours labour on the motor, if you gave it them loose... give them the whole bike? And risk of siezed exhaust studs, rotten headers, or other 'associated' hassle on thier way to getting at the engine.... job could mushroom from a £150 one to 'Scrap it mate, its not worth doing"..
Personally, I would be inclined to do it DIY with new head and cylinder, following the book, to know 'whatever' is wrong is sorted, and done proppa and done once, shouldn't need looking at again for a long while;
BUT, I would be presuming on the laws of sod, and finding un-anticipated hassles and niggles some-where along the way; and even though there's a chance I could roll it in the shed on a Friday after-noon and ride it out again on Monday morning..... I'd be quizzing collegues whether any one could give me a lift in for the week, or checking bus time tables, and other alternatives; and not presuming all will go as hoped with no inconvenience or hassle.. it rarely does, and laws of sod sat even more so if you are banking on using it to get to work on Monday!
davebike
PostPosted: 08:06 - 19 Aug 2016    Post subject: Reply with quote
Honda don't list them as a separate part and I not surprised most modern engines have them cast into the head most have flanges inside the head to keep them in place replacing would be a major machining job
I say if you replaced the guide seals you have a worn out or damaged oil control ring or rings
There are poor quality valve guide seals out there and poor quality rings but not so common
Dave
NC750Xdct + others at work !
[email protected]
PostPosted: 10:11 - 19 Aug 2016    Post subject: Reply with quote
Yes they do.
For example.
12021107310
Nobby the Bastard
Harley Gaydar
PostPosted: 16:40 - 19 Aug 2016    Post subject: Reply with quote
I thought that they can generally be pressed in and out.
When my (original) exup engine was being stripped, my mechanic checked the valve guides for wear, having said it was't a problem to replacement if they were. As it happes they were fine.
Triumph Sprint ST 1050
scotto75
PostPosted: 22:22 - 19 Aug 2016    Post subject: Reply with quote
Thanks for all the replies. If changing the exhaust stem seal hasn't done the job, I too am inclined to fit a new cylinder and head to have peace of mind.
I'm afraid I could do with a bit of clarification regarding this bit though...
I'm sure you're not saying that I haven't replaced the exhaust stem seal, or that I have caused the blue smoke and oil loss by incorrectly fitting the stem seal. Without getting all chicken and egg, the smoke and oil loss was definitely there before as it is the reason why I decided to buy and fit a new seal. Unfortunately, after fitting, the smoke and oil loss are exactly the same. Changing the seal appears to have done nothing to improve, or worsen, the problem.
Please could you explain further why it would not be possible for me to properly fit the stem seal without splitting the head.
The process I followed was this...
1 - removed rocker assembly
2 - compressed spring
3 - removed collets
4 - removed inner and outer springs
5 - removed stem seal
6 - fitted new stem seal.
https://i951.photobucket.com/albums/ad355/scottfury/Photo%2017-08-2016%2013%2032%2013.jpg
It would be a great help if I've missed something. Many thanks.
Teflon-Mike
tl;dr
PostPosted: 00:22 - 20 Aug 2016    Post subject: Reply with quote
Err.. well that's a first...
USUALLY you would have to have the head 'off' to get at and hold the valve against the seat to be able to compress the valve spring to be able to remove collets and spring and get at the top of the guide and seal... and not have the valve drop into the pot, or ding the soft alloy of the piston.
And I have seen valve stem seals fitted in two halves, super-glued together and to the valve guide, presumably fed in through teh coils of the spring, amongst the myriad bodges I have ever had the misfortune to discover.. human ingeniosity being seemingly limitless.
But Oh-Kay... you managed to get a new seal on the stem without lifting the head.... implications on the piston crown are probably redundant; if it's still burning oil, then the tops got to come off, and in bigger scheme, whether rings or guides, while apart you might as well do the lot, and it will be of little import.
Just don't bet on doing it all in one week-end and being able to ride it to work Monday morning.
scotto75
PostPosted: 14:13 - 20 Aug 2016    Post subject: Reply with quote
No. I'm definitely one who is controlled by the Law of Sod. Plus any new purchases will have to wait until the end of the month. I have already organised lifts to work for the meantime.
https://i951.photobucket.com/albums/ad355/scottfury/Photo%2020-08-2016%2012%2024%2015.jpg
As much as fitting a new cylinder and head makes a lot of sense, it seems I still wouldn't have satisfied my curiosity as to the source of the oil loss and smoke. I've stripped the top end down and would like to investigate the parts before replacing. Do you have any thoughts how I can diagnose whether the guides are worn or the piston rings are knackered? I guess with the head off I can pour a little petrol in and see if the valves leak at all?
https://i951.photobucket.com/albums/ad355/scottfury/Photo%2020-08-2016%2011%2059%2009.jpg
The piston's obviously had a rough time and the oil control ring is gunked up and doesn't move. Is a compression/leak down test the only sure way I can check rings for leaks, or by the look of all the deposits, would it be a safe assumption that this was past it's best?
https://i951.photobucket.com/albums/ad355/scottfury/Photo%2020-08-2016%2012%2003%2021.jpg
I'd also really appreciate some thoughts on the state of the cylinder. There are lots of very feint lines, but no real scoring that I can feel with my fingers. Thanks.
Teflon-Mike
tl;dr
PostPosted: 15:19 - 20 Aug 2016    Post subject: Reply with quote
That's past its best!
Gunked up oil control ring, would be prime-suspect for the blue-gugg effect... BUT, as so many things, it's rarely a singular protagonist but a conspiracy of'em.
Bore will tend to only get scored when the cylinder is so worn out that the rings can pop out the piston & break up & snag, or the motor has siezed and the rings have snagged after being smeared in the piston grooves.
The 'wear' pattern tends to be that from new; metal rubbing on metal, will tend to make the gaps between bits grow, and grow fairly evenly. After initial bedding in, the motor will 'loosen up' and the rate of wear will be fairly constant and apparently negligible; as it adds up though, it will start to accelerate as the piston rings, designed specifically for this, made of springie iron, 'expand' in the grooves to fill the gap as it grows.
Towards the end of service life; a lot of ring is poking out of the piston grooves and less is filling the groove; so they start to loose thier sealing efficiency, and you start to get increased oil-blow by.. but even then, it can be fairly insignificant, for a fair while.
But, it marks the onset of a period of accelerated wear; where with larger clerances, and less sealing efficiency, blow by reducing the amount of lube between cylinder wall and rings, the bore wears out that much faster, and the cycle adds to the causes making it wear faster still.
By the looks sounds that is probably about where you is at!
Bore is beyond service limits and wearing at a quicker rate; piston rings are struggling hence blow-by & gumming of the scraper ring.
Guides? Heh-mu-fug.
New seal on the top, you probably aren't sucking much if any oil down the pipe.... BUT... motor had been run hard enough and long enough to see bore ready for a rebore... how far behind the cylinder wall will the valve guide, and valve seats be?
As mentioned; put to a paid mechanic, 'cost' in the job would be taking bits to pieces and putting them back together again, at £30-60 an hour... in that, £30 piece parts become almost insignificant in the 'cost' of the fix; so even if they aren't completely knackered, replacing as course, so you dont have to spend the big money of pulling the bugger apart again to replace them when they become the weak-link, makes sense.
DIY? Its only saving you money 'cos you don't cost your time.. or like me, figure its a more pleasurable way to waste time than watching a bunch of fellas kick a pigs bladder round a field, or dangling a bit of string in a puddle hoping to out wit a fish! In which vein, buying spanners and gaskets and stuff, CAN actually also be a cheaper way to waste money, than buying season tickets, SKY subscriptions, this years supporters scarf, bait, tackle and Lemsip!
But brings us to a conclusion, do you really NEED to know what the 'cause' is, absolutely, and nail it down to that one main. singular, major protagonist, or even hang all the conspirators in the plot? Or do you just want to fix the problem?
And if its hobby-mechanics, that don't have to earn their keep... well... yeah, you can live with that much more 'risk of failure'... as every failure is an opportunity to play with spanners and more fun to be had... BUT it don't get you to work on Monday Morning!
Personally? have it down to the base gasket; I'd be wobbling the con-rod on big-end, and the crank in the mains, to assess how much life is left in the bottom end; and then probably chucking new cylinder & piston kit on the top, as cheaper, usually than a rebore on these little motors; Head, if cheap as suggested like-wise; and once all back together chucking the left overs into the Little Honda Engine Bits breeding pile in the corner, and forgetting about them, until I need something to chock a Land-Rover wheel or a bit of alli to rebuild a cooling fin or something.... but nothing stopping you leaving them on the bench and cracking out the DTI gauge and mag-stands to measure them up for size and roundness etc and discover just how far gone each protagonist was, IF that's of such interest to you.... But that's me, and once fixed, I have more than enough other teasers to keep me and my spanners entertained!
Like trying to find where halfl my effing volts are escaping from my Range-Rover battery! Or, reconditioning a pair of carburetors for one of the 125 Super-Dreams, OR repainting my Montesa's frame, ORR ooh! that one don't need anything!!! Maybe I should try a new handle-bar & head-lampo arrangement on the 'Seven-fifty'.... it's been avoiding the spanners for TOOO long! Lol!
Post-Script:
Old shedology rule of thumb for valve guides is, without the stem seal or springs in the way, to pop the valve in, and with oily thumb push the valve stem down into the guide until the ball of your thumb is sealing the top of the guide... then rapidly pull the valve about half way down the hole, and let go... see if it springs back under the vacuum!
If it pops back all the way and 'rings' nicely on the seat.. its pretty damn good!
If it pops back about half way or more, its pretty good.
If it sort of sluggishly worms its way back in....take it out, wipe the oil off it, use a cotton bud down the guide to clear gunk out of that, and try again with a light smear of thin oil, like vegie oil for the deep-fat fryer!
If it just drops out... yeah.... its probably 'shot'!
shedologist 'leak test' is to leave the head combustion chamber side up on the bench over night, with the valves in, and the combustion chamber filled with light, veggie oil or two-stroke, see if the level drops.
Petrol or White spirit, anything thinner than diesel, will almost certainly 'leak' by capilliary action past the seats, so not tell you anything.
But will only tell you if the valve seat is 'OK' ish; wont tell you whether anything gets past the guide; hence the 'suck test' above for them.
Rings, likewise, in the bore; pouring oil or petrol into the pot and watching the level wont really tell you much, unless it literally pisses out; its a pretty crude 'laberyth seal' technically; the rings dont form a seal all the way around the bore, they have gaps between the ends, and between themselves and the piston grooves; principle is that the 'path' pressure has to take to get past them is like a maze, rather long and difficult, but it can and will get past. Efficiency of such a seal is reliant on the fact that the pressure in the cylinder isn't constant, and under the effof high pressure of combustion, the tiny % that might get past will be insignificant, and fleeting.. most will stay in the pot and push piston down.
Hence you assess the sealing before strip down with a compression tester 'dynamically', or after strip-down by measurement of clearances.
MCN
PostPosted: 16:55 - 20 Aug 2016    Post subject: Reply with quote
The only way to determine where the most leakage is coming from is to pressurise the cylinder with compressed air through the plug hole.
Listen for air leaks from the rocker cover, exhaust pipe, inlet manifold.
It is not an exact science but it can help.
To be more precise you need access to the top cover and the crank case which you won't get on the CG125. Sad
The valve guide can be fooked but the seal should keep oil out if good. You can tel if the guides are worn by pushing them side to side with the seals off and look for movement. There should be no movement.
You need a rather specialised tool to measure guide bores too.
Pressing out and pressing in guides is quick. Heating and cooling is cheaper is you don't have access to a press. Smile
scotto75
PostPosted: 22:02 - 20 Aug 2016    Post subject: Reply with quote
Thanks MCN. A leak down tester is on my birthday wish list, but Mrs Scotto never gets me anything I ask for.
Teflon-Mike - thanks for all the information. That last post is full of genuinely useful information that I'm sure will be of use now and with all the other potential top end fiascos future me has yet to encounter (I'm currently trying to make on CB250 Superdream from two basket cases).
Also, there was a lot of amusing home truths... Little Honda Engine Bits breeding pile made me chuckle.
I don't think I need to know what the cause was, and as you rightly say, it is more likely a combination of factors, but this is a rare opportunity to poke around and feel like a proper experienced motorcycle mechanic and have some first hand experience in those things I read in my Roy Bacon or Mark Zimmerman books or BCF workshop threads!
Regardless of what happens next, you can guarantee I will be trying out the shedology valve and combustion chamber test just for kicks.
Teflon-Mike
tl;dr
PostPosted: 03:57 - 21 Aug 2016    Post subject: Reply with quote
scotto75 wrote:
I'm currently trying to make on CB250 Superdream from two basket cases.
oooooooooh nooooooooooo.... not-a-nuva-wun... or two.. or four!
Back in 1982.... Unc banana'd an almost brand new 250N 'delux' on the Brimingham road, at an indicated 80, when a woman backed off her drive..... I had the folder of paperwork for it some-where in a bunch of 'stuff' my mother dumped on me after my gran died, cos 'Bike', ergo must be mine!!!!
Original MCN advert for the things; I think it was something like "all you need to do 200 miles a week, for a tenner" Petrol was £1.20 a gallon at the time, so it was something like £7 a week on the 'knock', and they chucked in a crash-hat, jacket and your first years insurance!!! ride-away price on the invoice was £999!!! THEY WEREN'T WORTH THAT THEN!!!!!!!
Meanwhile Donald, had staked claim to the farm workshop; He was a friend of my Gran & came round to mow the lawns & tinker with the machinary, had acquired another 250N off a 'lad at work', who'd given up trying to fix it when he discovered he couldn't ride it on L-Plates when his 17th birthday came round.
Two-(fifty) and Two-(Fifty) equals DAFT IDEA.. to make one... I would say 'good' bike.. out the assemblage.....
A number of other Honda 250's joined the congregation, rapidly filling up the tractor shed!
I 'saved' the air-cooled Yamaha RD250 my other Unc donated to the pile.. or more accurately, he got it off a lad in the pub, who was struggling to make it work; and offered it to Donald to aid his campaign, hoping perhaps that as it was a two-stroke, and didn't have an over-head-cam, he might not get in such a tangle with it.... But donald didn't want it, so he gave it to me... "You can fix it up for when you're 16" he suggested......
Even Donald knew better than 16-year olds being allowed to still ride 250's... that law had come in a decade before, even the 125 L-Plate regs.... but Unc simply said "Shhhh! It'll keep him out the way pushing it up and down the drive for a few months!"
In 1995, I returned to the family seat after uni....... Unc, recently divorsed had done like-wise, and had cleaned out one of the old animal sheds; installed a wood-burning stove and racked it out with all his snap-on spanners, he'd managed to keep in the divorse settlement.
Sat in the middle of this glorious accommodations, was a very very rusty but almost complete AJS 350 single......
Chris the Wop; was stood in the doorway having wheeled it in.... and Unc was asking Donald "Now isn't this more like what you want to mess with?"
A measured frown was on Donald's brow, as he assessed how much money might be being wrestled out of his wallet, and how much work this thing would take to ever run again.....
"Look!" Said Unc... "I need the tractor shed, I'll swap it for your super-Dreams!"
Donald was still suspicious... but after a cup of tea in the kitchen, and leaving Chris the Wop to help him have a shuftie and they'd had a ferret through Chris's van for some bits... he reluctantly agreed it might be an 'OK' deal!
"Right!" Said Fred.... yup that is Unc's name, and that IS what he said!
"Right! Mike... I need your help!" and marched me off to the tractor shed.... to sling at least three honda 250 frames, five petrol tanks, and I have no idea how many boxes of what might once have been 250 twin engines... or possibly even the odd single!! Into... the back of 'Pikey' Chris' (as distinct from Chris the wop!) skip lorry!
"You swapped a 350 AJS, for a pile of old Honda 250's... JUST to chuck'em in a skip?" I mused... "How much did the AJS cost you?"
"Don't Ask!" he replied! "But worth every penny to put t'owd bugga out of his misery and get my damn tractor shed back!"
I believe that is the last time I touched a 250N.......... thankfully!
Teflon-Mike
tl;dr
scotto75
PostPosted: 22:06 - 21 Aug 2016    Post subject: Reply with quote
Wow! You have to hand it to the Superdreams, they're like marmite and hate 'em or love 'em people always seem to have a strong opinion on them.
I'd much prefer to have a CB250 G5, or an AJS 350, than my two bikes. Well, I say bikes, but what I have is two log books and a lockup with a growing Honda Superdream Bits breeding pile.
I've only just got the engine on my workshop table and the task at hand is beginning to dawn on me. Still, I would rather be doing this than anything else, and am naively seeing this like benign the property ladder, and eventually I'll be able to transcend the bedsits for a period semi in the suburbs.
PostPosted: 18:02 - 22 Aug 2016    Post subject: Reply with quote
Meh. You've clearly never seen the Indian rope trick.
I've seen all the vlave stem oil seals replaced on a GS1000 without the head coming off.
You set the piston to BDC then stuff as much plastic coated washing line as you can down the sparkplug hole. Now turn the crank gently until it stops. You an now pop the springs off without the valve dropping. Tneds to be a two-man job. One to compress the spring by main force (spring compressor end on a t-bar) and the other to remove/replace the colletts.
Teflon-Mike
tl;dr
PostPosted: 20:58 - 22 Aug 2016    Post subject: Reply with quote
Lol!
I have now you come to mention it.... just never seen it 'work'.. or at least work sufficiently to 'save' the hassle of taking the head off to get all the bits of 'rope' out the pot after!
Never seen it tried with PVC sheethed washing line though... maybe that's the trick. Wink
The last post was made 10 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 154.76 Kb
