Can engine get damaged from minor dirt in the oil
Sweaty_Doughnut
PostPosted: 23:22 - 16 Aug 2016    Post subject: Can engine get damaged from minor dirt in the oil Reply with quote
I was wondering, when checking the engine oil level, there is a little bit of dirt around the thread and if you put the dipstick on the ground there is a chance even after you clean it for some dirt to stay on it (sand grains or whatever we can call it). Can this minor dirt damage the engine or the filter would catch that?
jaffa90
PostPosted: 00:16 - 17 Aug 2016    Post subject: Reply with quote
Clean the area around the dipstick before removing, filters will stop engine damage.
PostPosted: 10:03 - 17 Aug 2016    Post subject: Reply with quote
Don't put the dipstick on the ground. You have a rag/paper towel to wipe it with. Put it on that.
There is a screen filter on the oil pickup that would stop bigger bits being sucked into the oil pump and most bikes have a finer gauze/paper filter somewhere in the circuit. They are mostly there to filter out bits of carbon deposit and small particulate matter resulting from wear of engine internals. They are also acting only on the pressurised part of the oiling circuit. They are not there to filter out lumps of sand you stuck in there on your dipstick.
Any dirt that goes in the oil filler hole is going directly into your gearbox and crankcase. There is no filter there so it'll be sloshing around in with all the gear componants, clutch, alternator and crank.
Also consider. In most cases, that gauze filter on the pickup is right in the middle of the engine and never gets cleaned in the bikes lifetime (and isn't designed to be for most bikes). Any dirt that is caught in there will gradually build up over time. If it blocks, your engine is toast.
So it is good practice to avoid as much as possible, dirt going into your engine.
PostPosted: 23:22 - 17 Aug 2016    Post subject: Reply with quote
Yes a tiny bit of dirt can cause major damage. Although most of the time not. While there is a screen before the pump, the mesh isn't that small on some bikes. And the oil filter is after the pump, hence the dirt can damage the pump. Further, depending on engine temp, pressure, etc, some oil will bypass the filter before being pumped around the engine.
Katy
Shinigami
PostPosted: 12:21 - 18 Aug 2016    Post subject: Reply with quote
why are you putting your dipstick on dirty ground to begin with though Question
tom_e
PostPosted: 13:53 - 18 Aug 2016    Post subject: Reply with quote
We've all put our dipsticks places we shouldn't at one time or another, it happens Twisted Evil Laughing
Shinigami
PostPosted: 15:21 - 18 Aug 2016    Post subject: Reply with quote
mines got lumps all over it and a weird discharge....wait oh...oil dipstick!.... Embarassed
Evil Hans
PostPosted: 15:43 - 18 Aug 2016    Post subject: Reply with quote
Rated informative, as there didn't seem to be an option for over-informative.
Very Happy
Gone but not forgotten This post is not being displayed because the poster is banned. Unhide this post / all posts.
ackack
PostPosted: 16:34 - 18 Aug 2016    Post subject: Reply with quote
Britabroad wrote:
You're main concern is HTF did dirt get in there,( other than your apparent lack of concern for dipstick placement)
Dirt inside any engine is not a good thing, & l'd advise you to buy some flushing oil & a new filter as well as new oil & just make sure you don't do the task on the back field! Wink
I would give flushing oil a very wide berth. I would do a double oil change rather than use engine flush.
james1988
PostPosted: 17:47 - 18 Aug 2016    Post subject: Reply with quote
Why? What's wrong with flushing oil?
James
Honda XL1000VA '07
ackack
PostPosted: 03:20 - 19 Aug 2016    Post subject: Reply with quote
Flushing oil was a handy thing to have in the 70's and 80's on cars when oil quality was not like it was today and the engines on your average family car had shit crankcase ventilation and you either got mayo or black death in your engines. The problem I have with engine flush is that it is designed to break down 'sludge' and 'carbon' deposits and while that is all fine and dandy how do you make sure that when you've drained the oil and engine flush that there isn't any engine flush still left in the engine?
You don't so whatever is left in the oilways or in the engine is going to be mixing with the next batch of oil you put in the engine and it is going to affect the new oil in some way. Plus you're going to have it go all over the gearbox and clutch. One thing I do notice is that of all the manufacturers handbooks I've read regarding oil changes not one mentions flushing oil. Only regular changes.
The last post was made 10 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.51 - MySQL Queries: 13 - Page Size: 80.61 Kb
