My CBR900rr has leaked coolant from the reservoir
jonathan26
PostPosted: 18:34 - 21 Aug 2016    Post subject: My CBR900rr has leaked coolant from the reservoir Reply with quote
My cbr900 fireblade 1999 has leaked coolant from the pipe connected to the top of the coolant reservoir. This pipe has an open end which leads to the bottom of the fairing. I had been out on the bike, no apparent problems with over heating. After parking up the bike, I noticed coolant coming out of this pipe till the reservoir emptied. when the bike had cooled I opened the radiator cap to find the coolant 2-3 cm below the overflow pipe.
What could cause the reservoir to do this?
Any ideas appreciated.
Jonathan
PostPosted: 18:40 - 21 Aug 2016    Post subject: Reply with quote
The most common cause is over-filling the expansion bottle. It should be no higher than the line when stone cold.
Might be it just needs a coolant change.
Other than that you might have a failing pressure cap. If the system doesn't get up to pressure it'll boil and the excess will expand into the expansion bottle - the lower the pressure the more expansion.
Similarly, if the bottle level has been allowed to get too low it might have drawn air into the system when cooling, instead of drawing the coolant back in.
jonathan26
PostPosted: 19:35 - 21 Aug 2016    Post subject: Reply with quote
Ok thanks for that, since the coolant has recently been changed, look like it might be the filler cap.
PostPosted: 19:57 - 21 Aug 2016    Post subject: Reply with quote
Ah, more likely it still had air in the system. Fill it, burp the system and keep an eye on the level for a while.
andys675
PostPosted: 21:10 - 21 Aug 2016    Post subject: Reply with quote
the "reservoir" is a catchment tank for coolant expansion, once sorted I would run it at the minimum mark to help avoid overflowing in future
The last post was made 10 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 44.42 Kb
