| Dr. DaveJPS |
 Dr. DaveJPS World Chat Champion
 Posted: 15:10 - 22 Aug 2016 Post subject: Daytona 675 Fault |
Hi all,
Thought I'd ask on here to see if any of you lot have any suggestions as even the Triumph factory are stumped...
My 675 was running fine on monday, put it in the garage on monday night. On tuesday morning it wouldnt start, turned over but wouldn't fire. Changed the battery and still nothing, engine turns over but nothing. No change in noises (fuel pump is priming fine).
So arranged collection from my local Triumph dealer, who are currently having a look. The ECU is coding no errors, the CPS is reading the correct resistance and it doen't appear the loom had any issues. The garage have phoned Triumph techincal but they can't suggest anything. ____________________ "intelligent inattention is preferable to unintelligent tinkering"
www.davejps.com |
| chris-red |
| MarJay |
 MarJay But it's British!
| Polarbear |
 Polarbear Super Spammer
 Posted: 00:28 - 23 Aug 2016 Post subject: |
The wonderful world of the modern dealership/mechanic. If there isn't a fault code they are stumped.
Basically it needs air, fuel a spark and compression.
I'm presuming we can rule out compression
So it will have enough air (unless a family of mice have taken up residence in the air box)
That leaves fuel and spark,
Test spark by removing plug, lying it on cylinder head a turn over.
If there is no spark, your problem stems from there.
If there is a spark it has to be fuel.
Start from there and eliminate things logically. ____________________ Triumph Trophy Launch Edition |
| Dr. DaveJPS |
 Posted: 07:53 - 23 Aug 2016 Post subject: |
In answer to your questions:
-Wasn't the sidestand/clutch/kill switch as they all worked as they should.
- No alarm system fitted
- no spark is the problem
Heard back from the garage last night, and after talking to the triumph's head of technical service they ran some further diagnostics and pinned it down to the ... Crank Position Sensor.
Which was what Dr.Google suggested the problem was and what I told them I thought it was. It seems this a a weak point on the daytona 675 (pre 2012) and the annoying thing is its "wired" into the stator, so officially have to replace both the stator and the sensor, which is £323.17 from triumph. Thankfully i've found a third party supplier who can do it for more than half that! ____________________ "intelligent inattention is preferable to unintelligent tinkering"
www.davejps.com |
The last post was made 9 years, 168 days ago. Instead of replying here, would creating a new thread be more useful? |
