Honda deauville fuelling issue
sgtcalle
PostPosted: 13:59 - 20 Aug 2016    Post subject: Honda deauville fuelling issue Reply with quote
Hi all. I have a 99 Honda deauville i use for my 90 mile daily commute.
I was coming back from work the other day, and the bike gave the symptoms of running out of fuel. I put it on the reserve tank and it gave me about another 5 miles before sputtering and dying. I just thought id ran out of fuel as the mileage I had done meant I would have been close to empty. So I filled it up and off I went, bike ran fine.
Then yesterday the same thing happened, but it happened when I still had half a tank. So clearly hadnt run out of fuel. Bike died, I pulled up, opened the tank cap as you do, closed it up, the bike fired up and let me go another half mile before it happened again. Luckily I had a half full gas can on me from the week before, so I filled it up and off I went no issues.
My current thinking is blocked breather hose, or a blockage in a fuel line somewhere? Any ideas? Help appreciated as always.
CBR600F '02
Manchester
Oldie
PostPosted: 14:50 - 20 Aug 2016    Post subject: Reply with quote
Most likely it's the fuel pump. You'll either need to (a) replace the points, available on ebay, (b) replace with a new Chinese fuel pump, ebay again, or better, (c) fit a new Facet fuel pump. See link for a very good guide
https://robdavistelford.co.uk/webspace/deauville/
Oldie
PostPosted: 16:02 - 22 Aug 2016    Post subject: Reply with quote
Oh, and if you decide to replace the points and do the (recommended) diode mod, I have a bag-full of them if you need a couple Very Happy
davebike
PostPosted: 06:40 - 23 Aug 2016    Post subject: Reply with quote
Yes sounds lie the fuel pump
Probily the points
But just did one that was a failing alarm turning the pump off at random !
Dave
NC750Xdct + others at work !
davebike1@gmail.com
The last post was made 9 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 39.24 Kb
