Brake pad uneven wear?
kramdra
PostPosted: 21:34 - 21 Aug 2016    Post subject: Brake pad uneven wear? Reply with quote
Getting uneven wear on pads, is it normal?
More wear happens on the bottom pot/pads, which see the disc first as it rotates. Probably a result of drilled disc eating into the pad? seems to be 0.5-0.8mm difference after 30k miles
I have rotated my pads, which should even it out. The good ones have perhaps 10k miles left, but I had to swap the other two for spare. One was down to 0.3mm at the bottom Shocked (the top of this pad was just on the wear marker 1mm). MOT is soon so will get new before then.
RhynoCZ
PostPosted: 21:41 - 21 Aug 2016    Post subject: Reply with quote
Nope, not normal at all. Time to clean/rebuild the caliper. Some uneveness is possible between the left and right pad in one caliper, especially if it's a floating caliper, but when talking about only one pad, it should never have uneven wear.
EDIT: Rotating the pads to even the wear is wrong as well. Thumbs Up
This kind of thing should never happen:
https://www.aa1car.com/library/brake_pads_uneven_wear.jpg
kramdra
PostPosted: 22:00 - 21 Aug 2016    Post subject: Reply with quote
It is not massively uneven, 0.5mm not 3mm. However the pads only have 3mm to begin with (including the 1mm wear limit), so that 0.5mm is quite a few wasted miles. Both pads in both callipers are the same, slightly more wear on the bottom pot. Callipers were stripped and cleaned Jan 2015, I noticed some pots were slightly freer to push by thumb back then. Seals were inspected, perfect condition, cleaned and put back. Callipers and seal groves were spotless. Today I pushed the pistons half out and flossed them clean with tissue and brake cleaner, they all seem equal, much better than they used to be.
What to do? I will fit new pads this month anyway, but seems silly to do seals just before winter. Also need new rear disk, rear pads, probably new rear piston and seals. About 90 quid. Front pads and seals is another 200 quid if I use genuine Nissin parts, which I would prefer.
PostPosted: 22:06 - 21 Aug 2016    Post subject: Re: Brake pad uneven wear? Reply with quote
Yes it is pretty normal or at least not unusual. Basically the same reason as why a lot of calipers have smaller leading pistons.
Katy
PostPosted: 22:41 - 21 Aug 2016    Post subject: Reply with quote
Normal. I don't think I've had any pad pair that wore at exactly the same rate and it's common to find a couple of mm or more extra thickness on one side, especially on the rear. In fact, I have a drawer full of old pads for when I/someone gets caught out with pads down to metal and a wait for a new set. Better to put in a part-worn pad temporarily than trash the disc.
Shinigami
PostPosted: 08:52 - 22 Aug 2016    Post subject: Reply with quote
if its a sliding caliper it could be what happened with mine, one of the sliding bolts was very slightly mis-threaded/crossthreaded (couldn't tell visually). Ended up having to replace the caliper when I finally figured out the problem..
It was chewing up pads at a very similar angle to those pics
Fizzer Thou
PostPosted: 22:52 - 23 Aug 2016    Post subject: Reply with quote
The rear pads on the Exup and the FJ12 have shims that allow different pressure on one side of the pad.It sounds like one is missing or that where the pad backing plate slides in the caliper body,that it is catching somewhere and not moving freely Question
Always have a 'Plan B'
MCN
PostPosted: 15:53 - 24 Aug 2016    Post subject: Reply with quote
The Hydraulic effort from the lever will take the path of least resistance.
If a pad or piston is tighter than another on in the same circuit then that slacker/free one will wear most.
Clean out the caliper and check the pistons move together.
kramdra
PostPosted: 20:28 - 24 Aug 2016    Post subject: Re: Brake pad uneven wear? Reply with quote
Katy
This explains it, they did use a smaller piston on the bottom.
Pulling the lever without pads will move them the same amount. Very little resistance, I am quite happy they are not needing to be stripped and cleaned until after winter.
Fizzer Thou
PostPosted: 14:12 - 25 Aug 2016    Post subject: Re: Brake pad uneven wear? Reply with quote
The standard Exup1000 calipers that I now have fitted to the FJ1200 have smaller leading pistons,which is quite obvious when looking at the caliper body
https://i1073.photobucket.com/albums/w384/Rhencullen5/FJ1200/20160612_164135_zpscciufiq6.jpg
The standard FJ1200 calipers have the same piston size for leading and trailing items
https://i1073.photobucket.com/albums/w384/Rhencullen5/FJ1200/20150621_202218_zps87slwrom.jpg
The YZF750 calipers that I now have fitted to the Exup1000 are quite distinctly six piston,where the leading pistons is smaller than the other four
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/20160420_165309_zpsxolnnfa8.jpg
But I have yet to see any difference in the way that the pads wear.It is more about braking forces.The FJ1200 standard calipers are known not to have a very good feel and need a lot more braking pressure on the lever,than say the six piston YZF750 calipers.
PostPosted: 23:05 - 25 Aug 2016    Post subject: Re: Brake pad uneven wear? Reply with quote
I suspect a large part of the issue with feel is down to lousy choice of leverage ratios (especially on 1980s Yamahas) and not very rigid calipers.
The leading edge of the pad will have a greater braking effect, and likely wear to go with that . Smaller leading piston is meant to result in a bit less pressure on the leading edge, and even out that braking effect
Katy
The last post was made 9 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 74.83 Kb
