Bent fork but no reason
PostPosted: 12:45 - 24 Aug 2016    Post subject: Bent fork but no reason Reply with quote
I rebuilt my forks last weekend. When putting them back together they wouldn't sit right.
After much fucking about and trying everything I come to the conclusion the LHS upper Fork leg is bent.
The problem when I first put it back together was the spindle screwed in too far and the wheel would sit off center. The face of the spindle should sit flush with the fork leg.
i.e.
https://www.consolidatedtools.com/WebRoot/GroupNBT/Shops/s3zpvuf584b3/4EE4/8654/F741/6FA6/18B9/0A0C/05E9/4FC4/KOKENSPINDLE_LARGE.jpg
See how it is flush with the fork leg? Mine was 5-10mm recessed.
The test that proved it to me was I had the forks in and bolted up the spindle but no wheel/Muguard. I tighten the spindle up enough so it was flush.
I loosened the pinch bolts on the RHS fork and spun the upper stantion (Chrome bit). The space between the face of the spindle and the lower leg didn't move.
When I repeated this on the LHS leg the spindle face would move in and out.
I have no idea how this happened, They haven't been in an accident. Is it possible to bend a fork and not realise?
CaNsA
PostPosted: 12:47 - 24 Aug 2016    Post subject: Reply with quote
What are the bushes like?
PostPosted: 12:56 - 24 Aug 2016    Post subject: Reply with quote
New oem with the rebuild.
CaNsA
PostPosted: 12:59 - 24 Aug 2016    Post subject: Reply with quote
Strip the fork again and check everything with a straight edge innit.
PostPosted: 13:14 - 24 Aug 2016    Post subject: Reply with quote
I did strip it again to check it was together properly. I didn't really have anything straight enough and the right size. I'm taking it to motoliner at the weekend to get it straightened.
CaNsA
PostPosted: 14:29 - 24 Aug 2016    Post subject: Reply with quote
do you not have a laser pen?
PostPosted: 15:20 - 24 Aug 2016    Post subject: Reply with quote
My method of checking is enough to establish it is bent just wonder how it could have happened.
PostPosted: 16:36 - 24 Aug 2016    Post subject: Reply with quote
Accident Sad
If you want to get them straightened you're welcome to come over and use my hydraulic press.
PostPosted: 22:17 - 24 Aug 2016    Post subject: Reply with quote
Pete. wrote:
Accident Sad
These legs haven't been in one I'm fairly certain, they have been on the bike years too.
Cheers for the offer but I've already booked them in with Motoliner. I'm taking them in Saturday morning to get checked if as I suspect it's only one it'll only be £35 to sort.
PostPosted: 22:36 - 24 Aug 2016    Post subject: Reply with quote
Can't really beat that price TBH to have Motoliner do it. Do they require the leg whole or stripped? My guess is they'd appreciate it stripped.
PostPosted: 23:09 - 24 Aug 2016    Post subject: Reply with quote
They didn't last time, I took a complete front end wheel, forks and yokes to them. Dropped them off went into the village found the pub had a pint a burger read a magazine came back and they had sorted the lot.
PostPosted: 23:37 - 24 Aug 2016    Post subject: Reply with quote
Is this on the tdm? With conventional forks. Takes a fair bit to bend forks (and massive amount to bend USD forks - when compressed in an impact the main stress point just under the bottom yoke has the strength of both the inner and the outer). An accident really is the most likely cause. Are they the original forks (ie, been out for a fork change at a dealer and got mixed up with another set maybe?)
Katy
Wonko The Sane
PostPosted: 08:19 - 25 Aug 2016    Post subject: Reply with quote
pothole?
PostPosted: 09:32 - 25 Aug 2016    Post subject: Reply with quote
Yeah this is the TDM. Both stantions were replaced a few years back with new OEM by me. I haven't had any meaningful impact since then. This is why I am so perplexed by it.
I do have an old bent one in the garage I use as breaker bar which i considered had gotten mixed up but that would be impossible has it has a collection of old fork seals round it as a sort of grip.
Ariel Badger
PostPosted: 22:01 - 25 Aug 2016    Post subject: Reply with quote
You tend to notice incidents that bend forks! Are you sure they were straight when you got them?
The last post was made 9 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 87.33 Kb
