| DVicinskas |
 DVicinskas Two Stroke Sniffer
| MahatmaAndhi |
 MahatmaAndhi Traffic Copper
 Posted: 18:08 - 04 Sep 2016 Post subject: |
First thing's first: I know naff all about anything bike related.
My Kawasaki recently stopped working. Turns out it was the starter switch itself.
It could be that? Here's the thread for my issue:
https://www.bikechatforums.com/viewtopic.php?t=315316 |
| DVicinskas |
 Posted: 18:17 - 04 Sep 2016 Post subject: |
I'll have a look into it I opened the fuses and made sure they are all connected this is what sound it makes now https://vid.me/TaOE |
| MahatmaAndhi |
| DVicinskas |
| DVicinskas |
| Teflon-Mike |
 Posted: 22:52 - 04 Sep 2016 Post subject: |
Sounds like a machine-gunning solenoid.
I presume you hear it rattle like that when you press the starter.
Hints that your original problem wasn't the solenoid that was replaced, but that may have been a symptom of it.
Machine-gunning happens when the circuit made by the solenoid results in a voltage drop beneath what is needed to keep the solenoid engaged.
So, you touch the button, and the solenoid engages, and turns on the starter circuit, causing voltage drop that turns the solenoid of again, which lets the volts come back up enough to turn the solenoid back on; so it cycles through the loop as long as you have your finger on the starter button, very rapidly firing the solenoid back & forth like a machine-gun... or an electro-mech indicator flasher unit... that co-incidentally works on exactly that principle.
Causes of machine gunning?
1/ flat or fucked battery providing terminal volts high enough to trip the solenoid, but not enough amps to turn the starter.
2/ gummed or fucked starter motor, sucking more amps when turned on, than the battery can supply.
3/ jammed or fucked starter clutch, that stops the starter motor turning when it's turned on; so the high 'mechanical load on it puts high electrical load on the battery.
BUT, the causes & symptoms are inter-related.... eg:
Carbon brushes in the starter motor wear; the carbon dust coats the armature contacts, and conducts electricity, so that more than one or two windings in the starter get fed at a time, perhaps doubling the electrical 'load' drawn by the starter, whilst the starter looses efficiency the extra 'unwanted' windings making magnetic field pushing against the ones you want pushing.
Extra electrical load on the starter, sucks more amps from the battery, more quickly, so battery goes flat faster, BUT 'deep-cycled' heavy load supplied very very quickly, wears out the battery, quickly.
While the amps trying to be sucked through the solenoid, can see the it 'arc' accross teh contacts before they actually touch, both pitting the copper and oxidising it, making the contact area smaller and 'corroded', so it too adds to the electrical load, or starts refusing to pass any.
Tackling the obviouse first; you charge the battery up.. and with more juice in it, it doesn't suffer as badly, but, not the 'root cause' masks them for a bit, so you can carry on with the starter sucking higher current, wearing out more brush, and the solenoid erroding...... until it gets worse again, and charging the battery doesn't help... 'cos by now its buggered... and you buy a new one...... and like the machine gunning solenoid... go back round the loop.... until you look at the solenoid.... and clean, fix or replace that... A-N-D go back round the loop.. a repeat incident taking you back to the battery, you are convinced must be good 'cos you 'just' replaced it.... so you replace it again, and back round the cycle until you finally get to the starter motor. ... and with THAT reconditioned... start over, discovering that the second new battery and the first new solenoid were similarly buggered by the old starter!!!!
SO!!!!
It dont work... take it back the shop who haven't fixed it... or start burrowing into it DIY.
Removing the starter and testing the resistance readings as you rotate the armature can give hint whether the windings inside have broken down or worn through and the starter is a dodo that will have to be replaced or proffessionally re-wound. If Resistance readings 'consistant' if not great, then you may get away with just a clean and brush kit....
But that would be my starting place, after looking for any signs or obviouse spanner-monkey numptiness like a solenoid feed wire trapped under the starter motor mounting flange, being pinched and shorting when you turn the starter 'on' or something. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| petalbriefs |
 petalbriefs Traffic Copper
| Aceslock |
 Aceslock Spanner Monkey
| Spamalittle |
 Spamalittle Scooby Slapper
| DVicinskas |
 Posted: 13:58 - 05 Sep 2016 Post subject: |
Hey guys so the problem was the rectifier, it just wasn't charging the battery properly, will swap it out. Other than that bike is in top form right now, but trust me if I had known of how much troubles I would have with this bike I would have never bought it... Sorted and happy now though  |
The last post was made 9 years, 219 days ago. Instead of replying here, would creating a new thread be more useful? |
