Best Plasterbord Fixings?
TimNorwich
PostPosted: 19:35 - 05 Sep 2016    Post subject: Best Plasterbord Fixings? Reply with quote
Hi BCF,
Calling on your wisdom again, I've just had a new porch put onto my house and intend on putting a coat rail in there. The width is around 1.2m which will mean a decent amount of coat space but this means the rail will need to be strong enough to hold them (and hopefully not rip out of the wall!).
I've had a look online but there is frankly too many variants around, i'm hoping somebody will point me in the right direction Very Happy
Thanks!
Mark_F
PostPosted: 19:39 - 05 Sep 2016    Post subject: Reply with quote
You really want a wooden batten behind the plasterboard so you can screw through.
grr666
PostPosted: 19:40 - 05 Sep 2016    Post subject: Reply with quote
Are the boards dotted and dabbed onto block or fixed to stud?
It makes a difference.
TimNorwich
PostPosted: 19:50 - 05 Sep 2016    Post subject: Reply with quote
They are fixed to a stud, the depth of the cupboard is only 70cm so no studs in the middle just either end sadly!
arry
PostPosted: 19:56 - 05 Sep 2016    Post subject: Reply with quote
Fix a wood to the board running between the two studs, painted in the same colour as the cupboard, and then fix the rail to that. It really is the only way to get very strong plasterboard fixings to hold decent weight.
If you really don't want to see wood (snigger) then cut the board horizontally where you want the rail, insert a noggin and affix nicely either side to the studs, then replace the board, repair flush and paint, then affix the rail.
lihp
PostPosted: 20:02 - 05 Sep 2016    Post subject: Reply with quote
https://www.screwfix.com/p/easyfix-hollow-wall-anchors-16-32mm-m5-x-72mm-10-pack/11143
Use the above a lot in work as everything is plasterboard. Put coat hangers up with these that are strong enough to do pull ups from.
TimNorwich
PostPosted: 20:26 - 05 Sep 2016    Post subject: Reply with quote
I like that idea about fixing wood to it, it's only a cupboard so not too worried about it looking naff, just want it to function well.
This may be a stupid question but can I just screw the board straight through the plasterbord into the stud (with the help of a guide hole)?
Thanks!
grr666
PostPosted: 20:36 - 05 Sep 2016    Post subject: Reply with quote
Uno plugs. Available in B and q. For a coat hook I'd probably use the grey ones. which require a 10mm drill bit.
400bandit
PostPosted: 23:40 - 05 Sep 2016    Post subject: Reply with quote
https://www.youtube.com/watch?v=sDHvyH4zuc8
These are the best things I've used in plasterboard, currently holding a a very heavy mirror in the front room with three of these though in reality two would have been fine.
I've used both the plastic and screw-in types which serve a purpose but these are much more sturdy.
Joe
arry
PostPosted: 08:28 - 06 Sep 2016    Post subject: Reply with quote
Thanks!
Yeah. You can use big ass wood screws.
J4mes
PostPosted: 17:05 - 06 Sep 2016    Post subject: Reply with quote
Joe
I like the way he shows us how tight they are by trying to wiggle them with his finger. Laughing
TimNorwich
PostPosted: 23:18 - 06 Sep 2016    Post subject: Reply with quote
Thanks for your help guys. I installed the rail this evening with a plank spanning from one stud to the other - so far so good!
The last post was made 9 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 73.5 Kb
