| blinky |
 blinky Nitrous Nuisance
 Posted: 17:43 - 25 Aug 2016 Post subject: DISC/brakes advice please. cbr600f 94 |
hi guys,
one of my discs are worn quite heavily and/or warped i suppose... as im now getting a shuddering in my front braking.
any options?? (other than buying a new one)
can i service the disc by flattening it out? (has some worn grooves more than the other side)
If i buy a new one, im told i MIGHT have to buy 'TWO' new discs AND new pads ...otherwise the front will be unbalanced.
Another reason for me not buying new parts, is this is a run-around high milage bike... so dont particualrly want to spend money excedding the value of the bike, lol
mot only a couple months ago!
pads good.
brake fluid level good.
stopping power still ok.
overcompensating on the back brake at the moment, but i know this is ill-advised.
any help, hugely appreciated,
Cheers  ____________________ Better to ask forgiveness than permission!
Oh i miss my first love, the lovely lil CG!
Rouser 135 2012... Enfield 25... Hornet 600 2002... CG125 2000 |
| MarJay |
 MarJay But it's British!
 Posted: 17:58 - 25 Aug 2016 Post subject: |
Bear in mind this was a Supersport championship winning bike in 1994. It can't really be run on a shoestring. If the discs are within the wear limit, you *may* be able to skim them. I was going to suggest removing the discs and cleaning any corrosion off of the mountings, but if one side is grooved, then it either needs skimming or replacement.
The service limit will be stamped on the disc somewhere, and needs to be measured with a micrometer. My guess would be, a bike from 1994 with scored discs will need new discs. You can't really just replace one, unless you want a 150mph bike with crap brakes.
So yes, buy decent aftermarket replacement discs, replace the pads and while you're at it strip and clean the calipers and replace the brake fluid. If you can't do that yourself, either buy a workshop manual or ask someone who does know. There may even be someone on the forum who lives nearby who can help you. Maybe. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| G |
 G The Voice of Reason
| andym |
 andym World Chat Champion
| haroman666 |
 haroman666 World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 19:12 - 25 Aug 2016 Post subject: |
My CB seven-fifty uses the same wheels & brake set-up I believe & I bought that 10 years ago as high-mile hack, with juddery front brake....
Nissin 'floating' calipers are notorious for sticking on the float-pins, & the steel pins corroding in the alloy housing, in damp and salty British climate.
Pull, strip, clean meticulously, and re-assemble with new grease & if you are indulgent seals & pins from Dave-Silvers.
Popping the pistons & fully overhauling the caliper can save a lot of silly questions later, too.
Likely that pistons are rather flakey and seal grooves gummed up, and most brake failures occur AFTER maintenance.
Usual mechanism, is that an old flakey pitted piston, that has spent 3/4 of its life out in the elements, is shoved back into the caliper when new, thicker pads are fitted, often taking a load of shit with it, to make seals stick, and or leave the flakey/pitted bit of piston wall wearing away the tired old seals.
Cleaning up sticky old float pins and letting the caliper actually float like it should, can do similar, begging the pistons travel twice as far as they have become accustomed.
ISTR pistons in those calipers as OE were chromed mild steel, and they do tend to go rather flakey and pitted in British weather; Stainless replacements from all things old Honda aren't exactly penny parts, but overhaul ops to fit'em are a precaution against causing later problems, and they do seem to last well, even on all weather, out-door living owld dawg like mine!
Discs; Off top of my head, they are aprox 6mm thick when new, with a wear limit stamped on them of I think its 4 or 4.5mm; there's not a lot of 'meat' in them to get them skimmed if warped or scored & they are stainless, which isn't so nice to work with in a M/C shop; I have a couple of good engineering co's round me, who will do such scratty little jobs, but loath to take on one of these....
More helpfully, pulling the discs, good chance you may find that the steel disc bolted against alloy hub for twenty years has a build up of corrosion on the mount flange, which 'may'.. and it is just a chance let the disc 'creep' out of true, when its hotted and cooled under load, & stripping & cleaning & careful re-assembly 'might' help take out a bit of imbalence... but if you fit a new disc certainly advisable to make the mount 'good' before you fit it.
Plenty of Cheapo discs on e-bay, including wavy-ones I am utterly unconvinced by. Not wanting to take chances I got genuine EBC's from Dave-Silver's.. they weren't 'that' much more expensive and they have lasted ever since....
It's not an area of a bike to try cutting corners or taking chances with IMO, and as said, it is a 150mph race winning sports motorcycle, not an MZ250 utiliterian commuter hack! & horses for courses, & if you want 'cheap' wheels, it's not exactly the best starting point. "Cheap" old bike like this will only be 'cheap' if you don't use the performance it has to offer... either saving it as Sunny Sunday toy, in which case it's still not very cheap, and the bills might not come in very often, but still sting when they do... or you ride it like an ER5.. in which case you might as well have bought an ER5, 'cos bills are still going to come in, and still sting when they do. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| blinky |
| blinky |
| MarJay |
| G |
| Bozzy |
 Bozzy Traffic Copper
| tom_e |
 tom_e Brolly Dolly
| skatefreak |
 skatefreak World Chat Champion
 Posted: 09:21 - 09 Sep 2016 Post subject: |
These look cheap and cheerful.
If you're not pushing the bike hard then I wouldn't worry to much tbh. My buddy is sporting some cheap wavey disks on a gsxr 600 k1 track bike and they have been performing great, no sign of fade/fractures etc. |
| Rogerborg |
 Rogerborg nimbA
| blinky |
 Posted: 21:21 - 10 Sep 2016 Post subject: |
| skatefreak wrote: | These look cheap and cheerful.
Cheers they ain't bad at all! ...even if they don't last as long as Honda ones.
I'm making a trip up through Swansea to snowdonia area next week..so il pay them a visit on the way and posibly install them myself or ask them to do it on the spot.
Oh and thanks guys, but I should be been more specific.
I meant if I replaced the rh disc with a used disc (similar thickness to left side) ..then surely ther wouldn't be any or very little inbalance?
Maybe it's not worth the time taking jus one off... il work that out tomorow.
...and to the chap that thought my bike is worth a grand.. ha, you haven't seen this bike, trust me ☺
54k milage, 14 past owners, and front plastics missing ..along with ripped seat and hole in one of the cowels.
I was very surprised it passed it's Mot with discs like this!
The bonus is, the way it looks, not many people wana steal it
I will be selling it within the next 2 months anyway most likely... just put 2 new tyres on it and cleaned out the carbs. I want to do one long trip around the UK. I've never seen parts of Wales and the North, and want to go on an adventure! 😀😁
Il be posting a new thread for trip advice and nice bike roads if anyone is keen to offer.
Ta again.  ____________________ Better to ask forgiveness than permission!
The last post was made 9 years, 296 days ago. Instead of replying here, would creating a new thread be more useful? |
