Rotax 122 - Measuring Squish?
FlubbaBubba
PostPosted: 20:03 - 08 Sep 2016    Post subject: Rotax 122 - Measuring Squish? Reply with quote
Can anybody tell me how to measure the squish on a stock rotax 122 engine?
Its got a new mitaka piston in an old mitaka cylinder and head which has around 4000miles on it.
Can i use solder to measure the squish and my manual says its supposed to have 1.5mm squish on it.
Does it have to be 1.5mm or just in the ball park?
Any help would be much appreciated, thanks.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:01 - 08 Sep 2016    Post subject: Re: Rotax 122 - Measuring Squish? Reply with quote
Squish band, you mean.
Not squish
Triumph Sprint ST 1050
PostPosted: 21:05 - 08 Sep 2016    Post subject: Reply with quote
Rolled up plasticine on the piston crown. Properly done it's called 'claying'.
redeem ouzzer
PostPosted: 21:09 - 08 Sep 2016    Post subject: Reply with quote
You have to build it up and then compress the solder, then strip it to retrieve the solder ring so you can vernier it. Arsehole but only way to tell. No less then 0.8mm for pump fuel unless you like fucked Pistons from detonation.
I'm not sure what Nobby is on about but then again I'm not sure how familiar he is with tuning 2t's.
Be a REAL MAN!
PostPosted: 21:19 - 08 Sep 2016    Post subject: Reply with quote
I should think that 0.8mm squish would put the piston very close to contact with the head at full revs.
Hahadumball
PostPosted: 23:06 - 08 Sep 2016    Post subject: Reply with quote
i think a majority are ~1mm so 0.8mm doesn't sound too close, id be aiming for 0.9 as a happy medium, 0.9mm would make it that little faster, longevity and moar powah id go for 1mm- 1.2mm+
dont listen to me its been years since i worked in a bike shop
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
PostPosted: 06:08 - 09 Sep 2016    Post subject: Reply with quote
1mm is the recommended minimum piston to head clearance for a steel conrod.
PostPosted: 08:01 - 09 Sep 2016    Post subject: Reply with quote
I measured squish on my 350 YPVS by having a twisted up long piece of solder, poking it through the plughole until it touched the side of the cylinder, then turning the engine over. I did this four times on each cylinder, at each corner of the cylinder. I then used a vernier to measure the crushed solder.
I have a feeling on that bike it was about 3mm or so, and could have done with being reduced a bit.
Old Git Racing
PostPosted: 15:32 - 09 Sep 2016    Post subject: Reply with quote
As Marjay says, solder down the plug hole is the easiest way. I wouldn't be going less than 1mm on a road bike engine, they just aren't durable enough without constant rebuilding of the crank, and fuel isn't good enough to prevent detonation. Even 1mm would be pushing it in my view.
My race only TZ could be built with varying squish gaps by changing the base gasket thickness. Running at .9 - 1mm was good for reliability and ok power, crank rebuild every 1000 miles. Running at .6 - .7mm gave more power, crank life down to 700 miles and pistons 250 miles instead of 300.
OGR.
The last post was made 9 years, 186 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 61.93 Kb
