how vital is the anti-rattle clip on brakes?
Wonko The Sane
PostPosted: 14:16 - 09 Sep 2016    Post subject: how vital is the anti-rattle clip on brakes? Reply with quote
One of my anti rattle clips is missing due to one of the retaining screws having sheared and I was wondering if it's a huge issue or will just cause the pad to wear down a little quicker or get crudded up a little quicker?
cheers
RhynoCZ
PostPosted: 14:27 - 09 Sep 2016    Post subject: Reply with quote
It is not dangerous to ride it without the clips, they only make sure the pads are not vibrating during braking, which is what causes the whistling/squeaky sound. You could use some grease on the back of the pads to emulate what the clip does. Thumbs Up
EDIT: And what Mr. Wheel says, I forgot some clips are actually guides for the pads. Well, If you've got Nissin 4 pot calipers from the 90's, you can ride them with out the clips. Thumbs Up
PostPosted: 14:38 - 09 Sep 2016    Post subject: Reply with quote
I would say it depends on which anti-rattle clip it is.
Some seem to simply stop rattling. Others act as a guide for the ends of the pad and I'd worry aboutthem jamming in the calliper without.
SO the 6-pots on my VFR were supplied without anti rattle springs, I had to fit some because it was noisy. The rear calliper on my KLE would spit the pads out without the clip (and sometimes does anyway).
Wonko The Sane
PostPosted: 14:42 - 09 Sep 2016    Post subject: Reply with quote
Kawasaki ZZR600 running the standad Tokothingies:
parts diagram
https://www.cornwallkawasaki.co.uk/shop/shop.php?cmd=showdiagram&id=2592
PostPosted: 14:53 - 09 Sep 2016    Post subject: Reply with quote
Should be ok with that one missing.
You may (shock horror) find it rattles without them. Is annoying.
Wonko The Sane
PostPosted: 15:16 - 09 Sep 2016    Post subject: Reply with quote
probably won't hear it over the fairings rattling!
pepperami
PostPosted: 21:06 - 09 Sep 2016    Post subject: Reply with quote
I lost one on my Superdream and it didn`t stop the bike functioning, it did however make the brake squeal during light braking???? Confused
As soon as I got that silly little sliver of metal off another old caliper and put it in, the squealing stopped??
Nobby the Bastard
Harley Gaydar
PostPosted: 22:01 - 09 Sep 2016    Post subject: Reply with quote
The squealing is vibration at a frequency that you can hear.
Triumph Sprint ST 1050
MCN
PostPosted: 08:56 - 10 Sep 2016    Post subject: Reply with quote
The reason for the shim it to present a different material between the pad backing and the caliper which interferes with the resonance of the assembly and prevents squealing.
As said it will work perfectly without the shim but may squeal like a stuck pig.
The last post was made 9 years, 294 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 62.36 Kb
