| Tom_91 |
 Tom_91 L Plate Warrior
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 14:30 - 10 Sep 2016 Post subject: |
Take them apart and clean them? ____________________ My Flickr |
| Itchy |
 Itchy Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 14:38 - 10 Sep 2016 Post subject: |
What you call 'head cylinder' is the master cylinder. The oil is held in the reservoir.
Seems if you pushed the caliper pistons back, then they are moving. I think that what you mean to say is that they aren't moving out when you squeeze the lever on the master cylinder. Since the master cylinder is pumping oil, which must be going somewhere, and the pistons aren't moving there must be air in the system. Bleed the front brakes. ____________________ a.k.a 'Geri'
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:54 - 10 Sep 2016 Post subject: |
If bleeding doesn't sort it, your master cylinder seals may be shot.
What bike, how old, how many miles, and have you done any very hard braking recently? ____________________ Biking is 1/20th as dangerous as horse riding.
| bikenut |
 bikenut World Chat Champion
 Posted: 17:45 - 10 Sep 2016 Post subject: |
Piston/caliper corrosion making piston movement really really really difficult.
Hot water can help free of a stuck/stiff piston but it must be dried/lubed straight away after, else more corrosion, so perhaps mums hair drier for the heat.
Stuck/corroded in pistons can be freed off even with some air in the system.
Once piston has moved out as much as you dare without it popping out, clean off corrosion, lube and gently g clamp back in, repeat until piston is free.
If multi piston, g clamp others and work on one piston at a time, do not allow it to pop out!!
Pics of caliper/calipers, master cylinder and fluid.
Wood, brake fluid ( for lube, you know it can be a brilliant paint stripper ), g clamp/s, patience, rags, wire brush, pictures, pictures, pictures!!
see cmsnl for the exploded views of your bike and brakes.
Corroded piston hydraulic seal face, corroded area between caliper hydraulic seal and dust seal. master cylinder strip down clean reassembly with new parts and Fluid.
Red rubber grease.
Clean caliper pistons in a clean caliper bore will drop in and drop out, red rubber greased new seal and piston will be a push fit with thumb pressure. Any slide pins?? pics pics pics. ____________________ nuts about bikes |
| stinkwheel |
 Posted: 20:42 - 10 Sep 2016 Post subject: |
Sounds like you need to bleed the air out.
If the lever has no resistance, either the master cylinder piston seal is dead or you need to bleed the air out of the system.
If the lever moves a little then goes solid, your pistons are seized. However, the pressure exerted by a hydraulic brake system is such that I'd expect even pistons that have been practically welded in place by corrosion to move with a good firm pull on the lever. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Fin |
 Fin World Chat Champion
| Ed Case |
 Ed Case World Chat Champion
| Major Doss |
 Major Doss Traffic Copper
| stinkwheel |
| bikenut |
 Posted: 14:10 - 11 Sep 2016 Post subject: |
Doc whatever posted:
Oh dear. I was so expectecting to be a better forum member..
Red rubber grease.
Woo! I did it.
ftfy foc
It is annoying when people advise the use of brake fluid on brake seals, so well done.
ftfy foc
Red rubber grease.
Doc whatever, dont know what the ftfy foc means, modern kids babble chat probably.
And,
Just what do the seals in your master cylinder etc. "live" in, mineral oil?
Original poster Tom, how you getting on? ?? pictures please ____________________ nuts about bikes |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 15:50 - 11 Sep 2016 Post subject: |
If the master-cylinder reservoir was empty.. I'd want to know why, before anything else.
Pushing the pistons back all the way into the caliper body is usually a very bad idea on anything but a brand new caliper assembly.
The pistons, gradually creeping out of the caliper to compensate for pad wear, get covered in brake dust; add rain-water and possibly some road-salt; and the result is a quite corrosive mixture.
This causes the pistons, that are usually hard-chromed steel, like the fork stanchions to rust, and the chrome to pit and flake, depending on how bad they are allowed to get.
Now add road grime to the brake dust, and the rust, and you have a rather nasty 'grinding past' around the piston, which as it corrodes takes on the texture of sand-paper rather than glass...
Add the two together, and what you have is a perfect system for wearing away the rubber seals around the piston as the piston moves in and out, that very small distance it travels under normal braking operation.
THEN when you get to the point that the brake pads have worn out...
To fit new ones between the disc and the caliper body, you have to push the pistons back into the caliper body.. do that without cleaning & inspecting the pistons first, and you are likely to a) grind a load of rubber off the seals when you push them back in, b) push a load of shit past and or under the seals with the piston, so that the seal either wont, or wont for long, as the crap trapped under it holds it away from the metal its trying to seal against and or adds to the abrasive action wearing it away double time.
And like I say... brake fluid cant simply 'dissapear'... it HAS to go some-where.... and the seals in the caliper are a pretty likely suspect.
Master cylinder seals are next.. and not shoving fluid down the pipe to the caliper, adds to the suspicion...
But, putting new fluid into an empty reservoir, and not bleeding it through to remove air from the pipes, means that basically you haven;t got a clue what's going on... or what you are doing.
In which case, STOP and give the job to some-one who DOES.....
Brakes are ONE thing you really don't want to fuck'up from numptiness, they really aren't. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| andym |
 andym World Chat Champion
| Fizzer Thou |
| Islander |
 Islander World Chat Champion
 Posted: 21:41 - 11 Sep 2016 Post subject: |
As above, bleed the system and use hydraulic pressure to drive the piston out.  |
| Major Doss |
| bikenut |
 Posted: 18:01 - 12 Sep 2016 Post subject: |
As well as being brake seal/fluid friendly ( fluid dependant? ) , try castrol lm and see what happens!
Brake fluid-moisture-corrosion-knackered seals-bound pistons. Repeat ad infinitum. cos thats the process. Alloy corrodes, even stainless steel will etch etc..
Yeah, ride thru fords and pressure wash to your hearts content.
cmsnl is vast and free, but you don't have to buy from there do you?
Sorry cmsnl, but we have, and will again.
Still no answer about the kids babble and fluid/seal interface?
As to heat, warm the alloy so its expands a bit, a bit faster than the piston material, so piston can move more easily/at all.
With the hydraulics still plumbed, i place the caliper in a bucket of hot water, count to 3 then pump away, piston moves quite quickly and pop out. The stuff I have to deal with is usually badly corroded, needing new piston and seals, time with a dremel type wire wheel to get ride of all the alloy corrosion, cleaned cleaned cleaned and inspected, if ok, reassembled with new parts, then onto the master cyl.
Wow, if the stuff I have to deal with is a "good" as those fizzer, i would be well happy.
When m/cylinder is done ( remember that tiny little hole, the recouperating port, to allow the brakes to "release", unless its blocked!! ( cleared either mechanically ( less than 0.6mm hole) or by pressure ) a plumbed in caliper, use "reverse" hydraulic pressure, but be ready for the long lasting "jet" of fluid!!! ) its refitted to the bike, hose attached at that end, and fluid allowed to syphon/flow by gravity to caliper end of hose, cleaning it of old fluid as it does so.
Priming the m/cylinder is easy if bore has been "WETTED" with fluid before the unit was assembled, so piston etc. has a full non sticking, lubed bore to travel in.
Remember its a pump, so finger and thumb on caliper end banjo, and pump till air is pushed out, then connect to caliper and gravity prime till no more air, then normal pumping/nipple fiddling till bleed .
Just assume brake fluid is a good paint stripper/pad fucker upper etc so keep it way from the brakes, you dont lube brakes, unless its tractor type etc etc etc.....
pictures can be misleading/deceaving, would i re use those pistons and seals, no . want to know why??
how you getting on tom?? ____________________ nuts about bikes |
The last post was made 9 years, 300 days ago. Instead of replying here, would creating a new thread be more useful? |
