brake fluid
bikenut
PostPosted: 15:00 - 11 Sep 2016    Post subject: brake fluid Reply with quote
As a matter of interest, do any modern bikes use "lhm" or "lhs" type of fluid for brakes these days?
nuts about bikes
RhynoCZ
PostPosted: 15:28 - 11 Sep 2016    Post subject: Reply with quote
LHM, that's mineral based oil, right? I doubt that modern vehicles still use that in brakes. I'd say it's all DOT silicon based fluid nowadays.
Islander
PostPosted: 21:45 - 11 Sep 2016    Post subject: Reply with quote
Eh? I thought the only brake fluid that's silicon based is DOT 5. All of the others are glycol based IIRC.
PostPosted: 22:03 - 11 Sep 2016    Post subject: Reply with quote
Thought LHM was the stuff used on Citroens and the like, effectively a mineral oil. Not sure I have ever heard of any bike using it.
Silicone fluid is pretty rarely used. Think Harley use it. Has a few advantages (mainly doesn't take paint off and doesn't absorb water so in theory doesn't need changing regularly) and a few disadvantages (possibly gives a spongier feel to the brakes, and not absorbing water so it water gets in to the system it is very difficult to get it out).
Katy
Fizzer Thou
PostPosted: 22:11 - 11 Sep 2016    Post subject: Reply with quote
DoT 5.1 is different to DoT 5,which is similar to DoT 4.
The DoT 4 that I use is this,which is silicone based
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/20160911_215832_zps1sfm8kov.jpg
The mineral oil is specified for use in the Magura clutch fitted to my KTM enduro.Later Brembo clutches on KTMs use Dot 4 or better,as in DoT 5,which has a higher boiling point but is still silicone based
Always have a 'Plan B'
Islander
PostPosted: 22:19 - 11 Sep 2016    Post subject: Reply with quote
It's only DOT 5 that's silicon based and is the only non-hygroscopic fluid (because it is silicon based Wink ). DOT 4 and 5.1 are glycol based. The DOT ratings refer to boiling points. Katy has it right. Thumbs Up
https://en.wikipedia.org/wiki/Brake_fluid
PostPosted: 22:28 - 11 Sep 2016    Post subject: Reply with quote
DOT 5 is silicone based (normally coloured purple), but DOT 3, DOT 4 and DOT 5.1 are no
DOT 5.1 has a higher boiling point and mixes with DOT 4 normally. DOT 5 doesn't mix with the others (it shouldn't react with it, just doesn't mix).
Main use for DOT 5 seems to be military vehicles.
Katy
MCN
PostPosted: 22:48 - 11 Sep 2016    Post subject: Re: brake fluid Reply with quote
I've googled a bit of that for you.
https://en.m.wikipedia.org/wiki/Brake_fluid
Rolling Eyes
Fizzer Thou
PostPosted: 01:55 - 12 Sep 2016    Post subject: Reply with quote
Apologies.
I got DoT 5 and 5.1 around the wrong way.
I first started to use DoT 5 on my Honda 750 back in 1981 when I first heard about the fact that it did no harm to paintwork.
I have been using DoT 5.1 in the KTM enduro brakes in the past,as that is what the manual specifies,but until recently I have run out and have been using DoT 4 instead Thumbs Up
weasley
PostPosted: 07:21 - 12 Sep 2016    Post subject: Reply with quote
Then there's Castrol React SRF brake fluid, which is silicon-based but not silicone, so can be used in DOT 3/4/5.1 applications but has a boiling point that exceeds DOT 5. It is hygroscopic but its performance does not deteriorate much when wet. Not cheap though.
arry
PostPosted: 08:32 - 12 Sep 2016    Post subject: Reply with quote
Interesting. I have a Magura clutch reservoir on my 990. Do you reckon that's what's supposed to be in mine, too? I wonder if it is what's in there after monkey dealer servicing.
Fizzer Thou
PostPosted: 18:38 - 12 Sep 2016    Post subject: Reply with quote
The reservoir caps usually give an indication about what specification fluid that should be used
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/20160912_181538_zpskagzwu35.jpg
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/20160912_181623_zps3lrtemay.jpg
As for the fluid in my clutch,the manual specifies mineral oil only.This does not need to be replaced as often as a DoT 4 or 5.1 fluid and the bleeding procedure is quite different to brakes Thumbs Up
arry
PostPosted: 18:55 - 12 Sep 2016    Post subject: Reply with quote
Thanks. I'll take a look. As I say, I wonder if there's what should be in there at the moment - probably the original fluid.
Fizzer Thou
PostPosted: 20:35 - 12 Sep 2016    Post subject: Reply with quote
My brother also rides a 990 SMT and he says that his clutch master cylinder cap says to use mineral oil only Wink Thumbs Up
As Motorex sponsor KTM,the recommendation is to use that sold by them.
I have found that Putoline make a cheaper but similar quality mineral oil Thumbs Up
The last post was made 9 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 2.28 - MySQL Queries: 13 - Page Size: 85.1 Kb
