Engine/frame bobbins.
kernel gadaffi
PostPosted: 14:39 - 19 Sep 2016    Post subject: Engine/frame bobbins. Reply with quote
I was going to fit some crash bars to my 96 Bandit 600, but a mate suggested fitting some bungs/bobbins to the frame in front of the engine, can anyone recommend a set that won't break the bank? My mate reckons I'll get a set off Baye for £25-30, the ones I've seen are nearer £70+.
I've nothing against my left leg.
1996 Mark 1 Suzuki Bandit 600.
PostPosted: 15:07 - 19 Sep 2016    Post subject: Reply with quote
Screw threaded rod into the appropriate holes, drill-and-screw blocks of wood onto the rod, spray pound-shop black if you're fancy.
May know someone that did this on their GPZ500S. Super legit.
c_dug
PostPosted: 16:33 - 19 Sep 2016    Post subject: Reply with quote
Unless you're really worried about ground clearance or are particularly fussy on cosmetics, I'd go for the crash bars, they offer far better protection, and I would think are far less likely to cause damage in an off.
Alpineandy
PostPosted: 17:00 - 19 Sep 2016    Post subject: Reply with quote
Are these any good?
https://www.ebay.co.uk/itm/SUZUKI-GSF-BANDIT-600-1200-CRASH-MUSHROOMS-SLIDERS-BOBBIN-BUNGS-PROTECTORS-R7A2-/331875809353?hash=item4d4556f849:g:GesAAOSw7NNT92XJ
The above comment isn't necessarily the truth and anyone that says it is, is only correct if it's the truth or they're bigger than me.
andys675
PostPosted: 18:20 - 19 Sep 2016    Post subject: Reply with quote
do not fit bobbins to the front engine mount on a bandit (or hornet)
they have a habit of breaking the engine mounts in a crash, and the insurance company will write your bike off
kernel gadaffi
PostPosted: 19:10 - 19 Sep 2016    Post subject: Reply with quote
They are just the job Andy.
Thanks.
PostPosted: 19:29 - 19 Sep 2016    Post subject: Reply with quote
Sample set is...?
iwaldo
PostPosted: 19:56 - 19 Sep 2016    Post subject: Reply with quote
Not the same bike but a car decided to play ping pong with me and my MT-09 last week, the front crash protector got bent back and saved the bike (and me) from any other damage
It was just a cheap no name £40 set on ebay. Needless to say I've ordered a replacement set!
I'm sure if you put your bike model and crash protectors on ebay search, a similar cheap set will show!
MT-09 / YZF600R Thundercat '02
andys675
PostPosted: 20:11 - 19 Sep 2016    Post subject: Reply with quote
Rogerborg wrote:
Sample set is...?
m0l0t0v wrote:
Keir_K3 wrote:
i dont have bungs to stop damage altogether, i have bungs to limit the chance of holeing an engine casing or similar which would put the bike out of action and me stranded.
My bungs made a huge hole on my engine....
https://www.ebay.co.uk/gds/Crash-Mushrooms-pros-and-cons-Are-they-worth-fitting-/10000000177650184/g.html
PostPosted: 21:15 - 19 Sep 2016    Post subject: Reply with quote
What, he fitted them, then a big hole just appeared? Cum hoc, ergo propter hoc.
Crashing made a huge hole in the engine. The bungs just failed to save it. People get Schumachered while wearing helmets, but it doesn't mean that they never help.
OP's riding a 20 year old Bandit. I'd hazard a guess that any crash with enough energy to wreck the bike despite the bungs is going to make it non economic to repair anyway.
Itchy
PostPosted: 21:25 - 19 Sep 2016    Post subject: Reply with quote
Sample set is...?
Hornet is true. The cheapo box section spine frames bend on impact even low speed spills and low sides. The Norf BCF lot killed 6+ Hornets from low speed spills due to the frame snapping as they seem to be made from wet cardboard.
PostPosted: 23:41 - 19 Sep 2016    Post subject: Reply with quote
Fitted with bungs?
The last post was made 10 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 76.08 Kb
