Will I blow myself up? Boiler stuff
Quote Me Happy
PostPosted: 14:27 - 20 Sep 2016    Post subject: Will I blow myself up? Boiler stuff Reply with quote
Hypothetically speaking, if I were to replace a thermocoupler in my boiler, what are the chances of me making a crater where my house once stood?
PostPosted: 14:52 - 20 Sep 2016    Post subject: Reply with quote
That's a DIY job.
I would point out that you need to turn the gas off but if you didn't already know that then it's not a DIY job. Laughing
mudcow007
PostPosted: 15:28 - 20 Sep 2016    Post subject: Reply with quote
Also, dont check for gas leaks with a lighter
I replaced the control board, AAV and fan on our boiler (old scabby Worcester) an im still here to tell the tale
PostPosted: 15:52 - 20 Sep 2016    Post subject: Reply with quote
It might invalidate your house insurance, mine stipulates all gas repairs/installations must be done by a gas safe registered person.
That said, they are a piece of piss to work on.
Triumph Trophy Launch Edition
ScaredyCat
PostPosted: 15:58 - 20 Sep 2016    Post subject: Reply with quote
Aren't you supposed to be a corgi or something to do work like that?
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
mudcow007
PostPosted: 16:11 - 20 Sep 2016    Post subject: Reply with quote
Or border collie
Quote Me Happy
PostPosted: 16:55 - 20 Sep 2016    Post subject: Reply with quote
If it does go wrong I'll probably go woof.
PostPosted: 17:26 - 20 Sep 2016    Post subject: Re: Will I blow myself up? Boiler stuff Reply with quote
To paraphrase Arthur Ransome.
"Better exploded than duffer. If not duffer, wont explode.".
Compared to motorcycles. Boilers are simple. Otherwise boiler repair men wouldn't be able to do it.
Quote Me Happy
PostPosted: 17:44 - 20 Sep 2016    Post subject: Reply with quote
The nice gas man replaced the thermocouple, simple job. I have a new problem now, the pilot light ignites and stays on but when the main burners come on after about 15 seconds or so there's a loud click and everything goes out, what do?
It's a crappy old boiler that I've been meaning to replace for years, I might just get it done.
PostPosted: 18:01 - 20 Sep 2016    Post subject: Reply with quote
If it's a normal boiler rather than a combi, I wouldn't.
If it's a normal boiler, keep it. Combis are unreliable pieces of shit that fuck up on a regular basis and are nothing but trouble.
Is it getting water? Pump kicking in when it starts? Could there be an airlock?
Sounds like it's firing up the burner then deciding it's too hot and cutting out again.
My combi did something similar and after an enormous amount of pissing about, three visits from the boiler guy and two new PCBs, I got mad, grabbed a wiring diagram and worked out the problem myself using my brain and a multimeter. It was a flow switch that was put in on the piss (despite there being both a locating notch AND an arrow on it). It would fire up, decide no water was flowing in and cut out again.
MCN
PostPosted: 18:18 - 20 Sep 2016    Post subject: Reply with quote
You're not allowed to work on anything behind the front cover
You need to be Current Gas Safe Registered.
It only costs a couple of grand to get registered though.
Seriously.... Turn the gas off and do it. The real difficult not is checking for leaks after. Even the Pros get leaks.
You could soap test with a plant/empty kitchen cleaner sprayer. Or buy a tin of soap sprayer from B&A et al.
Al
PostPosted: 19:08 - 20 Sep 2016    Post subject: Reply with quote
When you say everything goes out do you mean you have to re light the pilot afterwards as well or just that the main burner goes off?
Yamaha FZR400RR 3tj
My Instagram Thingy
Quote Me Happy
PostPosted: 19:50 - 20 Sep 2016    Post subject: Reply with quote
Yeah, the pilot light goes out as well, along with the main burners.
Pjay
PostPosted: 20:43 - 20 Sep 2016    Post subject: Reply with quote
Hit it with a big a hammer as you can find.
A few times for best results.
If it don't work after that, it's almost certainly fucked.
Al
PostPosted: 21:13 - 20 Sep 2016    Post subject: Reply with quote
If the pilot is staying lit ok until the main burner fires up its probably that causing the pilot to blow off of the thermocouple, which in turn thinks the pilot has gone out and cuts the gas.
Could be that the pilot is too small, maybe slightly blocked in the injector or tube. Could possibly be an issue with the gas valve set up(main burner set too high/pilot too small/thermocouple not positioned correctly).
Probably not that helpful but it's unlikely terminal, just needs a bit of fiddle by somebody that knows what they're doing.
Yamaha FZR400RR 3tj
My Instagram Thingy
The last post was made 9 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 84.99 Kb
