| louis250994 |
 louis250994 L Plate Warrior
| Doovy |
 Doovy World Chat Champion
 Posted: 16:47 - 22 Sep 2016 Post subject: |
It's a 125cc, and a relatively unknown model one at that. But that does sound quite slow. ____________________ Yamaha RXS 100 > Honda CD 250 > Honda Hornet 600 > Honda CBR 600RR > Yamaha RXS 100 > Kawasaki ZX6R J2 > Yamaha FZ1 |
| arry |
 arry Super Spammer
| Azoth |
 Azoth Brolly Dolly
| louis250994 |
| louis250994 |
| arry |
 arry Super Spammer
| Azoth |
 Azoth Brolly Dolly
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:45 - 22 Sep 2016 Post subject: |
Cute little ride.
That's a CG-125 copy engine. Very basic, pushrods, but it's robust and it should - in good tune - be able to make enough power to get you to 100kph with the right gearing, or 90kph at the very least.
First, get it in good condition. Check the tyre pressures, chain tension and lubrication, and that the brakes aren't binding and the clutch isn't slipping. Consider changing the oil, it only needs 1 litre of any cheap 10W40 oil. If the engine is clattery, check and adjust the tappet clearances. Run it hard and pull the spark plug, check that it's not sooty or white - the previous owner may have tried to "improve" it. Actually... is that a fuel injector rather than a carb? Nice.
The rev counter goes to 12,000 and it's good for at least 10,000 of those. Rev it hard in every gear before changing up. You may find that it'll actually go faster in 4th gear depending on how it's geared.
If it's reaching 10,000rpm in 4th or 5th gear but still only doing 70kph then you could try lengthening the gearing. Try a 17 tooth front sprocket - a Honda CG sprocket will probably fit, but check the dimensions. Conversely, if you rev right it out in each gear but then it struggles and loses speed when you change up, then you may need to lower the gearing and narrow the ratios - try a 15 tooth front sprocket. Give it some abuse first though. ____________________ Biking is 1/20th as dangerous as horse riding.
| louis250994 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 18:05 - 22 Sep 2016 Post subject: |
A four-Stroke 125 single, will generally make something in the order of 10bhp; in a 'normal' style motorcycle that should be good for 'about' 60mph or about 90Km/h. A little less if its a dirt style bike with high wide handlebars spreading the rider out like a parachute, or a cruiser with similarly wide bars and lots or heavy bodywork to drag along. Chinese built 125's though are usually restricted to 55mph for local market regulations; usually by down gearing them.
Either way, most 125 four-stroke singles, have a 'quirk', max power will be delivered at almost max revs; you need all the available power to reach max speed; but at half revs where they only have about half the power they usually have much more power than is needed to go half the speed.
This is because of the 'exponential' of wind resistance; Takes about 3bhp to go 30mph, takes about 9bhp to go 60, takes about 27bhp to go 90, takes about 81bhp to go 120mph...
Ie to go 30mph faster you need three times the power each time.
So, little 125 single, will pull well to perhaps 45mph, even in top gear, but to go any faster, it needs to turn faster RPM to find more power; BUT, at 45mph, it only has enough power at the revs it's turning to go 45mph, so wont accelerate and wont find more power, and you have to change down a gear to get the revs up and find more power to make it go faster...
Which seems counter intuitive... to go faster you need a higher gear, changing down makes you go slower..... surely? Well, it does, if you only stay in the one gear.. but changing down, like you would to go up a hill, can let you get the revs up, get at the power to accelerate, and get some speed up, and THEN you change up in to top, to hold it of eek a little more around that peak power you now have found.
And this niggle is encountered by many new 125 riders, who find that they gave a gear-box to play with, and the engine seems so willing at lower speeds that they change up too many gears far too early so that they dont have any acceleration in top to go any faster when they want it, and are loath to change down, in misguided belief that that's going to slow them down more, not help them go faster.
It is likely there's not much wrong with the bike; its probably still pretty slow, but is actually faster than you are getting, just because you aren't riding it right...
Tiddler's you gotta threash'em a bit to make em shift, you really do.
Answering the accademic question of the title, How fast can a 125cc bike go? WELL.... the fastest 125cc production bike, is disputed between the two stroke aprillia RS125 and the similarly two stroke Cagiva Mito 125. Both have set 'flying mile' or 'flying kilometer' times under record condtitions to clock a few tenths over 101MPH, from limited production 'racing' variants of the over-the-counter models, of which the earlier ones were usually the quicker in magazine tests and the like; as successive emmission controls reduced their power. Both of those bikes are notoriously unreliable for road use, but about 30bhp and reasonably aerodynamic 'race' fairings to help them to top speed.
The old two-stroke 125 Grand-Prix bikes of a few years ago, had about 45bhp as they were supplied to the 'teams'... and engine lives measured in running hours; teams might tweek them a bit more if they could afford the rebuilds, and a 'hot-lap' qualifying engine expected to last no more than maybe five laps, ten or fifteen miles, might offer something over 50bhp, and could clock perhaps 150mph on a fast circuit.
For outright speed records; there are a number of classes; and the 'ultimate' classes allow not only slippy cigar streamlining, but supercharged engines and special fuels and stuff, which make the engine displacement something of an irrelevance to a degree.
Last time I looked, the record for a 'normally aspirated' Ie non super-charged, or nitreose oxide injected 125cc engine, running high-octane, (special) fuel, but not 'nitro-' (explosive rocket) fuel, in a full stream-liner bodywork, was something still quite markedly under the 200mph mark, about 170mph I think, using specially tuned two-stroke engine's.
I struggled to find what had been achieved with a 4-stroke 125cc engine, in record breakers; as they didn't seem to differentiate in the non-production classes.
If you built one, you would struggle to get as much power from one as the two-strokes by a long way; if you could get as much power per cc, though as say a race tuned Yamaha R1, that would be about 200bhp per liter, you might get around 25bhp.... so you would be looking to stream-lining to get one to crack a 100mph, and even with that, probably not much more, maybe 120-130 or so, I would suspect. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| carpe_diem |
 carpe_diem Trackday Trickster
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
| M.C |
 M.C Super Spammer
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 21:22 - 22 Sep 2016 Post subject: |
| The Shaggy D.A. wrote: | I don't think my GPZ was putting out 243bhp when I hit 155mph. I'd be lucky if it produced half that. |
Don't think my VF'r was either... but SHSHHHHHH.... the nice neat 'progression' is actually starting to fall off at much over 60mph, which is where the stream-lining starts to become as significant as the power.....
Only took a little over 60 to get Rollie Free to 155mph on the methanol burning Vincent at Daytona in '48...
https://upload.wikimedia.org/wikipedia/en/4/4a/Rollie_Free%2C_record_run.jpg
NOT sure I would strip to my grundies & a swimming cap to try go that quick.... Just think about 'rubbing salt in the wound' if he came off, given its a salt-flat! EEEK! but still!
Jonny allen's streamline Triumph Thunderbird that offered the Bonnaville name to the twin-carb road-bikes, running methanol, to make something probably still well under 90bhp, managed acredited two-way times of 193mph, and a unacreddited run of 214mph.
Yet that was still a challenge to a more conventional road-bike like the old ZZR, or more slippery Busa, that with a turbo could be punting 200bhp, to crack that barrier in the 'modified' production bike classes.
Meanwhile the super-tuned 50cc streamliners, were still trying to crack the ton, last time I looked, with around 9-10bhp, which sort of gives some sort of brackets around how much can be done on streamlining and how much just needs shear power. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Alawson68 |
 Alawson68 Renault 5 Driver
| NJD |
 NJD World Chat Champion
 Posted: 21:47 - 22 Sep 2016 Post subject: |
Something as slow as my arrow, at last, wheeeey.
Traffic light grand prix OP?  ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
| symonh2000 |
 symonh2000 Crazy Courier
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 14:55 - 23 Sep 2016 Post subject: |
Lol.. oooh the 80's.... FM Galactica hats, Red & white leather jackets, coloured vynal saddles, and a row of variously melted pistons on the garage windowsill.... a mate you needed to borrow a spanner off round the corner who had a GSX250 and always asked "So how fast do you think you were going when it happened this time?" and another, down the pub, who'd tell you the exact same thing happened to him over Digbeth over-pass on his 250 Samuri in 1976!!!
Oh the nostalgia.. what happened to Digbeth over-pass? lol
I had an AR125... I left the bludy motor the fuck alone for three years!!! It wasn't the fastest 125 in the county..... but at least it worked!! I saw that off the clock a few times on big enough hills, but geez, the needle was wobbling all over the place! I think speedo's should have had the same sticker on them as pub fruit machines "For entertainment Purposes Only" on'em! Lol.
Was pleasantly surprised five years ago when I had renovated the first of the four-stroke 125 twin Super-Dreams; Snowie was still finishing hers but wanted to go over to a meet in Coalville, so we 2upped on the tiddler, and GPS snail trail when we got home showed a recorded 69.8mph over 1/2 mile of the M42.. probably slightly gravity assisted, but still; impressive for a 25 year old four-stroke tiddler, two-up! Speedo had been some-where off the clock wobbling about like an exited dogs tail, though! Guess they don't get better with age!
I have a 125 twin motor in the shed, I rebuilt last winter, waiting for a frame to drop it in; that has the 309 cam from the 'full-power' engine in it; begs suggestion of 16/17bhp over the 'reduced effect' learner-legal version that only had 12... be interesting to see if that can crack a genuine 80.
Curious, none of the modern 125's don't make more than the old 2v twin could; but seems to be a matter of scale.
Power = Cylinder-displacement x Cylinder Pressure x Crank Revs
So if you cant up the cylinder displacement you have to get it to cram more charge in the pot(s) and or rev higher to get more power, but I suspect shrinking the bore and stroke to be able to double-up and make a higher revving twin gives you two cylinders barely moped displacement; and little 'space' to get more than two-valves into the pot and have room for a spark-plug, which is why latest generation of water-cooled, 4v 125's are still singles. The 125 twin can certainly rev; red-lines at 13K and even the 'reduced effect' motor eagerly buzzes well past that; but little valves I presume just don't let them cram any more in'em. So, trying to make a 'four' to find even more revs, would probably be just as self defeating; so a single, is probably nearer an 'optimum' for making charge move, and can still be encouraged to rev high-enough.
Bigger multi's are still struggling to better 200bhp per litre, where even a 600 has pots bigger than a 125's, and the 'scale' means that they can sacrifice low rpm power, and 'flexibility', to tune it more for peak; as they have so much more to play with; on a 4T 125, in the same sort of 'tune' to get maybe 25bhp, the low rpm loss would be as bad or worse than the old two-strokes.
Suggests that a 100mph four-stroke 125 is a theoretical possibility...... but, practically? It would likely be an absolute pig to ride; and likely inordinately short of service life.
I recall the comments about the 1966, I think, Suzuki 4-cylinder water-cooled 2-stroke 125GP bike; I believe it only ever had one GP outing at the end of teh season, as FIM changed the regulations for following year; limiting the number of cylinders, and capping the number of gears they could have! 8 gears had become common on the super-tuned tiddlers, with motors that were almost fixed speed, they were so 'peakily' tuned, they wouldn't even idle much under stupidly high 'peak-power' revs; and the 'four' was even worse, had 12 gears, and I recall, comment it had to be started on rollers to get enough crank speed for it to run, and rider warned not to let it 'conk' cos it couldn't be bump-started!! Made an impressive 40bhp though, and clocked 145mph. Which isn't far off what the last single cylinder 125 2T GP bikes were punting thirty years later. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Hong Kong Phooey |
 Hong Kong Phooey World Chat Champion
 Posted: 15:13 - 23 Sep 2016 Post subject: |
That's some extreme sunbathing, skillz when he turns over to tan his chest ____________________
'81 CG125, '97 FZS600 : '99 CBR600F4, '09 KTM RC8 |
| carpe_diem |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 17:43 - 23 Sep 2016 Post subject: |
| carpe_diem wrote: | I reckon I could have got 70mph put of my PX125 but after aquaplaning along the A61 for a few hundred feet I lost my nerve for a while. |
Scootah boi round the corner has a rather luciouse Labretta GP he could hustle round Mallory as quick as the 250LC racers.... and his own dyno to tune it on!
He was telling me that the TS5's(?) the 125 two-stroke with a Nikasil bore, were the quickest of the 125 Vespa's, but a pig to 'port'; he reckoned he could get them to go 'about' 70-ish, with some degree of reliability, but he hated the damn things in general as too many had too high hopes of them, and did too much to'em and expected him to sort them out... and didn't like the suggestion he'd put'em back to stock to do it!
He preferred the earlier iron barrel engines, he said; pretty sure he said they had a longer stroke, so you could get more cc's for any amount of over-bore, and they were more tolerant of more extreme porting you could do to the iron pot.... Wasn't particularly keen on going to town on the Vespa's though.... remember he's an absolute nutter who clocked near minute laps of Mallory on a scootah.... "Yeah, they get a BIT scary at anything over 60" he said think I'll take his word for that..... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| kgm |
 kgm World Chat Champion
| Derivative |
 Derivative World Chat Champion
| symonh2000 |
The last post was made 9 years, 352 days ago. Instead of replying here, would creating a new thread be more useful? |
