DIY ground anchor ideas
gsxr600menace
PostPosted: 12:23 - 24 Feb 2005    Post subject: DIY ground anchor ideas Reply with quote
I work for a company who have a massive shopfloor full of welders and heavy duty CNC lathes and one of the guys said he would build me a ground anchor out of some incalloy which supposedly is almost impossible to cut through. Has anyone got any ideas on shape etc ... or links to the best ground anchors you can buy so i can copy ?
Just bought yellow & black GSXR600, fast as hell !!! (1st bike)
speedfight
PostPosted: 13:01 - 24 Feb 2005    Post subject: Reply with quote
I Think Halford sell them, might be worth popping in to knick some ideas or Any good Caravan shop has alot of them for sale, take some quick photos and measurements from there that should help on your way.
Peugeot Speedfight 100cc (year 2000)
Polini Clutch, Malossi Multivar 2000 Variator
Malossi Kevlarf Belt, Doppler Exhaust
mchaggis
PostPosted: 16:10 - 24 Feb 2005    Post subject: Reply with quote
I'd get something a bit like the attached picture made up. I've no idea if it'd be really strong enough, but basically I'd just scale it up until it is. Make it out of suitable steel and it should be pretty good.
Bolting it to the floor is a basic approach, attaching a 'christmas tree' arrangement of concrete reinforcing bars to its base and setting that in concrete would be better.
Don't take my work for the attached design idea being especially secure, it's not exactly something I've spent much thought on. Just make sure that whatever is welded is properly filleted.
I must not be a troll...
Mmmm, Guinness
Jrod
Page 3 Girl
PostPosted: 16:30 - 24 Feb 2005    Post subject: Reply with quote
How would you bolt it down?
Dom_
Points Mean Prizes
PostPosted: 16:55 - 24 Feb 2005    Post subject: Reply with quote
I would do something like this, and set it in fresh concrete, no chance of them unbolting it then either.
Excuse the extensive detailed diagram. Laughing
gsxr600menace
PostPosted: 19:47 - 24 Feb 2005    Post subject: Reply with quote
thanks mchaggis that was the exact sane design i had in my head, should slow the thieving buggers down for abit !! Razz
Thanks for all the help people
mchaggis
PostPosted: 20:01 - 24 Feb 2005    Post subject: Reply with quote
If you're going to get a bolt down one fabricated, make sure to use bolts which will grip the ground properly. (Rawl bolts I think they're called.) Also, if there is a countersink around each head (so the top of the bolt heads would be flush with the upper surface of the metal) , and they were perhaps allen bolts (dunno if rawl bolts can be allen heads, but never mind that), then you could hammer a steel ball bearing into the allen key socket once they were in so that it'd never be coming out. Smile
Alternatively, I quite like the approach that Dom_ has shown, with it embedded. Just be sure to dig the hole narrower at the top than the bottom so that the new concrete can't be pulled out as a block, as old and new concrete don't bond very well.
Mmmm, Guinness
The last post was made 21 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 53.81 Kb
