what's the most miles you've put on one chain?
trevor saxe-coburg-gotha
PostPosted: 19:18 - 24 Sep 2016    Post subject: what's the most miles you've put on one chain? Reply with quote
A question for those whose bikes are chain driven - what's the highest number of miles you've notched up on a single chain?
PostPosted: 19:19 - 24 Sep 2016    Post subject: Reply with quote
17k on the 954 chain, 38k on the R1, but I suspect it's not on it's first chain.
The Tot
PostPosted: 19:31 - 24 Sep 2016    Post subject: Reply with quote
About 18k miles on the blade with an auto-oiler device. Even with chain loob, you do have to degrease them once in a while and remove the gritty paste which causes wear between the pins and links (which causes the stretch & tight links).
That was with a Tsubaki X-ring type chain.
Never argue with autism
wr6133
PostPosted: 20:40 - 24 Sep 2016    Post subject: Reply with quote
About 23k on a RK X ring chain. While I mantain my chains well my riding style and hamfistedness probably shorten life.
GSXR1000 still has the original chain the bike is on 12k and the chain is almost dead. That'll get replaced with an RK.
Moped belts I seem to shred in under 1500 miles Shocked
kramdra
PostPosted: 20:48 - 24 Sep 2016    Post subject: Reply with quote
A DID x ring should last 25-35k. More if frequent oiling.
Looking at history the original was replaced at 13k with some cheap SSS rubbish and then 23k with a DID, which lasted until I changed it at 51k. And now at 75k = 24k miles, not showing much sign of wear except 4 stiff links.. Never gets cleaned other than a good coating of oil every morning to fling all the shit off.
The Tot
PostPosted: 20:52 - 24 Sep 2016    Post subject: Reply with quote
I hasten to add, I was running renthal sprockets... Yep, they looked pretty hooked after that sorta mileage. Hence why I changed the chain. It didn't need attention or adjustment for 3-4 months when I had it oiled.
I accelerate hard, so as you can expect, it would probably have had a better life if I was more conservative with the throttle.
andys675
PostPosted: 21:35 - 24 Sep 2016    Post subject: Reply with quote
I've seen an OE standard chain on a CBR600 last 30k, legal speeds every day on the motorway in top not stressing it, the standard tyres (mcadams) lasted 20k too
my standard street triple chain was fucked out of its mind by 6k, poor maintenance did for it I just couldn't be asked, the replacement is a DID "gold & black" which hasn't needed adjusting in 6k miles, its had paraffin cleaning, WD40 all summer and silkolene chain lube recently
roadracejoe
PostPosted: 00:15 - 25 Sep 2016    Post subject: Reply with quote
my 02 xjr is still on its original chain & sprockets with 26000 mls thanks to a scottoiler
DJP
PostPosted: 09:06 - 25 Sep 2016    Post subject: Reply with quote
I've never worn one out.
My Bandit 1250 had 25,000 miles on the original chain and sprockets when I traded it in - and it they were nowhere near being worn.
I reckon that with a modicum of care 30k should be do-able on most bike chains.
Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https
Itchy
PostPosted: 09:26 - 25 Sep 2016    Post subject: Reply with quote
35K + and it still had plenty of life on it.
The bike had a scotoiler and dual injector on it and a massive reservoir using used oil then the cheapest mineral oil.
It also over oiled as the chain always looked wet.
PostPosted: 10:14 - 25 Sep 2016    Post subject: Reply with quote
944cc Twin
Odometer reading 53,068 miles
Advisory notice item(s)
Drive chain slightly loose (6.2.1d)
Drive chain worn but not considered excessive (6.2.1e)
Haven't changed it yet.
Currently 37k.
The 250cc single would eat a heavy duty chain every 15k.
PostPosted: 10:21 - 25 Sep 2016    Post subject: Reply with quote
30-35 on the TDM. DID VM Xring.
Andy_Pagin
PostPosted: 10:33 - 25 Sep 2016    Post subject: Reply with quote
About 35,000 so far on the Fazer, but then I oil it several times a week now, and every time after a ride in the rain.
craigT19
Jolly Green Giant
PostPosted: 14:12 - 25 Sep 2016    Post subject: Reply with quote
35k ish on a zx6r chain fitted with a scott oiler, when i changed it the chain was still good but the teeth had worn off the front sprocket. Thumbs Up
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
-Matt-
PostPosted: 10:48 - 26 Sep 2016    Post subject: Reply with quote
Did about 23k on my ZX6 stock chain. Managed that without hardly any cleaning or adjustment at all, somehow.
Next DID VX one managed 7k with regular cleaning before it was utterly knackered Brick Wall not quite sure what happened there.
Current ones done about 8k without any adjustment or problems however.
The last post was made 10 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 86.55 Kb
