Looking for this carb spacer
PASSRQ
PostPosted: 03:44 - 24 Feb 2005    Post subject: Looking for this carb spacer Reply with quote
I am looking for a source for this carb spacer:
48mm o-ringed, 5 mm thick
Any help is greatly appreciated.
Known to be used on Harleys.
Paul
alains
PostPosted: 21:54 - 24 Feb 2005    Post subject: Reply with quote
it's possible to DIY with polyester tissue & resine , i think about 10 thickness will do it . when hard it's only a file work
PostPosted: 16:38 - 25 Feb 2005    Post subject: Reply with quote
If used on some Ferraris then have a check around some small Alfa, Fiat or Lancia speclialists. The spacing looks similar to that used on Weber and Dellorto carbs. May also be worth speaking to a Lotus specialist as well (they used Dellorto carbs for years on the Esprit and Excel, and the turbo Esprit is probably the most likely to use the 48mm version).
PASSRQ
PostPosted: 23:29 - 25 Feb 2005    Post subject: Reply with quote
Thanks all, Was told that S&S Cycle products makes them and sure enough they do for their Super e carb setup (1 7/8 bore =47.6mm) .
They work perfect on Weber 48mm IDF's as no one produces them specifically for that purpose.
The last post was made 21 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.23 - MySQL Queries: 15 - Page Size: 38.96 Kb
