Bar Muff Recommendations
kgm
PostPosted: 16:03 - 26 Sep 2016    Post subject: Bar Muff Recommendations Reply with quote
Afternoon all,
I'm looking for recommendations from those of you who use a set of bar muffs for winter. I know they look a bit lame but I ride everyday throughout the winter and I have decided I'd like to avoid frozen hands this year. My commute is now shorter so it's not so much of an issue but I'd like to ride more at the weekends this year without suffering. I may be pairing them with heated grips on the bigger bikes but not on the CG 125 which I usually use for the commute as I'm not convinced the CG battery will cope due to the short journeys it normally does.
Based upon what I've already read I'm thinking about the Tucano Urbano set but does anyone have any other options or opinions of those? I'm curious to know whether there's much operational difference between the neoprene ones or the bigger fluffy ones?
kawakid
PostPosted: 18:43 - 26 Sep 2016    Post subject: Reply with quote
I'm an all weather biker for some weird reason.
Tucano Urbana is the way to go. They are excellent, I ride throughout winter in my autumn gloves and they never get wet even in downpours.
Only issue I can't use the flasher, so I simply turn high been on and off and it takes a while to learn how to take your arm out and then wipe your visor when raining.
Ive had fluffy ones and they were rubbish.
I've a twin and a 4.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:01 - 26 Sep 2016    Post subject: Reply with quote
I find bacardi and coke normally gets me muff in the bar.
Triumph Sprint ST 1050
Serendipity
PostPosted: 19:23 - 26 Sep 2016    Post subject: Reply with quote
The Tucano Urbano neoprene muffs have worked well for me. I've not tried the fluffy ones, but I have no reason to suspect that they're any worse, just bigger and more complicated.
My neoprene ones have covered nearly 80k miles now. The rubber sleeve that holds the bar end is a bit worn where my gloves rub, but it still grips ok. The metal ring where the bar passes through is a little rusty after several winters. And I needed to take a scalpel to the plastic insert to allow my clutch lever to come all the way back the bar.
Otherwise, no complaints.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
Commuter_Tim
PostPosted: 19:39 - 26 Sep 2016    Post subject: Reply with quote
As above, Tucano Urbanos...
https://www.amazon.co.uk/gp/product/B00426MZB0/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I ride a Bandit 600... badly.
PostPosted: 19:46 - 26 Sep 2016    Post subject: Reply with quote
The neoprene boxer-mitt Urbanos do work very well indeed. However, they also (IMO) make it awkward to work the indicators though the thumb. They aren't suitable for all bikes - I can't use them on my GS.
Anything is better than nothing though. I've just splashed out a whole £9.50 on https://www.ebay.co.uk/itm/131924166749
They have big gaping holes where they slide down the bars, but add a few pennies work of duct tape or cable ties and the job's a good 'un for casual use.
Failing that, DIY it: https://www.bikechatforums.com/viewtopic.php?p=3341207
Commuter_Tim
PostPosted: 20:28 - 26 Sep 2016    Post subject: Reply with quote
I did encounter the inability to use the indies, I took a Scalpel to the indicator 'thumb' on the Tucanos, problem solved.
Minimal water gets through those gaps even in thunderstorms.
PostPosted: 20:48 - 26 Sep 2016    Post subject: Reply with quote
This. 100% Mine lasted 3 winters before my rubber broke, They would have done this season too but the mechanic when I was in for a major service had no idea how to remove them, Which broke them.
New pair ordered already for this season.
Doink
PostPosted: 22:10 - 26 Sep 2016    Post subject: Reply with quote
I've only ever used the Tucano ones, no complaints at all.
Easy to fit and keep the elements out, they totally change the riding experience in very cold and wet conditions.
As has already been said they can take a bit of getting used to but the pros far outweigh the cons in my opinion.
DrDonnyBrago
PostPosted: 08:33 - 27 Sep 2016    Post subject: Reply with quote
I like the big furry Tucano Urbanos that encapsulate the whole handlebar area.
Bigger, furrier, fit a whole fist, no rusty ring and you can twiddle the important bits from the inside.
I've used these every ~Oct-Mar since 2011, nothing but good things to say about them:
https://www.bikechatforums.com/viewtopic.php?t=231946
DrSnoosnoo
PostPosted: 09:25 - 27 Sep 2016    Post subject: Reply with quote
I seem to have the newer version of these. They have a transparent area in the muff to see the controls. I used them last winter, I rate them highly. They cost ca. £50 but they are very sturdy, and will last a long time. It means I won't HAVE to fork out on mega gloves when they wear out, wearing non waterproof, non insulated gloves is do-able in the depth of winter!
Shinigami
PostPosted: 09:35 - 27 Sep 2016    Post subject: Reply with quote
be wary of some of the cheaper muffs that only connect to the handle bar in 1 place, had some on my 125 and in headwind they would bend/push back and apply pressure to both the clutch and front brake which was dangerous as fuck so removed them immediately. Not used or tried any since but haven't really felt the need to either
kgm
PostPosted: 10:04 - 27 Sep 2016    Post subject: Reply with quote
Thanks folks. Urbanos it is. I think I might get a pair of each and see which I prefer as it looks like I'll need a different pair to fit the CG/CX and the ER6 anyway. Cheers.
PostPosted: 10:39 - 27 Sep 2016    Post subject: Reply with quote
If you have bar ends, you can slip something rigid deep into your muff and screw it good and tight.
Does that need an illustration?
carpe_diem
PostPosted: 10:44 - 27 Sep 2016    Post subject: Reply with quote
Rogerborg wrote:
This entire thread made me quite literally laugh out loud. If vikings had ridden motorbikes, these are the muffs they'd have used. I think you should also fashion yourself a nice jerkin out of the same materials.
Currently riding: Suzuki EN125 | Previous rides: Vespa 125PX, Yamaha SR125
BTTD
PostPosted: 11:28 - 27 Sep 2016    Post subject: Reply with quote
Agree, have the same ones and they work well.
Commuter_Tim
PostPosted: 17:49 - 27 Sep 2016    Post subject: Reply with quote
Interesting, I never thought of screwing my muff before.
Now you say it, an illustration would be nice but you would probably be banned for NSFW. Laughing
Rog is from Scotchland, he practically is a Viking. Thumbs Up
talkToTheHat
PostPosted: 09:11 - 30 Sep 2016    Post subject: Reply with quote
I like the big woven nylon Tucano Urbano muffs with the rigid plastic inserts. Lots of room inside to reach the controls, ends do up with a drawstring (do this if you park outside or you'll end up with a muff full of water)
Bandit. does. everything.
The last post was made 10 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 101.69 Kb
