| adrew765 |
 adrew765 L Plate Warrior
| MahatmaAndhi |
 MahatmaAndhi Traffic Copper
| Ariel Badger |
 Ariel Badger Super Spammer
| Polarbear |
 Polarbear Super Spammer
| andyscooter |
 andyscooter World Chat Champion
| adrew765 |
 Posted: 00:14 - 27 Sep 2016 Post subject: |
| MahatmaAndhi wrote: | I was under the impression that all LT models had wheels spaced further apart than standard models, and that they had to have a foot brake to make it able to be ridden on a car license.
Ask The Police doesn't mention the foot brake though.
https://www.askthe.police.uk/content/Q900.htm
| Quote: |
The licence you need to ride a Piaggio MP3 will depend on the power output and the spacing of the front wheels.
If the vehicle is classed as a motorcycle you'll need the appropriate category for its power output:
A1- Light motorcycle up to 11 kW (and a power-to-weight ratio of no more than 0.1 kW per kg) and 125 cc. The minimum age is 17.
A2- Standard motorcycle up to 35 kW (and a power-to-weight ratio of no more than 0.2 kW per kg) bike must not be derived from vehicle more than twice its power. The minimum age is 19.
A- Unrestricted motorcycles in power/size, with or without a sidecar. The minimum age is 21.
If the vehicle is classed as a tricycle, you can drive a motor tricycle of any power rating if you are over 21 and have a full car driving licence. If not, you will need a full category A1 motorbike licence to ride motor tricycles up to a power output 15 kW , and a full category A motorbike licence to ride trikes with a power output of more than 15 kW .
Hope this helps. If in doubt, ask the dealer.
The MP3 is a very heavy bike. It's a real head-turner too. If you're as self-concious as I am, don't get one. People will be nudging and pointing daily. I wouldn't get another. I sold mine and paid for the DAS. |
thanks for help mate, its a private sale but this appears to answer i can ride it as passed car test 94! regarding other comments, i've done cbt's before so not really worried about the footbrake, some other people spoke to tonight mentioned this here which is more confusing!..
'The white blue one is a hybride never produced as a LT only as a motorcycle version and also stay away from the hybride the battery will last only 5 years max a new one OLD stock is 3200 euro so if its a 2011 you need a new battery espacialy iff it didn't have alot of miles on it' ____________________ aaaaaaaaaaaaaaaaaaaaaaaaaaaa
aaaaaaaaaaaaaaawwwwwwwwwwwwww
wwwwwwwwwwwwwwwwwwsssssss |
| Ariel Badger |
| nitrosurf |
 nitrosurf Trackday Trickster
| Rogerborg |
 Rogerborg nimbA
 Posted: 08:57 - 27 Sep 2016 Post subject: |
| andyscooter wrote: | All genuine LTS had a foot brake for the rear wheel
There is a lot of dealer made ones that had a spacer kit fitted to be sold legal to ride on a car licence before the proper ones came out |
That's my vague understanding too. That the ones with factory fitted foot brakes were homogenised and registered as trikes, but that it was perfectly legal to transform an extant "bike" into a "trike" just with spacers, because why would you want one department with a set of consistent regulations when you can have DVSA, DVLA, and six contradictory definitions.
However, that means that it's likely been modified by an insurer's definition. Not that I'd declare it (how would you be sure?) and it's hardly likely to be an issue, since the chances of you being tugged and asked to prove your innocence licensing status are minuscule anyway.
If you want it, have it, just don't go mad on the price. ____________________ Biking is 1/20th as dangerous as horse riding.
| andyscooter |
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:44 - 27 Sep 2016 Post subject: |
I imagine he got away with it though. Oh, while technically you can 'drive' them without a helmet, I expect that would be the best way to actually get tugged and have an awkward conversation. ____________________ Biking is 1/20th as dangerous as horse riding.
| adrew765 |
| Polarbear |
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:47 - 27 Sep 2016 Post subject: |
| Polarbear wrote: | But when I had my trikes, you needed a bike licence to ride them, the hang over from the reliant robin. When the hell did they change that law? |
It's OK, they've changed it back again. Since 2013, new licensees need cat A rather than cat B to 'ride' a trike. ____________________ Biking is 1/20th as dangerous as horse riding.
| Shaft |
 Shaft World Chat Champion
 Posted: 15:17 - 27 Sep 2016 Post subject: |
| adrew765 wrote: |
cheers andy, by road legal - it has a new Mot doc until sept 17 , so if there was issue surely wouldn't pass this test by definition? the v5 i've seen says 'Trike' too and tax form £82 for year ,so i'm assuming its ok, police site above also says i can ride on car lic so guessing its just insurance issues then as someone mentions!? |
If it's been dealer converted, make sure the MOT tester changed it's classification from Class 2 to Class 3, otherwise things coould get a bit fractious if claim time comes around and the insurance company want to see your certificate.
Also, you can check if it's been converted - measure across the width of the front wheels, from tyre centre to tyre centre; if it measures more than 18", it's classified as a trike. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| adrew765 |
 Posted: 16:59 - 27 Sep 2016 Post subject: |
| Shaft wrote: | | adrew765 wrote: |
Also, you can check if it's been converted - measure across the width of the front wheels, from tyre centre to tyre centre; if it measures more than 18", it's classified as a trike. | thanks mate, will show on latest MOT cert if Class was changed on its mot on 20th Sept? i will measure the wheels too  ____________________ aaaaaaaaaaaaaaaaaaaaaaaaaaaa
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:09 - 27 Sep 2016 Post subject: |
| Shaft wrote: | Also, you can check if it's been converted - measure across the width of the front wheels, from tyre centre to tyre centre; if it measures more than 18", it's classified as a trike. |
Why centre to centre?
Exactly 18"?
Classified for what purpose(s)?
I ask to reduce my ignorance a bit, I've not got trikes straightened out in my head. ____________________ Biking is 1/20th as dangerous as horse riding.
| Jmoan |
 Jmoan Could Be A Chat Bot
| adrew765 |
| MahatmaAndhi |
| Shaft |
 Posted: 22:02 - 27 Sep 2016 Post subject: |
| Rogerborg wrote: | | Shaft wrote: | Also, you can check if it's been converted - measure across the width of the front wheels, from tyre centre to tyre centre; if it measures more than 18", it's classified as a trike. |
Exactly 18"?
I ask to reduce my ignorance a bit, I've not got trikes straightened out in my head. |
Quoting from the MOT manual:
"A motor tricycle is a three wheeled vehicle on which none of the wheeled elements is recognisable as a side car. These vehicles are in Class III or IV, depending on their weight.
Other than for the inspection of tyres, any two wheels of a motorcycle shall be regarded as one wheel, if the distance between the centres of the areas of contact between such wheels and the road surface is less than 460mm"
I'll do the maths for you and tell you that 18" is actually about 457mm, but, AFAIK, the widetrack versions of these three wheelers easily exceeds 460mm, so total pedantry is not required.
For a bit of backstory, the 18" measurement was introduced to allow the original twin rear wheel Transit to fall into the less stringent category of test, as it was then - it was rounded up when we went semi-metric.
I made myself a little pointy tool from plasma cut steel sheet, specifically for measuring this obscurity - as yet, I have not had cause to use it. ____________________ Things get better with age; I'm close to being magnificent........
| Rogerborg |
 Rogerborg nimbA
| adrew765 |
 Posted: 21:48 - 28 Sep 2016 Post subject: |
. Thanks fell!found a 2013 plate for 3600 but has 21000km, high miles it seems?! ____________________ aaaaaaaaaaaaaaaaaaaaaaaaaaaa
| andyscooter |
| adrew765 |
The last post was made 9 years, 349 days ago. Instead of replying here, would creating a new thread be more useful? |
