Braided brake lines, Noticeable difference/worth the money?
bandit1990
PostPosted: 10:21 - 29 Sep 2016    Post subject: Braided brake lines, Noticeable difference/worth the money? Reply with quote
I'm looking at a full brake system overhaul as my brakes are slightly spongey due to the bikes age. I'm getting better quality pads probably EBC or Brembo sintered and getting i'm a rear disc upgrade possibly front too.
I'm looking at braided brake lines which apprently will improve the bite and smoothness/feel when braking. has anyone had good results with these and could recommend a brand?
PostPosted: 10:24 - 29 Sep 2016    Post subject: Reply with quote
I like them. They'll certainly feel more positive if you've got older rubber ones fitted. Don't know if they're more positive than new rubber ones but are probably cheaper and easier to get hold of.
Of the ones I've fitted, I like the HEL hydraulic lines best in terms of overall finish and apparent resistance to the elements.
RhynoCZ
PostPosted: 10:29 - 29 Sep 2016    Post subject: Reply with quote
Braided lines are cheap and everywhere, the OEM rubber hoses are not. Performance wise, no difference what so ever. Thumbs Up
PostPosted: 10:34 - 29 Sep 2016    Post subject: Reply with quote
Depends how knackered the original lines are.
Main advantage is that it forces you to fully bleed the brakes through.
If the rubber lines are ancient then they probably do need replacing, but if they are in good condition then there will be pretty much zero difference.
Make sure you route the braided lines well. They are far less able to put up with rubbing on things, and far stiffer so not so easy to route safely.
Katy
Suntan Sid
PostPosted: 10:38 - 29 Sep 2016    Post subject: Reply with quote
There must be some difference, it's a question of how much and how noticable that difference is!
I don't see MotoGP bikes running rubber hoses, even when they're using steel discs, there must be a reason for that.
There has to be some difference in expansion within the pipe!
RhynoCZ
PostPosted: 10:48 - 29 Sep 2016    Post subject: Reply with quote
Well, smaller diameter hoses mean less fluid, but the physics work the same.
Why MOTO GP etc., could it be, that the rules state they have to use braided lines, because they seem to be more durable in case of a collision? Thinking
PostPosted: 10:58 - 29 Sep 2016    Post subject: Reply with quote
Easy to knock up a braided line to the specific length required. Rubber lines are more difficult (although I think the bolt together brake lines are not legal for road use in some countries). But with production quantities this is probably not an issue. On a race bike you can check the hose regularly and will probably strip the bike regularly, unlike a road bike that will be used for ages between any serious attention.
Most proddy race bikes will need new lines anyway, as most standard setups have a join below the bottom yoke which is not allowed under race rules. Cheap to make up some braided lines but comparatively difficult to get some different rubber lines.
Race bikes could even get away with alloy fittings on the braided hoses, which are a really bad idea on the road.
Years ago I measured the external expansion of the lines on a few of the bikes in the garage while pulling the brake levers hard. The one that expanded the most was the standard fit braided hose on Charlottes Triumph Thunderbird.
Effects of a braided line rubbing lightly:-
https://www.alfa-pages.co.uk/TempPicture/colsbrake.jpg
And lines with alloy fittings used on the road
https://www.alfa-pages.co.uk/TempPicture/HelensBrakes.jpg
https://www.alfa-pages.co.uk/TempPicture/mikesBrakes.jpg
Katy
DrDonnyBrago
PostPosted: 11:27 - 29 Sep 2016    Post subject: Reply with quote
I couldn't tell the difference in feel. Main advantage to me was that the two straight lines direct to the MC was far easier to bleed than the OEM setup with splitters and high points above the wheel.
Kawasaki Jimbo
PostPosted: 12:27 - 29 Sep 2016    Post subject: Reply with quote
Me neither, despite the outgoing hoses having 60,000 all-weather miles and the bike being kept outside.
DrDonnyBrago wrote:
-two straight lines direct to the MC was far easier to bleed than the OEM setup with splitters and high points above the wheel.
Good point.
c_dug
PostPosted: 13:01 - 29 Sep 2016    Post subject: Reply with quote
I "upgraded" to braided when I had my brakes done on the Fazer.
I'm pretty confident that rubber hoses would have felt pretty much the same, but I'm a tart and I like the look of braided hoses which swung it that way for me - given the price difference was only £20 or so.
The best thing was actually spending some money on the brakes in the first place. I paid to have them done when I had new tyres fitted - never paid for anything other than tyres on a bike in my life. They did an absolute top job and the brakes are really impressive now.
kawashima
PostPosted: 13:16 - 29 Sep 2016    Post subject: Reply with quote
My Chinese 125(YB) had awful rubber hose. Couldn't stop at signal change. Went over the line Sick Now with braided hose, I can stop at signal safely. Even with Chinese pads. I'm very satisfied. One of the best investment as well as IRC tyres.
own:2020 Serow 250
MCN
PostPosted: 13:55 - 29 Sep 2016    Post subject: Reply with quote
Yes.
I fitted a HEL braided to our CG125 which has 'reinforced' rubber as standard.
The feel was immensely improved.
SOme suggested it was simply the act of bleeding that improved the feel but It was Soooooooooo much better it was obviously due to the reduced squeeze allowed by the braided hose.
Baffler186
PostPosted: 16:46 - 29 Sep 2016    Post subject: Reply with quote
for me the difference in breaking was perhaps increased by 5% but that might have been the fresh fluid in there.
looks wise I think they look much better, and neater because you get to take off a couple of brackets that previously held the splitter. I don't care about the back, at least not until the rubber ones actually need changing.
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
PostPosted: 19:34 - 29 Sep 2016    Post subject: Reply with quote
I fitted a braided hose to the Enfield then proceeded to outbrake the tyres and have an off. That's significant if you believe that the plural of anecdote is data.
mkjackary
PostPosted: 23:13 - 29 Sep 2016    Post subject: Reply with quote
You can get braided lines fairly cheap, and a lot of the £80 ones are just the chinese £15 ones with a logo printed on them. (although not all of them)
I had a 20k 19 yo rubber brake line, swapped for a cheap chinese braided line, along with brake service/flush and EBC sintered pads it made a hell of a difference.
Wouldn't be able to say how much of it was what, but almost certain that most of it was the service and the new pads.
If yours needs replacing anyway, might as well get one, they look cool, and aren't that expensive, especially compared to OEM rubber ones.
Kaya75
PostPosted: 23:26 - 29 Sep 2016    Post subject: Reply with quote
Yes, do it.
On a bandit? You'll most likely have to drill the rear caliper retaining pin.. I did so you'll have no worries, but I guess that's over in the workshop.
Glad I did it, they feel more consistent and about a thousand time better then the poor old orignial lines.
ybr125 Sold, GSF600 K1 Bandit (For Sale), FJR13000 gen2.
talkToTheHat
PostPosted: 09:55 - 30 Sep 2016    Post subject: Reply with quote
They didn't make a lot of difference to the feel of my 2002 bandit, but it was a 500 mile a year garage queen untill I got her. A good bleed worked wonders. I will be fitting new pads in the spring, probably SBS or EBC sintered.
However on my tatty 92 virago, th brake line replacement gave loads of feel back, so mostly it's a case of how knackered your rubber lines are.
Rubber brae lines are supposed to be replaced after 4 years. It rearely happens, check the date on yours. Braded lines don't deteriorate as fast.
Bandit. does. everything.
groovylee
PostPosted: 10:00 - 30 Sep 2016    Post subject: Reply with quote
i fitted braided in place of the 16yo rubber lines on mine.
braking feel was dramatically improved, but i don't think it made them any more effective in real life terms Thumbs Up
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
kgm
PostPosted: 11:21 - 30 Sep 2016    Post subject: Reply with quote
I put HEL lines on my ER6 as I was replacing the rubber lines anyway. I found they added a bit more 'feel' and feedback to the brakes and they do feel a bit tighter (I bleed my brakes regularly). I also added EBC HH sintered pads though which gave me far more bite plus I replaced all caliper seals at the same time so I can't say for certain how much the HEL lines actually contributed.
I did find the HEL lines were a bit longer than the stock ones which made routing a bit awkward though - I'd contact them and tell them what length you want and they'll make you a custom set rather than buying off the shelf.
I'd only fit them if your stock lines are due a replacement or if your bike comes with crappy hoses to begin with.
RhynoCZ
PostPosted: 11:25 - 30 Sep 2016    Post subject: Reply with quote
I'd say all the better performance, feel, is placebo mixed with a fresh brake fluid and bleed. If your previous brakes setup was upto spec, there's no way a set of braided hoses would improve the braking performance like people often say.
Kaya75
PostPosted: 12:01 - 30 Sep 2016    Post subject: Reply with quote
this ^^ - I did say braided lines made a difference, but I did a full overall too so who knows - calliper seals are well worth doing at the same time. - took me three full days to complete tho - bleeding is a bitch - I ended up using a basting syringe with a tube on the bleed nipple and filling the system that way. then bled a lil back normally to finish off - took me a day to figure that one out / find it on the net..
groovylee
PostPosted: 12:17 - 30 Sep 2016    Post subject: Reply with quote
RhynoCZ wrote:
I'd say all the better performance, feel, is placebo , there's no way a set of braided hoses would improve the braking performance like people often say.
I'd be inclined to agree on the performance front, but the brakes 100% felt different on fitting the braided lines.
PostPosted: 12:45 - 30 Sep 2016    Post subject: Reply with quote
We need someone to replace a rubber hose with a braided one then put the manky old fluid back in.
Unfortunately, BodyGuard seems to have flounced. Crying or Very sad
groovylee
PostPosted: 13:00 - 30 Sep 2016    Post subject: Reply with quote
i didn't completely replace my fluid........ just topped up and bled it. on the rear at least. #tightfistedbastard
kgm
PostPosted: 14:08 - 30 Sep 2016    Post subject: Reply with quote
I bought a Mityvac ages agoafter a buggered up my first fluid change and got so much air in the system it was taking forever to bleed. Bit expensive but well worth it. Makes bleeding so quick and easy. I think I was about an hour to fit the hoses and calipers and bleed the system. Feels rock solid every time.
The last post was made 9 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.78 - MySQL Queries: 13 - Page Size: 134.01 Kb
