Bike from hell
loughy
PostPosted: 11:23 - 29 Sep 2016    Post subject: Bike from hell Reply with quote
so, hello! First post and looking for help Embarassed
AJS JSM 125 Trial (has a lexmoto 125 engine in though)
Background - bike was bought for £500 as a stop gap before getting my "big" bike license, however Ive had nothing but issues with it, from every angle.
I've managed to have the majority fixed but 3 things still concern me!
Electrics - the damm fuse keeps blowing, I've checked for bad connections etc but can't see anything - I think this is a case of keep looking to be honest!
Chain - God knows how many times Ive had to retort (is that even a word???) 'tighten' the chain but each time the little tw*t keeps slipping off, its had a brand new sprocket so its not the teeth!
Engine (I think anyway) - this is the most concerning part and im not sure I can describe it accurately but I'll try. When I'm accelerating/deccelerating its generally fine, but when im coasing at a steady speed/revs the bike is AWFULLY jumpy/jittery, it literally shakes/rocks back and forths. ive done a lot of googling and its definitely not the "kangaroo hopping" as the revs/speed are not affected, its just rocky.
I already know how unreliable Chinese bikes can be but I only need this for another 3-6 months then I can get rid.
Any ideas on the above please (im fairly new to bikes so dont use too much jargon Razz)
THANKS!!!
loughy
PostPosted: 11:25 - 29 Sep 2016    Post subject: . Reply with quote
Should have tagged on what I've done to the bike as I think i know what the replies will be.
In relation to the rockyness, the bikes had a brand new exhaust, brand new air filter and has just had the carb cleaned.
tom_e
PostPosted: 11:54 - 29 Sep 2016    Post subject: Reply with quote
Electrics like you say you've just got to keep looking. There'll be a bad earth or a fur'd up connecter somewhere.
Chain sounds like the actual chain is fucked rather than the sprockets, check for stiff links. This may also explain the rough ride as the chain bounces all over the sprockets.
PostPosted: 12:54 - 29 Sep 2016    Post subject: Reply with quote
How slack is the chain? Pictures would be good.
Is the rear sprocket aligned with the front? Wouldn't be the first some someone has put spacers in wrong.
The rear sprocket is bolted onto a plate called the sprocket assembly. In between that and the actual wheel will be some rubber blocks.
With the bike parked up and in neutral, grab the rear sprocket and try and rotate it in both directions. A little bit of play is OK. If the sprocket and sprocket assembly rotate significantly independently of the wheel, the cush drive rubbers are likely wrecked. That could explain both the chain jumping off and the lurching.
Although the latter is more likely to be fuelling - you'll want to let it lurch for as long as possible, immediately kill the engine and whip the plug out to see what colour it is.
loughy
PostPosted: 13:20 - 29 Sep 2016    Post subject: Reply with quote
The rear sprocket is bolted onto a plate called sprocket assembly. In between that and the actual wheel will be some rubber blocks.
With the bike parked up and in neutral, grab the rear sprocket and try and rotate it in both directions. A tiny bit of play is OK. If the sprocket and sprocket assembly rotate significantly independently of the wheel, the cush drive rubbers are likely wrecked. That could explain both the chain jumping off and the lurching.
Thanks mate, so literally 30-40 mins after typing this I get on the bike to finish work and low and behold, the chain snaps, damaging 30-40% of the teeth on the sprocket in the meantime (as well as 2 bolts) WTF.
Walked it to the nearest garage for a replacement chain/sprocket and the mechanic reckons the lurching is happening due to the chain tightening/slacking constantly as its fucked basically (theres a technical term just forgot what it was). hes gonna change the plug too as apparently thats gone!
PostPosted: 13:48 - 29 Sep 2016    Post subject: Reply with quote
Shit Chain Syndrome. Well, at least that's resolved it.
If it's still on the stock plug, sure, bin it, an NGK costs a couple of quid.
tom_e
PostPosted: 13:49 - 29 Sep 2016    Post subject: Reply with quote
Sounds like I wasn't far off then. Stiff links will eventually snap.
bikenut
PostPosted: 14:18 - 29 Sep 2016    Post subject: Reply with quote
you have a wiring diagram and multimeter? if not get one of each.
jerkiness solved via bad chain/snapped.
chains need little and often maintenance, more when its raining.
lexmoto cg125 copy, push rod engine post a picture.
a cheap multimeter will have an ammeter section, read instructions to test for load, but since its blowing fuses, be logical.
when doers it blow a fuse, when the horn works, brake lights work, side lamps work, indicators work, neutral light works??
do any lights misbehaeve when steering turned from lock to lock??
how is the wiring in the headlight and under the saddle, any snagged wires under there??
rule out each circuit one by one, or, disconnect every circuit that is battery dependant, like horn, inds, lights etc. but not charging system.
does it blow a fuse then??
if niot, add a circuit at a time, like horn, brake lights, inds, side lights until it blows a fuse, the last thing connected that blows a fuse will be at fault somewhere.
get a multimeter and wiring diagram.
nuts about bikes
loughy
PostPosted: 14:48 - 29 Sep 2016    Post subject: Reply with quote
I've done a lot of diagnosing, checking the fuse after each thing has been used and came to the conclusion it had to be the horn, as the fuse blew twice after using it instantly, job done, So i thought. Turns out it blew again a day later and 100% hadnt used the horn!!
In terms of wiring Ive removed EVERY wire, checked them and every connection and wrapped them in insulation tape. It was a 15amp fuse in, got annoyed with having to bump start (as the electric wasnt working obviously) so just put a 30amp in, job done!
tom_e
PostPosted: 14:49 - 29 Sep 2016    Post subject: Reply with quote
There's a high chance that that's just going to lead to you sat on a smoking pile of wreckage if you've not actually found the problem.
loughy
PostPosted: 14:52 - 29 Sep 2016    Post subject: Reply with quote
Its a temp fix until Ive got time to go through every wire again (this weekend)
bikenut
PostPosted: 15:53 - 29 Sep 2016    Post subject: Reply with quote
As tom says, you have effectively removed the electrical safety feature, namely the fuse, and replaced it will a 30 amp fuse, may as well be a 6 inch nail!!
The fuse protects the wiring, blowing at 15 amp, now has a 30 amp fuse, can the wires handle a 30 amp load without melting and causing further problems or a fire!!
Get a wiring diagram ( or draw your own form the bike ) and a multimeter which has an ammeter function, which will show you the load experienced, and take it from there.
You have been around the bike, any crushed/caught wires anywhere ( anywhere ) on this bike, like by the head stock or under the saddle/battery box area/engine or anywhere else ?
Is the charging system fused on this bike, probably not, but may be.
Get a wiring diagram etc before this bike and you burn/cause bad accident ( accident ha !! bit more like negligence judge rinder would say ).
Do you live in north wales ? no, thank god for that.
nuts about bikes
bikenut
PostPosted: 16:02 - 29 Sep 2016    Post subject: Reply with quote
still could be horn circuit related, is the horn live and earthed via the horn button, see other horn fault thread.
nuts about bikes
Islander
PostPosted: 17:01 - 29 Sep 2016    Post subject: Reply with quote
Look for chafing on the wiring loom especially around the headstock. I'll bet something's shorting to the frame.
loughy
PostPosted: 11:12 - 30 Sep 2016    Post subject: Update Reply with quote
Bikes been in the garage and apparently the whole back wheel needs replaced, even with a new chain/sprocket it wont work
so the guy reckons, (prepare for amazing terminology) that the bolts which hold the sprocket in place are fine, however the rubber holder bits on the wheel itself which hold the bolts in place, are completely knackered. He reckons a whole new back wheel! Sad
apparently the bearings are on their way out too! ffs
bikenut
PostPosted: 11:19 - 30 Sep 2016    Post subject: Reply with quote
See "Transmission Backlash" thread exploded view of rear wheel, similar??
The silent block bushes are replaceable but difficult to remove. They are an outer steel tube, with a rubber bonded steel inner tube.
The rubber bonding can break up due to certain chain lubes, pins drive via outer steel tube and wear the alloy hub holes, making them egg shaped.
Then new wheel or some "engineering" to make good.
Post some pictures.
Any progress with the fuse blowing ? :karma:
nuts about bikes
tom_e
PostPosted: 11:19 - 30 Sep 2016    Post subject: Re: Update Reply with quote
The cush drive rubbers do need replacing eventually and will cost the grand total of about a tenner, the bearings another tenner and half an hours labour. Tell him to fuck off.
Unless these are setup totally different to my YBR or SV. In which case he may be right and don't tell him to fuck off.
bikenut
PostPosted: 11:23 - 30 Sep 2016    Post subject: Reply with quote
I would love to watch you replace the bushes ( if the silent block pressed into alloy hub type, hopefully picture to come for this ) and wheel bearing in that time, should be entertaining. :karma:
nuts about bikes
tom_e
PostPosted: 11:26 - 30 Sep 2016    Post subject: Reply with quote
You're right half reading it while I'm supposed to be working made it sound like he was talking about cush drive rubbers rather than anything more fixed Embarassed
loughy
PostPosted: 11:48 - 30 Sep 2016    Post subject: Reply with quote
I'll chuck some pictures up this afternoon, he did mention cush drive rubbers and the block being knackered.
PostPosted: 11:56 - 30 Sep 2016    Post subject: Reply with quote
This.
Check with various things turned on / off when the bars are moved fully from side to side. All lights on (including brake light), etc.
Many bikes the horn has a permanent live, and is switched by earthing the other side of the horn. Hence a chaffed wire to the horn earthing out (can easily be intermittent as the bars are turned) can blow the fuse even when the horn isn't in use.
Katy
PostPosted: 11:58 - 30 Sep 2016    Post subject: Reply with quote
Yes, that's fairly common, for no good (or even Teflonian) reason that I've been able to determine.
bikenut wrote:
[cush drive go boom]
Telt ye so.
Why would the wheel need replaced though? Cush rubbers, bearings, bushes are all consumables.
However, I would seriously consider whether it's worth throwing more time and money at it. No matter how much you spend, it's only every going to be worth £500, tops, with a fresh MOT and nothing needing done to it.
Might be time to stick it on Gumtree as "Easy project, just not got the time" and see if you can get a litter of Staffy puppies for it.
talkToTheHat
PostPosted: 12:44 - 30 Sep 2016    Post subject: Reply with quote
Try asking at a different garage if it's uncertain that the rear wheel needs replacing. Perhaps the place you are going just lacks a decently sized press.
Bandit. does. everything.
loughy
PostPosted: 15:05 - 20 Oct 2016    Post subject: update Reply with quote
I managed to get rid of the bike to a young lad (did tell him what was wrong etc) took a hit of about £500 in total.
So glad to be rid tbf
PostPosted: 16:40 - 20 Oct 2016    Post subject: Re: update Reply with quote
Something that bad can make you hate bikes. Just put it down to the learning curve.
I have bought non runners thinking 'easy fix'. They rarely are or someone else would have fixed them already! Laughing
At the risk of upsetting Linuxyetyi and the pro Chinese bike mob, they are still no where near the reliability level I would be happy to point a new rider at.
The last post was made 10 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 135.48 Kb
