Disc alarm going off
Fin
PostPosted: 21:17 - 02 Oct 2016    Post subject: Disc alarm going off Reply with quote
I have a cheap disc alarm and have never had any problems with it but I've never used it at night through a winter. 2 nights ago I woke up at 2am to hear the alarm going off for a few seconds. I wasn't sure that it went off so I looked out the open window for a while to see if anyone was trying to make an escape, I didn't see or hear anything so put on some clothes and went outside.
No one had been to the bike as there weren't any footprints on the grass but then there was also nothing to trigger the alarm.
All I can think of is that it was a rabbit knocking the wheel, a few times...
Like most alarms if you nudge it there will be a little warning beep, if you then hit it again within a few minutes the full alarm will go off.
Today when I went out to the bike the lock was buzzing and the batteries almost dead.
Any ideas what caused the alarm to go off? I'm hoping it was just the batteries going as It's really noisy and could keep neighbours awake (while I sleep through it).
Has anyone else had issues with disc alarms? I know at my college someone had one that would go off when I park my bike or if a fly landed on it but I've always had faith in mine for not going off unless someone's touching my bike.
edit: looks like this one but with a straight key.
https://i.imgur.com/X8uj361.png
ThatDippyTwat
PostPosted: 21:30 - 02 Oct 2016    Post subject: Reply with quote
The battery is going.
Colder weather makes them perform worse. I have the same, in addition to a number of other chains, locks.
Dave70
PostPosted: 21:40 - 02 Oct 2016    Post subject: Reply with quote
I have a disc alarm similar to the one you posted and have experienced the same issue in the past.
I have noticed that in the colder mornings it gets covered in condensation on the outside, so presumably the inside does as well. I put this factor down to the problems I was experiencing.
This could be a completely wrong assumption though but it's been fine on the occasional times I've used it in the warmer months.
Teflon-Mike
tl;dr
PostPosted: 07:53 - 03 Oct 2016    Post subject: Reply with quote
Yup, old batteries and/or cold and/or damp or simply chittychink electrickery.
Snowie has had a couple; did it even with new batteries.
Given that when the house got burgled for keys & I had to go cut all the locks of everything with an angry-grinder and replace; that one didn't even put up a fight... the zink-babbit alloy that only notionally passes for metal, just sort of squeeled a bit and ran for the hills at the sight of power tool!!! Dont even bother buying new batteries; save the money & put it into another 'non-alarmed' discie.. preferably one made of actual propper metal.
Pjay
PostPosted: 12:30 - 03 Oct 2016    Post subject: Reply with quote
Maybe the short burst of alarm was a low battery warning?
winz
PostPosted: 13:18 - 03 Oct 2016    Post subject: Reply with quote
I had that exact one on my bike when it was stolen. Didn't go off and was no deterrent what so ever.
Current Bikes: BMW K1200S
Previous: Honda CBR929RR, Honda CBR1100XX, Honda CB600F
grr666
PostPosted: 15:53 - 03 Oct 2016    Post subject: Reply with quote
Xena
/thread
PostPosted: 15:59 - 03 Oct 2016    Post subject: Reply with quote
grr666 wrote:
Xena
/thread
Don't use a disk lock, use a proper chain and anchor point
/fred
Fin
PostPosted: 18:35 - 03 Oct 2016    Post subject: Reply with quote
I know the disc lock is made of cheese, I use it for the alarm, it stops people fucking with my bike and might alert me if someone tries to steal it.
Sound is what will scare thieves where I live, I don't have anything solid and easy to chain the bike to and can't be arsed to get anything either.
I also use my chain and lock on my other bike.
I don't see the point in a "decent" non alarmed disc lock, this is for my NSR where the bike could be lifted.
Thanks for the replies off those who have experienced the same issue.
Teflon-Mike
tl;dr
PostPosted: 19:06 - 03 Oct 2016    Post subject: Reply with quote
If you actually believe that? fit a proper alarm then.
Cyclones aren't exactly expensive or difficult to wire up, and with a decent 'shrieker' claxon, powered by usefully beefy 12v supply, some-what more alarming than the bird-warble squeel those hearing aid batteries and computer warning speaker put out!
Actually, maybe that's what it was! Deaf Pidgeons trying to rob the batteries for their hearing aid! Laughing
ThatDippyTwat
PostPosted: 22:51 - 03 Oct 2016    Post subject: Reply with quote
Say goodbye to your bike.
It just takes one chancer to clock it able to be lifted into a van, one can of sprayfoam to shut the alarm up (Quick, effective), and it's outta there, you are none the wiser.
Chain it up or lose it.
Fin
PostPosted: 18:44 - 05 Oct 2016    Post subject: Reply with quote
They have to be able to get the Van to the bike, driving in the drive would most likely wake someone up.
Anyway, what I said about rabbits setting it off.
It's not just any rabbits, it's demon rabbits with no eyes!
https://i.imgur.com/XkMDKBr.png
https://i.imgur.com/vUUsrdP.jpg
ThatDippyTwat
PostPosted: 19:30 - 05 Oct 2016    Post subject: Reply with quote
Even Bikelyfe yoofs would push it away after shutting it up and one twat to get it off. They've done this before, a lot of times. You haven't. I know this, as I have it all on CCTV.
They had mine from under my bedroom window last week, window was open. I didn't know anything till I went out of the door to go to work, and boom, no bike.
Your bike, your loss.
Dave70
PostPosted: 19:41 - 05 Oct 2016    Post subject: Reply with quote
Just a word of advice from someone who did something very silly today.
If you intend using a disc alarm like the one in the OP when out and about, make sure you don't leave the key for it at home. Embarassed Embarassed Embarassed
grr666
PostPosted: 19:44 - 05 Oct 2016    Post subject: Reply with quote
Of the two silly things you can do with a disclock this is the second silliest and least painful. Laughing
goto10
PostPosted: 13:07 - 06 Oct 2016    Post subject: Reply with quote
This is the exact reason why I ALWAYS lock my disk lock immediately after removing it from the bike. *
Next time you go to use it, you need to unlock it - which verifies the fact that you do, in fact, have the key with you.
My poka-yoke training in effect...
(*I have more than one disk lock, more than one bike, more than one set of keys - the room for error is large enough for me to worry about it)
Dave70
PostPosted: 14:10 - 06 Oct 2016    Post subject: Reply with quote
That disk lock engages the alarm when locked though, which would cause it to constantly alarm with any movement, vibration or knock.
Good forward thinking though. Thumbs Up
DrSnoosnoo
PostPosted: 14:16 - 06 Oct 2016    Post subject: Reply with quote
Well done!! Laughing
Get that man a beer.
Barnoe
PostPosted: 16:16 - 06 Oct 2016    Post subject: Reply with quote
I have the Xena XX14 which is similar
i find if i clean the sensor with a cotton bud every once in a while it stops false alarms.
The sensors react to a moth fart at 2000 paces once dirty..... which means you have run out into the cold in your boxers at 2am!
Even so, disc alarms are a slight deterrent when parking at the shop etc but at home use something better.
I have so much security on mine, friends laugh at me... i dont care.
i had a bike stolen in 1986 and even now i still remember that shit feeling, i would rather go over the top like i have Smile
You know you are old when you're told to slow down by your doctor and not the police.
The last post was made 9 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.26 - MySQL Queries: 13 - Page Size: 109.38 Kb
