| Reef rider |
 Reef rider L Plate Warrior
 Posted: 02:05 - 04 Oct 2016 Post subject: Fell on roundabout in first week |
Hi All,
So I done my Cbt on a 50cc and then went and got a suzuki marauder 125cc, after a couple of hours of learning gears for the first time I was fine.
All week I had riddin the bike to and from work 15 miles each way, lots of bends, roundabouts and junctions.
However I went to town on Saturday and it was raining hard. I had not riddin in the rain before so I was extra carefull.
I approached a large roundabout with traffic lights and was on the inside Lane. I was going round. At 20mph at the back end just went, I low sided and got back on. I got it home and am now fixing the damage.
What could I have done to prevent this? I have been going over it and I did not brake at all, I was not leaning much, either, I didn't downshift. maybe up from 2 to 3Rd.
This has really scared me because although I am fine I am worried it will happen again.
Tires have plenty of thread... Would winter tires grip better??
Also when replacing bike parts, can you buy cheap eBay versions for example my carburettor is 344 pounds if buying via dealer, new aftermarket 50 pounds..
Any advice you can give would be appreciated |
| bugeye_bob |
| CaNsA |
 CaNsA Super Spammer
| Banana_B1 |
 Banana_B1 Banned
 Posted: 02:20 - 04 Oct 2016 Post subject: Re: Fell on roundabout in first week |
| thx1138 |
 thx1138 World Chat Champion
 Posted: 02:42 - 04 Oct 2016 Post subject: |
If it helps you feel better, I've followed an IAM instructor who binned it on a roundabout in the wet  |
| Teflon-Mike |
 Posted: 08:42 - 04 Oct 2016 Post subject: |
Well, two things you wont like, but the marauder has a rather weird rear wheel sizing, if memory serves; and a very limited choice of available rubber to fit it. ALL of which to my sense of sensibilities is MASSIVELY over sized for the weight and performance of the bike.
Lightweight 'cruiserettes' are notorious for this.
Basically, grip is a function of weight, pushing the tyre against the road, and the stikiness of the rubber. More rubber doesn't make more grip; you need more weight and or more stikiness.
Then, in the wet, to grip tarmac, the tyre tread has to 'squeegee' water out from between the rubber and the road; here a narrower tyre will tend to 'cut' into the surface water more easily, like a speed-boat rather than a barge; and having gut into the surface water, it doesn't have so far to move it away from the contact patch.
Fat tyres do NOT work well on light bikes.
So, likely there isn't much you can do to stop it happening again, other than get a different bike!
Improving your odds?
CONFIDENCE
Smoothness is key, minimising change, keeping forces low... not 'lean'.
A lot of newbies are scared to lean bikes; and even a lot of more experienced riders, especially in the wet.. but that's how bikes steer best.
Cruiser's dont 'like' to lean, due to the natural steering geometry, but they will still do it... but combine a reluctance to lean, due to being new, compound that with more due to wet, and more still due to the bikes nature, and in all liklihood what you got is a recipe for 'teetering'.... not confidently holding a bike to a given line, but whats called 50p-piecing it, taking a round-about in a sucession of straight lines and 'corrections' like a septagon.... heptagon?!? A seven-sided 'octagon'!!!!! or the shape of a 50p piece!
Anyhow, two factors; each corner of the septagon, is tighter than the one you would have to make to do it in one smooth curve, so creates a higher load, and each one creates two changes that create more 'load' and offer oportunity for instability.
But, first fail comes a long while before that IMO... you say you did your CBT on a twist and go 50... then got the marauder, and jumped straight into commuting on the thing.
CBT is only your first lesson; it does not teach you all you need to know, only the basics; and the DL196 cert for 'completing' teh course is exactly that, a certificate of completion, not a licence. The L-Plate is for Learner, so you can practice for tests; not so you can ride to and from work every day avoiding them.
IF you are safe and competent enough to ride to work every day, you are probably safe and competent enough to take the tests and get a full licence... they dont ask any more of you than to show you can ride competently and safely accross town, without breaking any laws, causing hazard or killing any-one.... So IF you don't think you could pass a test for a full licence... DONT COMMUTE!!! If you think you are safe and competent enough to commute.... prove it; take the tests; they only cost £121.50 at last count if you self book and take'em on your 125, and you get a full licence for the privilege and never have to pay-over to repeat CBT every two years.
Use L-Plate as intended then to PRACTICE, and do it on quieter roads at quieter times of day, and get your confidence up, and work on 'smooth'.
And or go get some more lessons; learn to do stuff right, right at the start, and learn from other folks mistakes.... sorry 'experience' rather than get it the hard way in the school of hard knocks, going it alone... which on a bike, usually means falling off.... as you have learned.
Paying for lessons is usually a lot cheaper than paying for new handlebars, mirrors and dented petrol tanks, at the end of the day, too! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Matt B |
 Matt B World Chat Champion
| kgm |
 kgm World Chat Champion
| grr666 |
 grr666 Super Spammer
 Posted: 09:18 - 04 Oct 2016 Post subject: |
Shouldered rear tyre can cause the back to snake unexpectedly in the wet. How are the tyres? And are they a dodgy
no name make?
https://www.cambriantyres.co.uk/wp-content/uploads/2016/03/Tyre.png ____________________ Currently enjoying products from Ford, Mazda and Yamaha
| Holdawayt |
 Holdawayt Trackday Trickster
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:48 - 04 Oct 2016 Post subject: |
And go as slow as you like. Sod everybody else, ignore cagers up your arse, they won't actually drive into you. Imagine you're a cyclist.  ____________________ Biking is 1/20th as dangerous as horse riding.
| Gosties |
 Gosties Two Stroke Sniffer
| carpe_diem |
 carpe_diem Trackday Trickster
| Rogerborg |
 Rogerborg nimbA
| carpe_diem |
| zMastaa |
 zMastaa Derestricted Danger
| talkToTheHat |
 Posted: 12:17 - 04 Oct 2016 Post subject: |
Metzler make tyres to fit the marauder that are ok, I had them on my first one. My second had no-name rubber on it and they were actually better in the wet though. It's a bit hit and miss.
However, there is a strong chance you are on original or very old rubber on the bike. Tyres degrade with age, the meztzlers I had were 2002 originals and that was in 2011. I was considering replacing. Then I binned it.
If you've got old, cracked, or 50p shaped tyres (like the one pictured above) consider replacing.
It's not so much the tread (as long as you have some) as the compound that makes a tire work well in the wet. A knobbly tyre trying to give a dirtbike look may well have a harder compound to compensate for less contact patch and be utterly shit in the wet. I recall the DT I had being hairy on wet tarmac, but that lived in a muddy field. Winter tyres as such don't really exist for bikes. Sport touring tyres like the Michelin Pilot Road series, Pirelli Angel GT and Mezler Roadtec Z8 are where it's at on big bikes with sensible wheel sizes. One of the drawbacks of a cruiser, particularly a small capacity one, is an awful selection of tyres.
You may have hit diesel, manhole, or something else slippery. If your shifting is slow and makes you kangaroo a bit, that can be enough to upset things if already marginal.
Check you don't have chain-lube on your wheel, or splatter from the airbox drain (should be plugged and occasionally drained. If you get condensation in the engine, it causes some oil to be burped into the airbox when it boils off. The GZ/GN engine does this more than most.
Beware messing with carbs, especially cheap ones. There be dragons.
Get a cheap helmet/handlebar cam. Use it. Review footage of those WTF moments. ____________________ Bandit. does. everything. |
The last post was made 9 years, 355 days ago. Instead of replying here, would creating a new thread be more useful? |
