cg centre stand pin
sayton1211
PostPosted: 20:29 - 08 Oct 2016    Post subject: cg centre stand pin Reply with quote
hi there hoping someone can help I need to replace my centre stand on my cg 125 2005
I have taken the brake off etc all the springs from the stand but no joy in removing the stand the pivot bolt seems hollow as I can put screwdriver right though the middle tried hitting it etc atm quite stumped on how this s removed its only ting holding it on it seems like its just a hollow tube with a split pin in end
any help be great
Commuter_Tim
PostPosted: 21:13 - 08 Oct 2016    Post subject: Re: cg centre stand pin Reply with quote
any help be great
It is just a simple bar and split pin arrangement, pliers for split pin and hammer out.
On my '98 CG I had to use some serious muscle to remove the split pin, I can fully believe it had never been removed since it was fitted at the factory.
You tried any lubricant whilst you jam a screwdriver/drift in there and whack it?
With mine it was a combination of plusgas, wd40, GT85, a large flathead and lots of whacking.
If the pin is stuck you could always grind/hacksaw it.
I ride a Bandit 600... badly.
sayton1211
PostPosted: 21:18 - 08 Oct 2016    Post subject: cg centre stand pin Reply with quote
not as of yet take the pin off just seems a weird set up mist bike I know have a threaded bot been giving it a whack today seem to be damaging it more then anything else
Commuter_Tim
PostPosted: 21:20 - 08 Oct 2016    Post subject: Re: cg centre stand pin Reply with quote
It's the CG setup. Smile
it doesn't have any way of undoing itself so doesn't require torqued threads.
My CB500 was the same too.
Oddly the 2005 CG doesn't seem to be on there, but the 2004...
https://storage.googleapis.com/pfk-megabucket-732/HPL/Images/17KGA401/IMGE/F__2000.jpg
sayton1211
PostPosted: 21:26 - 08 Oct 2016    Post subject: cg centre stand pin Reply with quote
ok cool so need to give a good whack from the spilit pin end correct ?
Commuter_Tim
PostPosted: 21:27 - 08 Oct 2016    Post subject: Re: cg centre stand pin Reply with quote
Indeed, always split pin end, that's why they put the pin on that end, as the other is riveted out to stop it passing through. (if it's anything like mine it will be that rivet lip that is holding the most)
Sorry, don't mean to sound patronising. Smile
Ed Case
PostPosted: 22:33 - 08 Oct 2016    Post subject: Reply with quote
I've had several Hondas and this pivot system is typical, after a few years the pivot tube rusts into the stand and then it turns in the frame usually making the round holes into sloppy oval ones. These pivot tubes are then usually utter bastards to remove, heat sometimes helps.
PostPosted: 22:46 - 08 Oct 2016    Post subject: Reply with quote
I've yet to see a cg stand pivot that could be easily removed. They really are the work of the devil.
Commuter_Tim
PostPosted: 22:58 - 08 Oct 2016    Post subject: Reply with quote
https://s2.quickmeme.com/img/dc/dcedf16fc31ba0c7d65eca8f87102df1960a6403c8f8a1a11f6c1010c898f622.jpg
Teflon-Mike
tl;dr
PostPosted: 00:44 - 09 Oct 2016    Post subject: Re: cg centre stand pin Reply with quote
NOOOOOooooooooooooooooooooo!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
In all liklihood all you will succeed in doing is mashing up the split pin end so you cant even get the split pin back in, and the mangled mess wont EVER go through the hole in the stand!!!!
The usual niggle is that the hollow pivot pin, corroded into the stand, and then the stand turns it in the eyes in the frame, rather than rotating around it; pin carries on rusting solid in the stand, and the eyes in the frame get worn oval by it, and wear a groove in the pin, until the pin gets so thin that it wears through.
WHY do you want to remove it?
Unless its already completely shot; you are likely to make more problems than you solve, and end up having to cut the stand off altogether. If you don't have to remove it, leave it alone.
If you must take it off......
DONT try smacking the hollow pin out from the split-pin side; certainly not directly.
First course; PLUS GAS 'penetrating oil'... not fucking water-dispersant WD40... PLUS GAS.. spray the pin and give it time to creep into the stand.
Then try and hold the stand and twist the pin, to get some movement and release the hold the corrosion has.. apply more plus-gas, and repeat.
I have, managed to free up a very stubborn one, by drilling three small, 2mm holes into the pivot of the stand and squibbing penatrating oil into the holes to get it deep into the area where they are corroded together, and using the twist technique....
BUT.. unfortunate fact is ultimately they nearly always end up having to be cut out, using a hack-saw on the pivot pin both sides of the stand, to leave you with two pin ends and a stand with a section of pivot tube rustwelded inside.... getting THAT out is the tricky bit.. but using a hacksaw blade threaded through the hollow, you can slot it, get penetrating oil into the slot, and then nibble it out carefully, breaking the corrosion by chisseling the exposed corners of the split into the middle away from the stand, and lots of wiggling and twisting until it's loose and will pull out with mole grips or pliers.
VERY likely, though that the actual stand will start to show its weakspots in the effort and legs bend, or crack.. in which case it was fucked before you started... sorry!
IF you can preserve the stand, or after pin removal, make good.. which I have to say is a risky business... these things tend to get rather than, and you can end up chasing good metal to weld to to still end up with nothing of use! But IF you can salvage the stand, though, you stand a chance of being able to get a new pin; I believe they are still available off the shelf from Dave-silvers if you know the part number; and I have found one or two New-Old-Stock on e-bay..... You do NOT see them come up very often 'used'.... I wonder why Rolling Eyes
BUT, you will usually have the ovalated eyes in the frame still to contend with.
On the current Super-Dream project; (Uses same stand arrangement) I have managed to salvage the stand itself; but horibly ovalated frame eyes; rather than trying to rebuild with weld and then re-drill; I had a mate turn down a pair of 'top hat' shaped bushes that sit in the stand eye and have thin 'lip' that covers the ovalated area and holds the bush in place; that bush then has I think an M10 hole down the middle, and to plain bushes with similar hole were pressed into th stand, which was then packed with grease, and given a long M10 pin to pivot on... not as cheap as a hollow pin.... or as 'easy'... but saved welding the frame, and the stand now pivots on the bushes, not the frame eyes!
Decent used stands dont seem to come up very often... again, I wonder why... so if you cant salvage the original, you may have to abandon it.
Common solution is often to use an aftermarket side-stand; often sold for customs/cruisers or 'streeting' dirt bikes.
Cruiser stands come in a few forms, some clamp to the lower frame rails .. which isn't much good on a CG that don't have none!or are supplied like OE side-stands, and come with a lug to weld to the frame.... which is more involved and would only really go onto the old center stand eyes, and could foul pegs.. but if you can weld? probably not insurmountable. DirtBike stands, often clamp to the swing arm, and may be easier to fit.
Conveniently though, Honda CD125/185/200's have a 'foot-peg' assembly that bolts to unused mounting holes on the engine, which I believe the CG125 motor shares.... so bolts straight on, and has a side stand on it.... if you dont want the foot-pegs? they come off with a hack-saw! These do come up quite often on e-bay and for not too silly money.....
BUT, those are the sort of options.. IF it proves a lost cause when you have got the thing off....
So like I say... unless you CANNOT live with it... probably best to leave it the fuck alone!
PostPosted: 01:20 - 09 Oct 2016    Post subject: Re: cg centre stand pin Reply with quote
They have a similar problem with bullet mainstands and there's a very simple solution providing they aren't too far gone.
Instead of the splitpin, use a bicycle spoke/bit of stiff wire. Bend it close round the bottom of the pin and take the other end up and around part of the chassis. On the bullet, one of the spring lugs is handily placed. This has the effect of anchoring the pin in place and preventing it from rotating.
Now the stand will pivot around the pin instead of the pin pivoting in the lugs and ovalling them out.
https://i48.photobucket.com/albums/f216/stinkwheel/distributor/Image001.jpg
Cool huh?
I suspect this will also stop the pin seizing in place because all it can rust to is the frame lug rather than the stand tube. Even then, I suspect there will be some slight movement.
I'll let you know tomorrow on that last point because I'm taking the stand off the bullet ready for fitting a new one because mine has started to sag in the middle due to excessive rust. Hopefully it'll waltz out.
Teflon-Mike
tl;dr
PostPosted: 02:34 - 09 Oct 2016    Post subject: Re: cg centre stand pin Reply with quote
Could be cool, but doesn't look like any old small-honda stand I have seen, unfortunately, that looks like it's made out of something resembling, err... metal! Wink
PostPosted: 10:30 - 09 Oct 2016    Post subject: Re: cg centre stand pin Reply with quote
But I presume the lugs in the frame are steel? It's the ovalling of the holes and seizing of the pin that tip is supposed to stop
And believe me, while it may resemble metal, coming from India isn't the only property it shares with dried elephant dung .
MCN
PostPosted: 11:48 - 09 Oct 2016    Post subject: Reply with quote
A full on Triple post Tef.
Smile
PostPosted: 12:11 - 09 Oct 2016    Post subject: Re: cg centre stand pin Reply with quote
It did. Had to chisel off the ends of the splitpin, the pivot pin itself was heavily corroded but free to move.
My new stand comes with a pivot pin anyway so I don't need to spend ages trying to drill/punch the old splitpin out.
sayton1211
PostPosted: 12:15 - 09 Oct 2016    Post subject: cg centre stand pin Reply with quote
thanks for the replies
only reason I wanted to remove stand is that one of the legs has snapped and its also due for an mot next week
Petemate
PostPosted: 12:44 - 09 Oct 2016    Post subject: Re: cg centre stand pin Reply with quote
[quote="Teflon-Mike"]
sayton1211 wrote:
I have managed to free up a very stubborn one, by drilling three small, 2mm holes into the pivot of the stand and squibbing penatrating oil into the holes to get it deep into the area where they are corroded together, and using the twist technique....
Just what I did Mike! However it was easy for me as the frame was stripped and upside down. Plus Gas, heat, and threaded rod with sockets etc got it out.
https://i460.photobucket.com/albums/qq324/Petemate_01/Miscellaneous/Current%20wheels/4%20Removing%20rusted%20centre%20stand%20spindle.jpg
Doing it like this ensured that I could re-use the spindle. I had to get the stand off as it had suffered a terrible repair to one of the feet, and with that wrongly shaped it was almost impossible to get the bike on the stand. Now it is easy after re-shaping the foot and some welding.
82 not out....1983 Honda LA250 Custom
2008 Saab 9-3 1.9 Tid 150 Vector Sport estate
2005 Stirling Eccles Topaz 2-berth
Rob Fzs
PostPosted: 13:34 - 09 Oct 2016    Post subject: Reply with quote
just cut the thing off with a hacksaw on either side of the available space around the pin
'00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30> Yamaha RD350 YPVS F2 > Kawasaki ZZR 600 D1 > Yamaha TZR 250 2MA >Suzuki TL1000R > Yamaha TDR250 > Honda 929 blade > Suzuki SV1000 > Honda H100
Mod 2 Passed 09/06/2011
Petemate
PostPosted: 18:02 - 09 Oct 2016    Post subject: Reply with quote
Agreed Rob for a speedy result, but I wanted to retain the pin (being a tightwad lol)
Rob Fzs
PostPosted: 20:12 - 09 Oct 2016    Post subject: Reply with quote
they're only like 20 quid new off david silvers, you'll only end up smashing something worth more trying to undo the pin, i doubt OP is going to strip the bike down completely to do as you have in the pic either
Petemate
PostPosted: 18:12 - 10 Oct 2016    Post subject: Reply with quote
Ah - I know the OP would not be likely to strip the bike down completely. I did so for a (budget lol) resto, not to get at the stand, but I think I would sooner drill holes/use Plus Gas/screw it out with threaded rod and bushe than hacksaw it in situ.
Teflon-Mike
tl;dr
PostPosted: 02:11 - 11 Oct 2016    Post subject: Reply with quote
Trouble with chopping the ends of the pin, is that while you may get the stand out in a hurry... you still have to get the corroded in remains of pin out of the stand some-how.
Pete did it 'Old skool' with patience and persistence, and 'minimum brute force' and if you have the time, it pays, not only in the £20 saving on a new pivot pin, but likely saving damage to fragile center stand along the way.
The one I described doing with drill holes and plus gas, that way, was fully salvaged... slowly, and the frame it belongs to resting back on it built up as a 'roller' waiting an engine.
OP says his stands already cracked a leg, though; and having turned the air blue trying to salvage one like that, and ended up achieving nothing more than a hole in the garden fence when I lobbed it in disgust, after managing to get it out and get the pin out of it, and spend two days chasing good metal to weld it up... I think I would probably be cutting to the inevitable & reaching for the angry grinder rather than the hacksaw, and digging through the piles of 'ready spares' or looking on ebay for a CM or CD footrest bracket with side stand to bolt to the motor to prop it up after!
One I did with the top hat bushes, was taken out with a hack-saw; but I saved the stand, but took three threaded hacksaw slots to loosen the pivot tube enough to peel it out, without doing 'too' much damage to the stand. (Probably 1/4 of the tube came out as saw-dust!) As I already had a side-stand bracket on the engine for that one, I would have probably not bothered, but for the fact that my daughter wanted that bike.
Rob Fzs
PostPosted: 08:02 - 11 Oct 2016    Post subject: Reply with quote
The stand is fucked, as OP said.
Even then, you just cut a slot along side the top of the stand, lube it up and slam the pin out with a big hammer and then weld it back up again.
Petemate
PostPosted: 10:20 - 11 Oct 2016    Post subject: Reply with quote
Brutal but clever Rob - save the stand and only a spindle to obtain.
Teflon-Mike
tl;dr
PostPosted: 10:59 - 11 Oct 2016    Post subject: Reply with quote
Well you can try it!! Let us know how it goes!
Reason for drilling holes to get plus gas into the pivot tube, was/is to avoid slotting the stand, and making more work / risk.
Reason you cant get the pin out to start with is because its rusted in the tube in the stand, so you aren't dealing with good metal; & I'd not be too keen to try filling a hacksaw or dremel slot, what 1-2mm wide and four inches long with weld.. and THEN trying to get a pin to go back in the hole, AND the stand to rotate round that pin.... even if it was good metal!
And no real need. If you are chopping the pin to drop the stand from the frame; you have the whole stand in your hand, and you only want to get the remains of pin out.
Why cut the bit you'd like to keep?
Thread the hacksaw blade through the pivot pin, and refix in the hacksaw', then slot the pin from the inside. If you keep the hacksaw 'flat' you can cut right through the pin, and leave barely a witness mark on the tube of the stand....
If you have enough of the pin protruding from the tube, you may be able to grab it with pliers or grips and twist; the slot letting the pin contract enough to break rustgrip and pull out with a little wiggling.
If not; thread the hack-saw again and cut two more slots at 120deg to the first; cold chissel and a hammer, and tap into the crack between the pin and the tube and and bend the end into the middle away from the tube, they you can work the chissel into the gap to break it away down the length, and it should pull out with pliers... if not work it from the other end the same way, and the first section will drop out. Next two sections can be removed the same way, but with more of a gap to bash the 'petals' into
Same conclusion, no welding required; much less risk of buggering up the stand you hope to keep in the process, and probably no more time or effort.
Save the metalic glue gun and the dremmel for building up the ovals of the frame eyes!
The last post was made 9 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 1.66 - MySQL Queries: 13 - Page Size: 148.41 Kb
