Project compressor
PostPosted: 12:46 - 16 Oct 2016    Post subject: Project compressor Reply with quote
Was given a non-working compressor and I hope to get it working again if I do I might give it a lick of paint and tidy it up.
The problem is the motor doesn't work. When you turn it on there is the hum of power and it looks like it wants to spin but it doesn't. it just gives a little jump. I've tire giving the fan a little push to help it go but it won't I've also removed a plug from the compressor barrel to lose the compression to see if that helps but it didn't. I suspect motor brushes.
https://img.photobucket.com/albums/v295/chris-red/IMG_20161015_132028_zpsghxpshjg.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_20161015_140750_zpsjsqpzefl.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_20161015_140815_zpsttorzk5n.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_20161015_140806_zpscerklpfx.jpg?t=1476531443
https://img.photobucket.com/albums/v295/chris-red/IMG_20161015_140719_zpscsjq4blx.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_20161015_140713_zps7edgjiqi.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_20161015_140736_zpsyect8cdb.jpg
Bit stuck now, I don't know how to split the compressor from the motor the fan was held on by a circlip but I can't pull it off and don't want ot put too much force though it it looks like I might have to remove the piston and rod, but wanted to get some advice before going further.
RhynoCZ
PostPosted: 13:31 - 16 Oct 2016    Post subject: Reply with quote
Is the condenser (capacitor) charging properly? If that's not the problem, then I'd be getting a new motor, they are not that hard to come by, you can even change the whole compressor unit. You already own the most important thing, and that is the tank. My neighbor used the compressor from an old frefigerator, the pressure build up is slow, but it's working.
Well, that, if you don't mind the unit not being period accurate. Thumbs Up
Q: Is capacitor the same thing a condenser in English? In Czech we say condenser. Thinking
ZebraDriver
PostPosted: 13:33 - 16 Oct 2016    Post subject: Reply with quote
Probably won't have brushes. Check capacitor (usually swollen or leaking if faulty) , centrifugal switch (stuck open and preventing start winding/cap from working) and start winding or main winding fault (open or short circuit).
ZD
p.s. Fan will lever off shaft but will probably crack as your doing the levering (old fans tend to be brittle). After fan is off end cover will come off showing centrifugal switch and wiring connections. Smell the windings at this point - a "sweet" smell tends to indicate burnt out windings
PostPosted: 16:48 - 16 Oct 2016    Post subject: Reply with quote
The capacitor is new the bloke I got it off replace d that and gave up.
PostPosted: 17:34 - 16 Oct 2016    Post subject: Reply with quote
Don't know the capacity of that one but do remember you can buy a 50 litre clarke compressor for about £150 brand new.
You can buy new clarke electric motors for about half that (depending on size).
331X2
PostPosted: 20:30 - 16 Oct 2016    Post subject: Reply with quote
Don't think it's the machine mart 'Clarke' going by the name plate.
OP, what's the value of the capacitor and how is it connected? Does the pump rotate freely?
V2
PostPosted: 05:30 - 17 Oct 2016    Post subject: Reply with quote
If it was the capacitor then the motor should still start after spinning by hand if I remember back to college correctly!
Cant you just drop off said motor at a motor rewind place and let them have at it?
PostPosted: 09:45 - 17 Oct 2016    Post subject: Reply with quote
It all spins freely, the bloke I got it off said he replaced it with the same one that was on it before I could do with a wiring diagram for it as it looks like it has been fucked about with. I'll check it out next time I get out there.
bugeye_bob
PostPosted: 09:49 - 17 Oct 2016    Post subject: Reply with quote
Looks like others have had the same problem.
https://www.gumtree.com/p/air-compressors/clarkes-jumbo-air-compressor-se3aj-/1177989471
ThatDippyTwat
PostPosted: 18:01 - 17 Oct 2016    Post subject: Reply with quote
Change the cap. I know the bloke said he tried it, but for the couple of quid it will cost, it's worth making sure. Shit, even in Maplin, it'll be less than a fiver.
Post a picture up if you want. Need the writing and pins.
SQL
PostPosted: 04:30 - 25 Oct 2016    Post subject: Reply with quote
I have exactly the same compressor, the fan pulls off its on a spline and is a cunt to get off, the cap is almost definitely the issue, i had the same thing.
sickpup
Old Timer
PostPosted: 19:32 - 01 Dec 2016    Post subject: Reply with quote
It is. This was the companies original name prior to Clarke International when they were based in Lower Clapton Road.
Chances are spares are still available from Machine mart spares.
PostPosted: 21:17 - 01 Dec 2016    Post subject: Reply with quote
Parts list.
I see part no 27 overload cutout. Could be a thermal switch and it might have gone bad. I'd look for/at that first.
sickpup
Old Timer
PostPosted: 23:16 - 01 Dec 2016    Post subject: Reply with quote
Clarke are very good on spares. I recently had parts for a 20 year old discontinued 12/24volt starter charger and prices were very low.
sickpup
Old Timer
PostPosted: 18:07 - 02 Dec 2016    Post subject: Reply with quote
Been a long time since I worked on one of these types of compressors but I believe disassembly is as follows.
1. Remove head and barrel.
2. Remove piston pin and then piston.
3. Remove con rod.
4. Remove fan using a hydraulic puller being careful that it doesn't crumble. It's a press fit on either a smooth or ribbed surface.
5. Sharp tap with a copper mallet on fan end of crank and it should start coming out. May take a few taps but should come out.
You may need to replace the crank bearings depending on how tight the crank is.
There is a chance that the piston or crank is seized which as you haven't mentioned draining the oil is a possibility.
If you take the head off does it turn over by hand?
PostPosted: 18:56 - 02 Dec 2016    Post subject: Reply with quote
It spins freely, and feels good. I've got no time to look at it till after xmas now. I'll bare all this in mind cheers.
The last post was made 9 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 91.3 Kb
