Motobatt Battery Problem?
Tedwood
PostPosted: 11:32 - 19 Oct 2016    Post subject: Motobatt Battery Problem? Reply with quote
Thought I'd check the voltage of my battery last night. Really surprised to see the state of it.
Seems like it's a film that covers the battery case that has sort of lifted/melted/been heated. Also it seems to smell of petrol!
It's about 3 months old, the voltage was OK. First Motobatt I've bought and wish I'd stuck to the normal lead/acid type.
Trying to find the receipt to contact the seller.
Anyone else seen this?
Thanks.
tom_e
PostPosted: 11:59 - 19 Oct 2016    Post subject: Reply with quote
If it smells like petrol then are you sure there's no way some could have leaked into the battery compartment as that would melt plastic eventually.
Doovy
PostPosted: 12:03 - 19 Oct 2016    Post subject: Reply with quote
That's odd - I've had 2 Motobatt batteries in 2 different bikes and never had issue like that. Possible that it's not an official battery and a copy? Where was it bought from?
PostPosted: 12:29 - 19 Oct 2016    Post subject: Reply with quote
That's quite worrying. I would have said overcharging but if your battery voltage is OK it sort of rules that out.
pompousporcup...
PostPosted: 13:12 - 19 Oct 2016    Post subject: Reply with quote
i've also had 2 motobatt batteries in 2 different bikes and i've not had any issues at all.
what bike is your one for?
lihp
PostPosted: 13:41 - 19 Oct 2016    Post subject: Reply with quote
So your battery is melted, and smells like petrol. And your first thought is that the battery is faulty?
PostPosted: 13:50 - 19 Oct 2016    Post subject: Reply with quote
There's nothing in your battery that would melt the casing. The only thing that's in it is battery acid and amazingly, they make battery casings out of stuff that doesn't dissolve in battery acid.
If it was heat, it would be droopy. If it was overcharging it would have started gassing and bulged the casing.
So it's almost certainly been melted by some sort of solvent.
Yes, petrol would seem to fit the bill. So find out how petrol is getting in your battery box and stop it. If for no other reason than it will eventually set your arse on fire.
Petrol melts many plastics, including motorcycle fairings.
RhynoCZ
PostPosted: 13:56 - 19 Oct 2016    Post subject: Reply with quote
Is it a genuine battery? It does look kind of odd. Could you make more pictures? Thinking
Tedwood
PostPosted: 14:51 - 19 Oct 2016    Post subject: Reply with quote
Thanks for your replies.
Yes, I gave the whole area a good wash down.
Ebay - MandP
stinkwheel wrote:
.........Yes, petrol would seem to fit the bill. So find out how petrol is getting in your battery box and stop it.....Petrol melts many plastics, including motorcycle fairings.
Yes, my first thought when I smelt petrol, but couldn't see where it could have come from.
More pics:
temeluchus
PostPosted: 17:01 - 19 Oct 2016    Post subject: Reply with quote
Overflow from the fuel tank. Not brimmed it recently have you?
cb1rocket
PostPosted: 21:24 - 20 Oct 2016    Post subject: Reply with quote
unlikely to be battery, its only been attacked from one side. Something else is causing this, esp you mention the petrol smell and it probably gets hot in there too!
PostPosted: 21:49 - 20 Oct 2016    Post subject: Reply with quote
Must be happening continuously though. Wouldn't get that from one splash of petrol considering how quickly it evaporates.
Doovy
PostPosted: 09:27 - 21 Oct 2016    Post subject: Reply with quote
I've not seen a Motobatt battery like that, with the wires protruding. Interesting.
bugeye_bob
PostPosted: 10:08 - 21 Oct 2016    Post subject: Reply with quote
I thought this, but assumed it was the new way and I was just behind the times.
Doovy
PostPosted: 10:49 - 21 Oct 2016    Post subject: Reply with quote
I'm sure it's just another type that I've not seen before, mine I bought last year for my FZ1 had the standard small bracket / bolt connector bits in the top corners.
tom_e
PostPosted: 10:52 - 21 Oct 2016    Post subject: Reply with quote
It's definitely not a way they're going as their big selling point is that they offer the only 4 terminal batteries.
After a quick look on their site it seems to be a battery for some early/mid 80's 50 and 125cc setups.
temeluchus
PostPosted: 05:02 - 22 Oct 2016    Post subject: Reply with quote
What bike is it?
Time to start looking at where the fuel is coming from?
PostPosted: 09:08 - 22 Oct 2016    Post subject: Reply with quote
I've put Motobatts on the CB500, Savage and the Electra, and will probably put one on the 350. Never had an issue like this with them.
PostPosted: 13:52 - 22 Oct 2016    Post subject: Reply with quote
Looking at the photos again I'm still wondering if it has come out of the battery rather than melted the case. To me it looks like extra material on top of the battery case rather than the case itself.
bugeye_bob
PostPosted: 13:58 - 22 Oct 2016    Post subject: Reply with quote
Something has dripped that has "just" been catching the top edge of the battery on the cable side,
it then looks to have run along the seem until it reached the cables where it then ran down the battery.
Kawasaki Jimbo
PostPosted: 16:36 - 22 Oct 2016    Post subject: Reply with quote
Has someone been using epoxy resin or some other kind of glue to make a repair in the vicinity of the battery?
PostPosted: 19:59 - 22 Oct 2016    Post subject: Reply with quote
I assumed looking at the pics it was a 6V battery (which often are wired like that), but on checking it isn't. Seems to be only a 2.5ah battery, so presume it is for a bike that uses very little battery power.
Katy
The last post was made 10 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 116.03 Kb
