| AcID ZeR0 |
 AcID ZeR0 Renault 5 Driver
 Posted: 22:25 - 25 Feb 2005 Post subject: |
The only good ways I know of doing it would involve removing the exhaust. ie. Setting it on fire or filling it up with caustic soda. Both of which would not do much good to the rest of the bike.
Obviously if it has removable baffles, remove them and treat as above but a lot of mopeds don't these days.
Other than that, I can only suggest a sustained flat-out blast...but you probably do that all the time anyway. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| AcID ZeR0 |
 Posted: 23:12 - 25 Feb 2005 Post subject: |
Depends on the system but it is usually mostly on the baffle. It fills in the holes drilled in the baffle core to let the gas out.
You can get some sludge in the bottom but it is the solid carbon physically blocking parts that causes the problem. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| AcID ZeR0 |
 Posted: 23:48 - 25 Feb 2005 Post subject: |
It shouldn't providing it is a standard silencer that has a tube with holes drilled in it for a baffle.
Some sports systems have fibre packing in them or little semi-circular baffle plates welded across the inside. It is possible these could be damaged by poking at them. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Will87 |
 Will87 Trackday Trickster
The last post was made 21 years, 232 days ago. Instead of replying here, would creating a new thread be more useful? |
