Cbf 125 headlight trouble!!!
Leepreston201...
PostPosted: 20:12 - 21 Oct 2016    Post subject: Cbf 125 headlight trouble!!! Reply with quote
Hi i have a 2011 honda cbf 125
The problem im having is i start the bike up light comes on till few mins down the road it dims main beam and full beam'
Its brightens up when i apply back brake
Or i use turn signals but flashes bright/dim
I have cleaned and earth points.
New battery
New bulb
And info will be greatfull thanks in advance
Ĺ.preston
jaffa90
PostPosted: 21:06 - 21 Oct 2016    Post subject: Reply with quote
Is the battery being charged when the engine goes faster?
Leepreston201...
PostPosted: 21:25 - 21 Oct 2016    Post subject: Reply with quote
I can only presume so i travel 30+ miles to and from work batterys never died ill have to rev it up with a multi meter to test this will that work
Ĺ.preston
Nobby the Bastard
Harley Gaydar
PostPosted: 21:34 - 21 Oct 2016    Post subject: Re: Cbf 125 headlight trouble!!! Reply with quote
I still think the earth is at fault. temporarily add a second earth by putting a wire directly from the battery and to the eath on the headlight bulb (by pushing the socket over the temp wire onto the end of the bulb)
Triumph Sprint ST 1050
nowhere.elysium
The Pork Lord
PostPosted: 21:43 - 21 Oct 2016    Post subject: Reply with quote
The entire lighting circuit uses a shared earth line, so check the earth as exhaustively as you can. The lights on a CBF are pretty crappy though - they're AC as well, just to make life that little bit more entertaining.
The last post was made 10 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 43.52 Kb
